i have the same pb with a toucam pro II.
but either i revceine no mail (High sense level) either i receive a lot of mails (Medium or Low sense level)
somebody can help me ?
i have found a temporary solution :
i use a new pwc.o and pwcx.o (see http://wl500g.info/showtread.php?t=2420)
now, i try to find how i can send a mail
bye
the link don't work ... and it's my issue
I read some articles here in the forum but I´m still confused.
Is it possible to use the logitech quickcam pro 4000 with the security mode. I did some settings but I had no motion detection an no email was sent.
Is there anybody with a working security mode. What are the settings?
it was supposed to be working..
a while ago i've turned it on (firmware 1.9.2.7-5) and it does currently not work, tested at WL500g Deluxe only
which firmware and device are you using?
I´m using the ASUS wl-500g with firmware 1.9.2.7-5.
I know this is thread number 10 or something about this issue, but there's no-one in the others threads that actually gets an answer to their problem.
How is it possible to get the WL500g to work with the Quickcam pro 4000 and motion detection? The closest I've came is to disable images, low sensitivity and thus recieving a bunch of emails.
I've tried stock firmware, old and brand new, and of course Olegs (several versions). Currently I'm using Olegs 1.9.2.7-6b.
I got no extra storage.
Has this ever worked? Why is the camera bundled with the router if it's incompatible?
All other webcam features work with the camera connected to the router.
same problem for me. help!
i have logitech 4000 pro, and email alert with pictures is working for me, but only in black/white. streaming video fram lan and wan is in colours. firmware is 1.9.4.0 from asus, hasn't done anything about it at all.
Do you use the Beta? I only see a beta edition in the firmware selector wizard...Originally Posted by tthen
Could you be so kind and quote all the setting under webcam? Of erase things like smtp and email...
I thought this was the greatest collection of WLxxx knowledge, but seems like no-one knows how to solve this rather simple issue! I tried the latest stock firmware yesterday, it actually managed to send images, not only those white squares with an X. But it just spammed emails, regardless of any motion. AND I needed to hot-reconnect the camera to make it work.... So not any progress...
Weird it's not possible to use Olegs firmware or something, seems like it can be used to anything else!
I have a WL500g (firmware 1.9.5.0) that came bundled with a Logitech QuickCam Pro. I have set it up to detect motion and send email, but that does not seem to work. There is no messages in the log indicating that motion has even been detected.
Does anyone have any hints how to make this work?
I am using Logitech QuickCam Orbit/Sphere and it works perfectly in color from WAN and LAN side, captures are getting updated every second as set in the router settings.
But I cant set the SMTP server for outgoing mail for motion detection, my ISP requires a username and password for outgoing mails. After 2 weeks I am going to vacation so I like to get this working for little bit security when I am gone for 4 weeks.
The question is how can I set the username and password for outgoing mails?
I am using WL500g with Oleg’s 1.9.2.7-6b as I mentioned everything works perfect for monitoring things so there is no problem with the cam on my router.
I did search on the forum and find couple threads but this question is not answered yet.
Filling the field for outgoing mail server wont help since I cant set the username and password and if I leave it blank it wont work either.
Any help is greatly appreciated!
No one knows a solution for this?
Can somebody show me a way to do this with SSH/Telnet?
I realy need this since we have a lot problems with security last months.
Thanks
I found finally way how to send mail with the motion alert
In the textbox for "Email Server" I filled in my mail address from my ISP instead of a SMTP server, and it worked. For "Send to" part you can fill any mail address you want even your own email same as in the other textbox.
Unfortunately it is not working good, it doesn’t matter what sensitivity I set, it keeps sending mails without any motion in front of the cam Do I need another cam to solve this problem?
