I did many and many test looking at your guides and tutorial... I waste a lot of time but... the situation is that:
1) Compiling helloworld.c with mipsel-uclibc-gcc -o hello hello.c
I can obtain hello executable.
If I run hello on the router I get
"./hello: can't load library 'AP'"
2) If after compiling I write mipsel-uclibc-ld hello
I can obtain an a.out executable that works on the router.
If I rename the file a.out -> hello on my PC then I go back to error shown on point 1.
If I copy a.out to the router and then rename it as hello all works well!
3) Compiling helloworld.c with mipsel-uclibc-gcc -static -o hello hello.c
I can get hello executable but when I run it on the router I get segmentation fault...
Please help! I'm becoming mad!
Where I'm wrong?
