Results 1 to 15 of 17
Thread: wl 500W problem with USB connection
    helo...i have a problem with my USB disk connection.I bought wl 500W and everything worked well exept the USB disk connection.
    When i connect my disc or USB key on the router,the router doesnt feels it...i dont know why? and it does with network the samewhen i click the network i cant acsses itSo my computer feels the USB but router doesnt.... it just give me the message that i dont have
    access to informations
    l made the users and share folderst like it was in the instructions but its still the sameWhat should i do? Can anyone please help meThank you
    Dec 2008
    Netherlands
    First thing:is the disk formatted?
    Next, you should check the dmesg command to see what has been detected, if any, and where it is being mounted. You can enter dmesg either in a telnet session, or you can enter it in the System Command window if you are running Oleg's firmware.
    Question
    Hey thank you for your explanation,but i actually dont know what is dmesg command?I really dont know much about that router so that is why i asked for help. What is that dmesg command and where can i found it
    The disk what formated when i bought it.Now all the informations are on it and about firmware...i have the ORIGINAL ONE....you also said something about Oleg's firmware ...Where can i found it and download it?i was looking for it already,but i didnt found it to download?
    Dec 2008
    Netherlands
    If you know how to log into the router and if you can click on the System Setup menu, then click on System Command, you'll find a text box where you can enter these letters: dmesg (then press Enter).
    You'll see a large amount of text, copy the last 30 or so lines here.
    Look here is my sistem setup menu...but i cant find sistem command
    Dec 2008
    Netherlands
    That's because you're not running Oleg's firmware but the Asus default one.
    Quote Originally Posted by EdP View Post
    Where can i download Oleg's firmware than? does anyone know?
    Dec 2008
    Netherlands
    OK, I think I understand what you wrote now.
    You're getting an error message about not having sufficiant access permission.
    When you're running the Asus firmware, you only have the option of using ftp.
    Dec 2008
    Netherlands
    This entire forum is about Oleg firmware.
    Here's the entry point for WL-500w.
    Here's the general starting point for installing Oleg's firmware on WL-500g/WL-500gx, I don't know if that's different for WL-500w, I guess not.
    Yes you understood right
    I also understand now...thank you for your help...but i still cant find Oleg to download
    Okej i will try to download now the newest version...Download latest (1.9.2.7-10) i hope it will work...thank you for the link....i will try it and wrote it here how it goes...or if there will be any problems
    Okej i download it and instal and it works...now here are these last 30 or so lines... i copied all so it will be easier for you:
    CPU revision is: 00029006
    Primary instruction cache 16kb, linesize 16 bytes (2 ways)
    Primary data cache 16kb, linesize 16 bytes (2 ways)
    Linux version 2.4.20 (root@localhost) (gcc version 3.2.3 with Broadcom modifications) #18 Sun Mar 30 13:13:29 MSD 2008
    Setting the PFC to its default value
    Determined physical RAM map:
    memory: 02000000 @ 00000000 (usable)
    On node 0 totalpages: 8192
    zone(0): 8192 pages.
    zone(1): 0 pages.
    zone(2): 0 pages.
    Kernel command line: root=/dev/mtdblock2 noinitrd init=/linuxrc console=ttyS0,115200
    CPU: BCM4704 rev 9 pkg 0 at 264 MHz
    Calibrating delay loop... 263.78 BogoMIPS
    Memory: 30092k/32768k available (1862k kernel code, 2676k reserved, 136k data, 72k init, 0k highmem)
    Dentry cache hash table entries: 4096 (order: 3, 32768 bytes)
    Inode cache hash table entries: 2048 (order: 2, 16384 bytes)
    Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
    Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes)
    Page-cache hash table entries: 8192 (order: 3, 32768 bytes)
    Checking for 'wait' instruction... unavailable.
    POSIX conformance testing by UNIFIX
    PCI: Initializing host
    PCI: Fixing up bus 0
    PCI: Fixing up bridge
    PCI: Fixing up bus 1
    Linux NET4.0 for Linux 2.4
    Based upon Swansea University Computer Society NET3.039
    Initializing RT netlink socket
    Starting kswapd
    Journalled Block Device driver loaded
    devfs: v1.12c (20020818) Richard Gooch (rgooch@atnf.csiro.au)
    devfs: boot_options: 0x1
    NTFS driver v1.1.22 [Flags: R/O]
    pty: 256 Unix98 ptys configured
    Serial driver version 5.05c (2001-07-08) with MANY_PORTS SHARE_IRQ SERIAL_PCI enabled
    ttyS00 at 0xb8000300 (irq = 3) is a 16550A
    ttyS01 at 0xb8000400 (irq = 3) is a 16550A
    HDLC line discipline: version $Revision$, maxframe=4096
    N_HDLC line discipline registered.
    loop: loaded (max 8 devices)
    PPP generic driver version 2.4.2
    PPP Deflate Compression module registered
    PPP BSD Compression module registered
    MPPE/MPPC encryption/compression module registered
    PPPoL2TP kernel driver, V0.13 (oleg@cs.msu.su)
    Physically mapped flash: Found an alias at 0x800000 for the chip at 0x0
    Physically mapped flash: Found an alias at 0x1000000 for the chip at 0x0
    Physically mapped flash: Found an alias at 0x1800000 for the chip at 0x0
    Amd/Fujitsu Extended Query Table v1.3 at 0x0040
    Flash Id: Vendor: 0x0001 Device: 0x007e
    number of CFI chips: 1
    Flash device: 0x800000 at 0x1c000000
    Physically mapped flash: squashfs filesystem found at block 912
    Creating 5 MTD partitions on "Physically mapped flash":
    0x00000000-0x00040000 : "boot"
    0x00040000-0x007f0000 : "linux"
    0x000e4000-0x007f0000 : "rootfs"
    0x007f0000-0x00800000 : "nvram"
    0x003e0000-0x007f0000 : "flashfs"
    sflash: found no supported devices
    NET4: Linux TCP/IP 1.0 for NET4.0
    IP Protocols: ICMP, UDP, TCP, IGMP
    IP: routing cache hash table of 512 buckets, 4Kbytes
    TCP: Hash tables configured (established 2048 bind 4096)
    Linux IP multicast router 0.06 plus PIM-SM
    ip_conntrack version 2.1 (256 buckets, 2048 max) - 352 bytes per conntrack
    ip_conntrack_pptp version 1.9 loaded
    ip_nat_pptp version 1.5 loaded
    ip_tables: (C) 2000-2002 Netfilter core team
    ipt_time loading
    NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
    IPv6 v0.8 for NET4.0
    IPv6 over IPv4 tunneling driver
    NET4: Ethernet Bridge 008 for NET4.0
    802.1Q VLAN Support v1.7 Ben Greear <greearb@candelatech.com>
    All bugs added by David S. Miller <davem@redhat.com>
    FAT: bogus logical sector size 40448
    NTFS: Unable to set blocksize 512.
    VFS: Mounted root (squashfs filesystem) readonly.
    Mounted devfs on /dev
    Freeing unused kernel memory: 72k freed
    Algorithmics/MIPS FPU Emulator v1.5
    eth0: Broadcom BCM47xx 10/100 Mbps Ethernet Controller 4.150.10.16
    eth1: Broadcom BCM47xx 10/100 Mbps Ethernet Controller 4.150.10.16
    PCI: Enabling device 01:02.0 (0004 -> 0006)
    eth2: Broadcom BCM4329 802.11 Wireless Controller 4.150.10.16
    device eth0 entered promiscuous mode
    device eth2 entered promiscuous mode
    br0: port 2(eth2) entering listening state
    br0: port 1(eth0) entering listening state
    br0: port 2(eth2) entering learning state
    br0: port 2(eth2) entering forwarding state
    br0: topology change detected, propagating
    br0: port 1(eth0) entering learning state
    br0: port 1(eth0) entering forwarding state
    usb.c: registered new driver usbdevfs
    usb.c: registered new driver hub
    usb-uhci.c: $Revision: 1.275 $ time 20:50:46 Mar 17 2008
    usb-uhci.c: High bandwidth mode enabled
    PCI: Enabling device 01:03.0 (0000 -> 0001)
    ECHI PCI device 30381106 found.
    UCHI reg 0x41 = 10
    UCHI reg 0x41 changed to = 0
    usb-uhci.c: USB UHCI at I/O 0x100, IRQ 12
    usb-uhci.c: Detected 2 ports
    usb.c: new USB bus registered, assigned bus number 1
    hub.c: USB hub found
    hub.c: 2 ports detected
    usb-uhci.c: v1.275:USB Universal Host Controller Interface driver
    PCI: Enabling device 01:03.2 (0000 -> 0002)
    ehci_hcd 01:03.2: PCI device 1106:3104
    ehci_hcd 01:03.2: irq 12, pci mem c0120000
    usb.c: new USB bus registered, assigned bus number 2
    ECHI PCI device 31041106 found.
    ECHI reg 0x49 = 80010f20
    ECHI reg 0x49 changed to = 80010f00
    ECHI reg 0x4b = 80010f09
    ECHI reg 0x4b changed to = 80010f29
    PCI: 01:03.2 PCI cache line size set incorrectly (0 bytes) by BIOS/FW, correcting to 32
    ehci_hcd 01:03.2: USB 2.0 enabled, EHCI 1.00, driver 2003-Dec-29/2.4
    usb.c: registered new driver usblp
    printer.c: v0.13: USB Printer Device Class driver
    hub.c: connect-debounce failed, port 2 disabled
    hub.c: new USB device 01:03.2-2, assigned address 2
    usb.c: USB device 2 (vend/prod 0x1058/0x1100) is not claimed by any active driver.
    usb.c: registered new driver audio
    audio.c: v1.0.0:USB Audio Class driver
    Linux video capture interface: v1.00
    SCSI subsystem driver Revision: 1.00
    Initializing USB Mass Storage driver...
    usb.c: registered new driver usb-storage
    scsi0 : SCSI emulation for USB Mass Storage devices
    Vendor: WD Model: 5000AAV External Rev: 1.65
    Type: Direct-Access ANSI SCSI revision: 02
    Attached scsi disk sda at scsi0, channel 0, id 0, lun 0
    SCSI device sda: 976773168 512-byte hdwr sectors (500108 MB)
    Partition check:
    /dev/scsi/host0/bus0/target0/lun0:<7>eth0: no IPv6 routers present
    eth2: no IPv6 routers present
    p1
    WARNING: USB Mass Storage data integrity not assured
    USB Mass Storage device found at 2
    USB Mass Storage support registered.
    MSDOS FS: IO charset utf8
    MSDOS FS: Using codepage 866
    What next???
    Dec 2008
    Netherlands
    Sheesh you're quite fast.
    You can go into USB Application > Samba, make the appropriate changes, e.g.
    Samba File Shares: All Partitions
    Default Access Level: Read/Write
    Host Name: WL500W
    Workgroup Name: <same as on your pc>
    DOS Codepage: <pick one>
    and press Apply > Finish > Reboot.
    OMG you are the bestThank you so so so soooo much...i do what you said and now all works :P thank you so much for help.....without your information it probably still wouldn work
    so i made this for today....i will try to to engage in more after the weekend because im not home at the weekend...so we keep in touch...
    i have one more question...do you mayby know how could i do on the networks, that all users dont have permisson to see the folders or the
    whole disk ...so on short if i can make users and give them some kind of assign rights...if you understand what i meanAnd how can i connect from FTP
    during the disk to on case from computer during internet....i will try to explain it what i mean more exactly in monday,when i come homeif you wont understand........so we keep in touch...:Pbut so far realy realy thank you so much
    Dec 2008
    Netherlands
    You're welcome
    I must say, you're making great progress.
    About your last question: I think you'ld need to install the ipkg samba for that, so if you're feeling brave enough you could try that. I must warn you though, you'll need some basic experience with Linux or it's going to be difficult and confusing for you.
    I'd say count your blessings and leave it like it is now
    Congratulations!
  1. USB problem
    By Oyabun in forum WL-500gP Q&A
    Last Post: 15-06-2008, 22:22
  2. ASUS WL-500gP + USB HDD problem
    By nsec in forum WL-500gP Tutorials
    Last Post: 21-04-2008, 07:04
