if I understand it right, you want to use the wl500w to assign dhcp ip-adresses?
then, just simply plug in a cable in the switch and the other and on the LAN port (not wan) of the router
yes, it's that easy![]()
Hello,
I wonder if it is possible to connect the wl500w with a lan-hub...
the lan-ports are to few for my lan... any ideas or suggestions how this could work?
is the wl500w ready for cascading?
Maybe it could look like this...
Code:| | | ____ | | | | | | | | | | | | | | | | | | | P1 P2 P3 P4 P1 P2 P3 P4 P5 P6 P7 P8 | | WL500W e.g. 8-port Hub
I dont have a hub, so i can not try :-(
Or how do you handle the problem, if you need more lan-ports?
greetz from austria!
norton
A network switch would be preferrable to a hub, because using a hub can cause your network traffic to collide. Switches don't have that problem. Besides, you'd probably have a real hard time to even find hubs nowadays.
