Page 3 of 13 FirstFirst 12345 ... LastLast
Results 31 to 45 of 195
Thread: [HowTo] Sane Scanner-Server with XSane Frontend
    Quote Originally Posted by carterb View Post
    Hi, did you also do that:
    http://wl500g.info/showpost.php?p=163772&postcount=28
    Regards
    Oliver
    yes. the problem is the file /etc/services that after a reboot changes back to the sane-server instead of saned
    Jul 2007
    Germany, Bonn
    then you did not change /opt/etc/init.d/S01sane-backends.
    This file looks at startup if the right service/port configuration is in /etc/services.
    Regards
    Oliver
    Regards / Grüße,
    Oliver
    Clients: Kathrein UFS910 FullHD Sat Receiver, PS3, PCs, Canon MP830 an Sane Scanner-Server, Kyocera-Mita FS1020D über Printserver
    I changed /opt/etc/init.d/S01sane-backends
    Now I have 2 problems.
    I change /etc/services to
    # Local services
    saned               6566/tcp        # SANE network scanner daemon
    but after the reboot it backs to sane-port. How that happens? Is it possible to have some file automatically doing that?
    I changed that and instead of rebooting I shut down xinetd and started it again and after that I run the code scanimage -L and I got
    [rmfontes@WL-500gp root]$ scanimage -L
    scanimage: '/opt/lib/sane/libsane-hpaio.so.1' is not an ELF file
    No scanners were identified. If you were expecting something different,
    check that the scanner is plugged in, turned on and detected by the
    sane-find-scanner tool (if appropriate). Please read the documentation
    which came with this software (README, FAQ, manpages).
    Jul 2007
    Germany, Bonn
    libsane-hpaio.so.1
    ok thats some problem with hplip-library. I have to figure out how to solve it.
    Please post the file:
    after a restart.
    The reason is a wrong "/opt/etc/init.d/S01sane-backends" because this file is looking for the right entry and if its not in, it will becreated. In your case, "sane-port" is created and not "saned". So as I told you, please post the file.
    Regards
    Oliver
    Regards / Grüße,
    Oliver
    I checked the /opt/etc/init.d/S01sane-backends file and it was sane-port. I don't know how it changed but it's ok now after the reboot. No error on the xinetd.
    The only thing that does't work is scanimage -L.
    Jul 2007
    Germany, Bonn
    good!
    I'm looking for a solution for the other problem.
    Regards
    Oliver
    Regards / Grüße,
    Oliver
    Jul 2007
    Germany, Bonn
    do the following for a test:
    rm /opt/lib/sane/libsane-hpaio.so.1
    ipkg remove hplip
    After restart do:
    ipkg install hplip
    restart and try it again with:
    scanimage -L
    Regards
    Oliver
    Regards / Grüße,
    Oliver
    hplip problem solved
    scanimage -L still doesn't detect the scanner
    Network scanning?
    Many thanks for the HowTo!
    I followed the whole thing and my Epson all-in-one RX520 is now connected to the ASUS WL-500 g Premium.
    What is working:
    • printing ubuntu Karmic & Jaunty
    • printing Windows XP
    • sane-find-scanner detects the scanner
    • scanimage -L detects the scanner after adding "0x04b8 0x081a" to epson2.conf
    I scanned an image (with scanimage) locally on the router and was able to save to the external storage device.
    What is not working:
    scanning over the network with xsane (Ubuntu and Windows XP)
    • I double checked with the instructions in the HowTo
    • what am I doing wrong - have missed something
    • how to analyse - logs - commands ?
    Jul 2007
    Germany, Bonn
    whats the error message of XSane?
    Could be a network problem.
    After a restart pleaso post the output of the following commands:
    grep "saned" /etc/services
    grep "saned" /opt/etc/init.d/S01sane-backends
    #Restart xinetd
    killall xinetd
    xinetd -d
    Post the complete output of xinetd.
    From your Windows-Commandline (cmd), type
    telnet ip.of.your.router 6566
    If the output is a black screen, well! Otherwise post the error-message.
    Regards
    Oliver
    Regards / Grüße,
    Oliver
    Re: Network scanning?
    Thanks for the quick reply, here my answers:
    Output of Xsane: no devices available
    if !( grep -q ^saned /etc/services ); then
    echo "saned 6566/tcp # SANE network scanner daemon" >> /etc/services
    #Restart xinetd
    killall xinetd
    xinetd -d
    sh: xinetd: not found
    telnet 192.168.1.1 6566
    Trying 192.168.1.1...
    telnet: Unable to connect to remote host: Connection refused
    I suppose a xinetd and/or connection problem? My answers made me thinking:
    due to some reason "xinetd" was not installed (not seen in HowTo, forgotten, ...), but
    ipkg install xinetd
    and
    Did help me one step further
    Now Xsane is starting remotely, but gives the following error:
    Unknown SANE status code -1081075667
    I'll keep searching?
    I tried scanimage both on Ubuntu and Windows and the output of
    scanimage -L
    on Ubuntu gives:
    WARNING: Unhandled message: interface=org.freedesktop.DBus.Introspectable, path=/, member=Introspect
    device `net:192.168.1.1:epson2:libusb:003:003' is a Epson generic flatbed scanner
    Thx
    Jul 2007
    Germany, Bonn
    are you sure, xinetd is installed correctly now??
    please again (now with xinetd installed) post the output of:
    #Restart xinetd
    killall xinetd
    xinetd -d
    And post your xinetd-sane-file:
    vi /opt/etc/xinetd.d/saned
    I'm looking for the error message on sane-support, because I do not know it.
    Regards
    Oliver
    Regards / Grüße,
    Oliver
    Re2: Network scanning?
    Part II:
    The output of
    #Restart xinetd
    killall xinetd
    xinetd -d
    looks like
    70/1/1@13:19:03: DEBUG: 1662 {handle_includedir} Reading included configuration file: /opt/etc/xinetd.d/saned [file=/opt/etc/xinetd.conf] [line=15]
    Service defaults
            Instances = 60
            CPS = max conn:25 wait:30
            Bind = All addresses.
            Only from:  localhost(HOST) 10.0.0.0/255.0.0.0(NET) 172.16.0.0/255.240.0.0(NET) 192.168.0.0/255.255.0.0(NET)
            No access: No blocked sites
            Logging to syslog. Facility = authpriv, level = info
            Log_on_success flags = HOST PID
            Log_on_failure flags = HOST
    Service configuration: saned
            id = saned
            flags = IPv4
            socket_type = stream
            Protocol (name,number) = (tcp,6)
            port = 6566
            wait = no
            user = 0
            group = 0
            Groups = no
            PER_SOURCE = -1
            Server = /opt/sbin/saned
            Server argv = saned
    70/1/1@13:19:03: DEBUG: 1662 {cnf_start_services} Started service: saned
    70/1/1@13:19:03: DEBUG: 1662 {cnf_start_services} mask_max = 6, services_started = 1
    70/1/1@13:19:03: NOTICE: 1662 {main} xinetd Version 2.3.14 started with no options compiled in.
    70/1/1@13:19:03: NOTICE: 1662 {main} Started working: 1 available service
    70/1/1@13:19:03: DEBUG: 1662 {main_loop} active_services = 1
    and my xinetd-sane-file:
    service saned
    port = 6566
    server = /opt/sbin/saned
    protocol = tcp
    user = admin
    group = root
    wait = no
    disable = no
    If nothing wrong with the above output, probably a backend problem?
    I had to put manufacturer ID and device ID manually in epson2.conf to let scanimage recognise the scanner?
    Thx!
    Dec 2008
    Saint-Petersburg
    Hello!
    Great thanks for you howto, carterb!
    But I have the same problem as weirt with my Epson Stylus Photo RX640. The output of all commands are the same as weirt's. Except two things.
    1) xsane gave me a segmentation fault.
    2) I am able to get scan using simple scanimage > temp.png on my PC running Ubuntu Linux.
    Jul 2007
    Germany, Bonn
    this seems to be a problem with the epson2 backend.
    I'm working on a solution.
    Regards
    Oliver
    Regards / Grüße,
    Oliver
  1. Replies: 24
    Last Post: 05-05-2015, 08:42
  2. SANE (Scanner server) - Any chance for WL-500g?
    By Dante_ in forum WL-500g Custom Development
    Last Post: 31-08-2012, 11:41
  3. [HowTo] Sane Scanner-Server mit XSane Frontend
    By carterb in forum German Discussion - Deutsch (DE)
    Last Post: 30-08-2012, 20:01
  4. HowTo install OpenVPN server
    By Tamadite in forum WL-500g/WL-500gx Tutorials
    Last Post: 31-05-2012, 21:41
  5. HowTo secure FTP server (SSL/TLS)
    By Tamadite in forum WL-500gP Tutorials
    Last Post: 14-10-2008, 20:38
