Провайдер FLEX, вы мануал кинули как раз оттуда, я его видел. Вот лог роутера:
Jan 1 00:00:04 syslogd started: BusyBox v1.20.2
Jan 1 00:00:04 kernel: klogd started: BusyBox v1.20.2 (2013-06-27 02:13:57 MSK)
Jan 1 00:00:04 kernel: Linux version 2.6.22.19 (root@localhost) (gcc version 4.6.3 (GCC) ) #1 Thu Jun 27 02:13:27 MSK 2013
Jan 1 00:00:04 kernel: CPU revision is: 00019749
Jan 1 00:00:04 kernel: Found a 8MB ST compatible serial flash
Jan 1 00:00:04 kernel: Determined physical RAM map:
Jan 1 00:00:04 kernel: memory: 02000000 @ 00000000 (usable)
Jan 1 00:00:04 kernel: Built 1 zonelists. Total pages: 8128
Jan 1 00:00:04 kernel: Kernel command line: root=/dev/mtdblock2 noinitrd init=/sbin/init console=ttyS0,115200
Jan 1 00:00:04 kernel: Primary instruction cache 32kB, physically tagged, 4-way, linesize 32 bytes.
Jan 1 00:00:04 kernel: Primary data cache 32kB, 4-way, linesize 32 bytes.
Jan 1 00:00:04 kernel: PID hash table entries: 128 (order: -3, 512 bytes)
Jan 1 00:00:04 kernel: CPU: BCM5357 rev 2 at 300 MHz
Jan 1 00:00:04 kernel: Using 150.000 MHz high precision timer.
Jan 1 00:00:04 kernel: console [ttyS0] enabled
Jan 1 00:00:04 kernel: Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Jan 1 00:00:04 kernel: Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Jan 1 00:00:04 kernel: Memory: 29216k/32768k available (2482k kernel code, 3552k reserved, 527k data, 116k init, 0k highmem)
Jan 1 00:00:04 kernel: SLUB: Genslabs=7, HWalign=32, Order=0-1, MinObjects=4, CPUs=1, Nodes=1
Jan 1 00:00:04 kernel: Mount-cache hash table entries: 512
Jan 1 00:00:04 kernel: NET: Registered protocol family 16
Jan 1 00:00:04 kernel: PCI: no core
Jan 1 00:00:04 kernel: PCI: Fixing up bus 0
Jan 1 00:00:04 kernel: Time: MIPS clocksource has been installed.
Jan 1 00:00:04 kernel: NET: Registered protocol family 2
Jan 1 00:00:04 kernel: IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
Jan 1 00:00:04 kernel: TCP established hash table entries: 1024 (order: 1, 8192 bytes)
Jan 1 00:00:04 kernel: TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
Jan 1 00:00:04 kernel: TCP: Hash tables configured (established 1024 bind 1024)
Jan 1 00:00:04 kernel: TCP reno registered
Jan 1 00:00:04 kernel: squashfs: version 3.4 (2008/08/26) Phillip Lougher
Jan 1 00:00:04 kernel: squashfs: LZMA suppport for slax.org by jro
Jan 1 00:00:04 kernel: io scheduler noop registered (default)
Jan 1 00:00:04 kernel: HDLC line discipline: version $Revision: 4.8 $, maxframe=4096
Jan 1 00:00:04 kernel: N_HDLC line discipline registered.
Jan 1 00:00:04 kernel: Serial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing enabled
Jan 1 00:00:04 kernel: serial8250: ttyS0 at MMIO 0xb8000300 (irq = 8) is a 16550A
Jan 1 00:00:04 kernel: loop: module loaded
Jan 1 00:00:04 kernel: PPP generic driver version 2.4.2
Jan 1 00:00:04 kernel: PPP Deflate Compression module registered
Jan 1 00:00:04 kernel: PPP BSD Compression module registered
Jan 1 00:00:04 kernel: MPPE/MPPC encryption/compression module registered
Jan 1 00:00:04 kernel: pflash: found no supported devices
Jan 1 00:00:04 kernel: sflash: squashfs filesystem found at block 1191
Jan 1 00:00:04 kernel: Creating 5 MTD partitions on "sflash":
Jan 1 00:00:04 kernel: 0x00000000-0x00020000 : "boot"
Jan 1 00:00:04 kernel: 0x00020000-0x007f0000 : "linux"
Jan 1 00:00:04 kernel: 0x00129ea8-0x007f0000 : "rootfs"
Jan 1 00:00:04 kernel: 0x007f0000-0x00800000 : "nvram"
Jan 1 00:00:04 kernel: 0x005b0000-0x007f0000 : "flashfs"
Jan 1 00:00:04 kernel: GACT probability NOT on
Jan 1 00:00:04 kernel: Mirror/redirect action on
Jan 1 00:00:04 kernel: u32 classifier
Jan 1 00:00:04 kernel: Performance counters on
Jan 1 00:00:04 kernel: input device check on
Jan 1 00:00:04 kernel: Actions configured
Jan 1 00:00:04 kernel: Netfilter messages via NETLINK v0.30.
Jan 1 00:00:04 kernel: nf_conntrack version 0.5.0 (1024 buckets, 4096 max)
Jan 1 00:00:04 kernel: BCM fast NAT: INIT
Jan 1 00:00:04 kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Jan 1 00:00:04 kernel: TCP cubic registered
Jan 1 00:00:04 kernel: NET: Registered protocol family 10
Jan 1 00:00:04 kernel: ip6_tables: (C) 2000-2006 Netfilter Core Team
Jan 1 00:00:04 kernel: IPv6 over IPv4 tunneling driver
Jan 1 00:00:04 kernel: NET: Registered protocol family 17
Jan 1 00:00:04 kernel: 802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
Jan 1 00:00:04 kernel: All bugs added by David S. Miller <davem@redhat.com>
Jan 1 00:00:04 kernel: VFS: Mounted root (squashfs filesystem) readonly.
Jan 1 00:00:04 kernel: Freeing unused kernel memory: 116k freed
Jan 1 00:00:04 kernel: Algorithmics/MIPS FPU Emulator v1.5
Jan 1 00:00:04 kernel: emf: module license 'Proprietary' taints kernel.
Jan 1 00:00:04 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 5.60.127.5
Jan 1 00:00:04 kernel: eth1: Broadcom BCM4329 802.11 Wireless Controller 5.60.127.5
Jan 1 00:00:04 kernel: NET: Registered protocol family 24
Jan 1 00:00:04 kernel: PPPoL2TP kernel driver, V0.18.3
Jan 1 00:00:04 kernel: vlan0: dev_set_promiscuity(master, 1)
Jan 1 00:00:04 kernel: device eth0 entered promiscuous mode
Jan 1 00:00:04 kernel: device vlan0 entered promiscuous mode
Jan 1 00:00:04 kernel: device eth1 entered promiscuous mode
Jan 1 00:00:04 kernel: br0: port 2(eth1) entering forwarding state
Jan 1 00:00:04 kernel: br0: port 1(vlan0) entering forwarding state
Jan 1 00:00:05 dnsmasq[218]: started, version 2.66 cachesize 512
Jan 1 00:00:05 dnsmasq[218]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN DHCP DHCPv6 no-scripts TFTP no-conntrack no-ipset no-auth
Jan 1 00:00:05 dnsmasq-dhcp[218]: DHCP, IP range 192.168.1.101 -- 192.168.1.254, lease time 1d
Jan 1 00:00:05 dnsmasq[218]: read /etc/hosts - 2 addresses
Jan 1 00:00:05 dnsmasq[218]: using nameserver 80.252.130.253#53
Jan 1 00:00:05 dnsmasq[218]: using nameserver 80.252.130.254#53
Jan 1 00:00:05 miniupnpd[220]: HTTP listening on port 59841
Jan 1 00:00:05 miniupnpd[220]: Listening for NAT-PMP traffic on port 5351
Jan 1 00:00:06 kernel: usbcore: registered new interface driver usbfs
Jan 1 00:00:06 kernel: usbcore: registered new interface driver hub
Jan 1 00:00:06 kernel: usbcore: registered new device driver usb
Jan 1 00:00:06 kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Jan 1 00:00:06 kernel: ehci_hcd 0000:00:04.1: EHCI Host Controller
Jan 1 00:00:06 kernel: ehci_hcd 0000:00:04.1: new USB bus registered, assigned bus number 1
Jan 1 00:00:06 kernel: ehci_hcd 0000:00:04.1: irq 5, io mem 0x18004000
Jan 1 00:00:06 kernel: ehci_hcd 0000:00:04.1: USB 0.0 started, EHCI 1.00
Jan 1 00:00:06 kernel: usb usb1: configuration #1 chosen from 1 choice
Jan 1 00:00:06 miniupnpd[220]: chain UPNP not found
Jan 1 00:00:06 kernel: hub 1-0:1.0: USB hub found
Jan 1 00:00:06 kernel: hub 1-0:1.0: 2 ports detected
Jan 1 00:00:07 kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Jan 1 00:00:07 kernel: ohci_hcd 0000:00:04.0: OHCI Host Controller
Jan 1 00:00:07 kernel: ohci_hcd 0000:00:04.0: new USB bus registered, assigned bus number 2
Jan 1 00:00:07 kernel: ohci_hcd 0000:00:04.0: irq 5, io mem 0x18009000
Jan 1 00:00:07 kernel: usb usb2: configuration #1 chosen from 1 choice
Jan 1 00:00:07 kernel: hub 2-0:1.0: USB hub found
Jan 1 00:00:07 kernel: hub 2-0:1.0: 2 ports detected
Jan 1 00:00:07 kernel: usbcore: registered new interface driver usblp
Jan 1 00:00:07 kernel: SCSI subsystem initialized
Jan 1 00:00:08 kernel: Initializing USB Mass Storage driver...
Jan 1 00:00:08 kernel: usbcore: registered new interface driver usb-storage
Jan 1 00:00:08 kernel: USB Mass Storage support registered.
Jan 1 00:00:08 kernel: NTFS driver 2.1.30 [Flags: R/O MODULE].
Jan 1 00:00:09 kernel: vlan1: dev_set_allmulti(master, 1)
Jan 1 00:00:33 l2tpd[310]: Too many retransmissions on tunnel (61642/0); closing down
upd. Повторюсь, на руках RT-N16 со свежей прошивкой от энтузиастов, все работает как часы, таких проблем нет.
