almost sound like a broadcast storm
Try to set the router back to manufacturers defaults (using the reset button), if that doesn't work use the asus firmware restoration tool to reflash the firmware.
all the tricks should described in the manual
and if that doesn't work either, I can only recommend going for warranty
