Results 1 to 5 of 5
Thread: a730W battery life / wlan WPA TKIP?
    a730W
    I see no forum for the new a730(w).
    Questions:
    - battery life of the 1100mw accu is very poor. What can i do to use the MyPal as long as possible without recharging?
    - is there a setup guide for the WLAN. I can't get it to work or have it connecting to an AP (WPA-PSK and TKIP).
    Nov 2003
    Eindhoven
    Quote Originally Posted by jbrbv
    Questions:
    I've tested the A730W personally, I could not reproduce the possible 'issue' with the battery (continues playing MP3 from 1GB Dane Elec CF card at 100% volume, using GS player for 2~2.5 hours)
    I'm not familair with the WLAN function of the A730W (does it support WPA-PSK at all? my A716 does not)
    Can you create a sub-forum for the a730(W)?
    Using the A730W with WiFi enabled, the accu lasts for 1~1.5 hours. While working the battery only lasts 2~2.5 hours, which is short compared to the competition.
    The WLAN function of the A730W supports WPA-PSK with WEP or TKIP encryption.
    Nov 2003
    Eindhoven
    done
    I have not run any test using WiFi or BT at all and don't have an A730W forhands anymore for testing..
    hello
    akku is really poor. my mypal 730w had a second akku in the box.
    the 1800er akku is VERRRY big.
    2x 1100 and 1x 1800 akku its ok for 1 day BT or wlan
    bt for GPS and wlan to check a few times mails.
    WPA-PSK and TKIP works fine.
    i have a dropdown wpa-psk und a second with tkip
    I filled out the field "key" and OK. ready to get my IP from the DHCP.
  1. WPA PSK + TKIP/AES or TKIP+AES
    By Bunzzing in forum WL-500g Q&A
    Last Post: 18-08-2005, 21:03
  2. Can't connect in WPA/PSK TKIP
    By calimero in forum WL-500g Q&A
    Last Post: 14-07-2005, 22:27
  3. WL-103b working with WPA-PSK: TKIP , But non AES option ?!
    By Stevio in forum WL-100g/WL-100gDeluxe/WL-103b/WL-120b/WL-120g [Broadcom Chipset]
    Last Post: 26-02-2005, 10:55
  4. Replies: 4
    Last Post: 04-04-2004, 14:47
