вот мой лог
Jan 1 03:00:03 kernel: PCI: Enabling device 01:02.0 (0004 -> 0006)
Jan 1 03:00:03 kernel: 2.11 Wireless Controller 4.150.10.16
Jan 1 03:00:03 kernel: device eth0 entered promiscuous mode
Jan 1 03:00:03 kernel: device vlan0 entered promiscuous mode
Jan 1 03:00:03 kernel: device eth1 entered promiscuous mode
Jan 1 03:00:03 kernel: br0: port 2(eth1) entering listening state
Jan 1 03:00:03 kernel: br0: port 1(vlan0) entering listening state
Jan 1 03:00:03 kernel: br0: port 2(eth1) entering learning state
Jan 1 03:00:03 kernel: br0: port 2(eth1) entering forwarding state
Jan 1 03:00:04 kernel: br0: topology change detected, propagating
Jan 1 03:00:04 kernel: br0: port 1(vlan0) entering learning state
Jan 1 03:00:04 kernel: br0: port 1(vlan0) entering forwarding state
Jan 1 03:00:04 dnsmasq[75]: started, version 2.22 cachesize 150
Jan 1 03:00:04 dnsmasq[75]: DHCP, IP range 192.168.1.2 -- 192.168.1.7, lease time 24h
Jan 1 03:00:04 dnsmasq[75]: DHCP, /tmp/dnsmasq.log will be written every 8h
Jan 1 03:00:04 dnsmasq[75]: read /etc/hosts - 5 addresses
Jan 1 03:00:04 dnsmasq[75]: reading /tmp/resolv.conf
Jan 1 03:00:04 kernel: usb.c: registered new driver usbdevfs
Jan 1 03:00:04 kernel: usb.c: registered new driver hub
Jan 1 03:00:04 kernel: usb-uhci.c: $Revision: 1.275 $ time 20:50:46 Mar 17 2008
Jan 1 03:00:04 kernel: usb-uhci.c: High bandwidth mode enabled
Jan 1 03:00:04 kernel: PCI: Enabling device 01:03.0 (0000 -> 0001)
Jan 1 03:00:04 kernel: ECHI PCI device 30381106 found.
Jan 1 03:00:04 kernel: UCHI reg 0x41 = 10
Jan 1 03:00:04 kernel: UCHI reg 0x41 changed to = 0
Jan 1 03:00:04 kernel: usb-uhci.c: USB UHCI at I/O 0x100, IRQ 12
Jan 1 03:00:04 kernel: usb-uhci.c: Detected 2 ports
Jan 1 03:00:04 kernel: usb.c: new USB bus registered, assigned bus number 1
Jan 1 03:00:04 kernel: hub.c: USB hub found
Jan 1 03:00:04 kernel: hub.c: 2 ports detected
Jan 1 03:00:04 kernel: PCI: Enabling device 01:03.1 (0000 -> 0001)
Jan 1 03:00:04 kernel: usb-uhci.c: USB UHCI at I/O 0x120, IRQ 12
Jan 1 03:00:04 kernel: usb.c: new USB bus registered, assigned bus number 2
Jan 1 03:00:04 kernel: usb-uhci.c: v1.275:USB Universal Host Controller Interface driver
Jan 1 03:00:05 kernel: PCI: Enabling device 01:03.2 (0000 -> 0002)
Jan 1 03:00:05 kernel: ehci_hcd 01:03.2: PCI device 1106:3104
Jan 1 03:00:05 kernel: ehci_hcd 01:03.2: irq 12, pci mem c0120000
Jan 1 03:00:05 kernel: usb.c: new USB bus registered, assigned bus number 3
Jan 1 03:00:05 kernel: ECHI PCI device 31041106 found.
Jan 1 03:00:05 kernel: ECHI reg 0x49 = 80010f20
Jan 1 03:00:05 kernel: ECHI reg 0x49 changed to = 80010f00
Jan 1 03:00:05 kernel: ECHI reg 0x4b = 80010f09
Jan 1 03:00:05 kernel: ECHI reg 0x4b changed to = 80010f29
Jan 1 03:00:05 kernel: PCI: 01:03.2 PCI cache line size set incorrectly (0 bytes) by BIOS/FW, correcting to 32
Jan 1 03:00:05 kernel: ehci_hcd 01:03.2: USB 2.0 enabled, EHCI 1.00, driver 2003-Dec-29/2.4
Jan 1 03:00:05 kernel: hub.c: USB hub found
Jan 1 03:00:05 kernel: hub.c: 4 ports detected
Jan 1 03:00:05 kernel: usb.c: registered new driver usblp
Jan 1 03:00:05 kernel: printer.c: v0.13: USB Printer Device Class driver
Jan 1 03:00:05 dnsmasq[75]: DHCPREQUEST(br0) 192.168.1.3 00:22:fb:36:65:c0
Jan 1 03:00:05 dnsmasq[75]: DHCPACK(br0) 192.168.1.3 00:22:fb:36:65:c0
Jan 1 03:00:06 kernel: usb.c: registered new driver audio
Jan 1 03:00:06 kernel: audio.c: v1.0.0:USB Audio Class driver
Jan 1 03:00:06 kernel: Linux video capture interface: v1.00
Jan 1 03:00:06 kernel: SCSI subsystem driver Revision: 1.00
Jan 1 03:00:07 kernel: Initializing USB Mass Storage driver...
Jan 1 03:00:07 kernel: usb.c: registered new driver usb-storage
Jan 1 03:00:07 kernel: USB Mass Storage support registered.
Jan 1 03:00:07 kernel: vlan1: Setting MAC address to 00 22 15 32 77 05 begin_of_the_skype_highlighting 00 22 15 32 77 05 end_of_the_skype_highlighting.
Jan 1 03:00:07 kernel: VLAN (vlan1): Underlying device (eth0) has same MAC, not checking promiscious mode.
Jan 1 03:00:07 udhcpc[100]: udhcpc (v0.9.9-pre) started
Jan 1 03:00:07 dhcp client: deconfig: lease is lost
Jan 1 03:00:08 udhcpc[100]: Lease of 10.200.62.95 obtained, lease time 604800
Jan 1 03:00:08 udpxy[109]: udpxy is starting
Jan 1 03:00:08 dnsmasq[75]: read /etc/hosts - 5 addresses
Jan 1 03:00:08 dnsmasq[75]: reading /tmp/resolv.conf
Jan 1 03:00:08 dnsmasq[75]: using nameserver 213.234.192.8#53
Jan 1 03:00:08 dnsmasq[75]: using nameserver 85.21.192.3#53
Jan 1 03:00:08 dhcp client: bound IP : 10.200.62.95 from 10.200.56.1
Jan 1 03:00:09 pppd[122]: Plugin pppol2tp.so loaded.
Jan 1 03:00:09 pppd[122]: pppd 2.4.2 started by admin, uid 0
Jan 1 03:00:09 pppd[122]: Using interface ppp0
Jan 1 03:00:09 pppd[122]: Connect: ppp0 <-->
Jan 1 03:00:09 pppd[122]: CHAP authentication succeeded
Jan 1 03:00:11 pppd[122]: local IP address 93.80.69.62
Jan 1 03:00:11 pppd[122]: remote IP address 85.21.0.251
Jan 1 03:00:11 pppd[122]: primary DNS address 85.21.192.5
Jan 1 03:00:11 pppd[122]: secondary DNS address 213.234.192.7
Jan 1 03:00:11 dnsmasq[75]: read /etc/hosts - 5 addresses
Jan 1 03:00:11 dnsmasq[75]: reading /tmp/resolv.conf
Jan 1 03:00:11 dnsmasq[75]: using nameserver 213.234.192.7#53
Jan 1 03:00:11 dnsmasq[75]: using nameserver 85.21.192.5#53
Jan 1 03:00:12 L2TP: connect to ISP
Jan 1 03:00:16 dnsmasq[75]: DHCPDISCOVER(br0) 00:25:d3:70:33:c0
Jan 1 03:00:16 dnsmasq[75]: DHCPOFFER(br0) 192.168.1.5 00:25:d3:70:33:c0
Jan 1 03:00:16 dnsmasq[75]: DHCPREQUEST(br0) 192.168.1.5 00:25:d3:70:33:c0
Jan 1 03:00:16 dnsmasq[75]: DHCPACK(br0) 192.168.1.5 00:25:d3:70:33:c0 YOUR-WFWQ5NXZMD
Jul 8 23:46:57 ntp client: Synchronizing time with time.nist.gov ...
Jul 8 23:48:42 dnsmasq[75]: DHCPREQUEST(br0) 192.168.1.5 00:25:d3:70:33:c0
Jul 8 23:48:42 dnsmasq[75]: DHCPACK(br0) 192.168.1.5 00:25:d3:70:33:c0 YOUR-WFWQ5NXZMD
Jul 8 23:48:46 kernel: change ip from 301a8c0 to 3e45505d
Jul 8 23:53:02 l2tpd[116]: Too many retransmissions on tunnel (41568/45097); closing down
Jul 8 23:53:02 pppd[122]: Terminating on signal 15.
Jul 8 23:53:02 dnsmasq[75]: read /etc/hosts - 5 addresses
Jul 8 23:53:02 dnsmasq[75]: reading /tmp/resolv.conf
Jul 8 23:53:02 dnsmasq[75]: using nameserver 213.234.192.8#53
Jul 8 23:53:02 dnsmasq[75]: using nameserver 85.21.192.3#53
Jul 8 23:53:02 L2TP: Disconnected
Jul 8 23:53:08 pppd[122]: Connection terminated.
Jul 8 23:53:08 pppd[122]: Connect time 21310312.9 minutes.
Jul 8 23:53:08 pppd[122]: Sent 32592173 bytes, received 670743889 bytes.
Jul 8 23:53:08 pppd[122]: Exit.
Jul 8 23:56:02 l2tpd[116]: tunnel_establish: gethostbyname failed for 'tp.corbina.ru'
Jul 8 23:59:02 l2tpd[116]: tunnel_establish: gethostbyname failed for 'tp.corbina.ru'
