There are two versions of python 2.4 and 2.5 separated. 2.4 worked with much troubles on 0.9.19. When I moved to 0.9.28 I did not check python. libstdc++ is wrong link as it should be linked with libuclibc++.
I'll update the page with some DD-WRT info (won't be a lot as I actually only have experience with Oleg - I'm more looking for file/ftp/news servers/clients on my router than the actual WLAN tuning which as I understand is the DD-WRT strength?) and see if I can get it into the Wiki.
Now I have installed your updated uClibc library on my router and reinstalled all packages from the oleg feed. Most things seem to be working (including unrar - one of my main missing items) however python now gives an error message. Whenever I start it up it says "python: can't load library 'libstdc++.so.6'". I'll try compiling it myself (my buildroot is still compiling at this moment so I'll need to be patient) but do you have already any idea what could be the problem here?
Kind regards,
Peter.
It seems that python25 is indeed better - I tried it and it actually works (at least it starts to run my program). However the program I am needing it for also depends on some other python packages (py-cherrypy, py-cheetah and py-elementtree) so I don't get very far. All of these packages are also available from the feed but they all are assuming a Python24 installation, they don't work with Python25. I'm trying to get them working also on Python25, let's hope this works...
Once that is working the final missing piece I need to get me setup working is par2cmdline. As this one is not available from the feeds I tried compiling it myself. It worked but once loaded on my router I got the "cannot find libstdc++" message again. I created a patch for the Makefile.am file not to add this library anymore, however when compiling I noticed that it still showed up. After some googling it appears that actually the g++ compiler is adding the "-lstdc++" itself automatically! There are some workarounds I have been thinking about (e.g. using the "-nodefaultlibs" option in g++) but as this must be a common problem for everyone using the build environment do you have any idea on the best/standard way to solve this?
I have changed shared library linking option in python24_2.4.4-2_mipsel.ipk and now python works. Run regression tests with
Code:cd /opt/lib/python2.4/test for f in test_[a-z]*.py; do python $f 2>/dev/null>/dev/null || echo "$f failed with error #$?" ; done > /tmp/harddisk/tmp/python-regression-test.txt
Hi oleo,
buildroot_3.4.6-8_mipsel.ipk (or maybe uclibc-opt_0.9.28-8_mipsel.ipk) package seems to be broken (lies in http://ipkg.nslu2-linux.org/feeds/op...g/cross/stable feed):
1. it misses /opt/sbin/ldconfig
2. even after I properly updated library cache every program in /opt doesn't work (as if libraries are missed or broken).
I reverted package to the version I had before upgrade (3.4.6-5 in particular) and everything works fine now.
Please, take a look. Merry Christmas!
buildroot_3.4.6-8_mipsel.ipk and uclibc-opt_0.9.28-8_mipsel.ipk are now split in such way that it does not provide common files. There is builtin dependency that buildroot and any other package needs uclibc-opt package.
With uclibc-opt-0.9.28-9 and buildroot_4.1.1-9 I have backported some patches to uClibc and upgraded GCC to latest stable version. Try it out. All apps should work. The problem was with -7 and not with -8 from my testings.
Recent advances brings complete native toolchain for all Asus routers with external storage. Supported firmwares are Oleg, DD-WRT, X-Wrt, OpenWrt, ...
Example instalation and native building of optware packages on router itself:
This toolchain brought also perl and its 70+ packages that depend on perl. Spamassasin and similar packages are now ready for use.Code:ipkg install optware-devel cd /tmp/harddisk svn co http://svn.nslu2-linux.org/svnroot/optware/trunk optware cd optware export OPTWARE_TARGET=oleg make bc
Great work!
Cant wait to try it out!
as far as I can see, the 0.9.7 version is the latest ipkg module available. Could anyone please compile the 0.9.8 version for the WL-500g?
Thanks.
Thanks a lot. I guess the ipk package should appear later on http://ipkg.nslu2-linux.org/feeds/op...ross/unstable/
Am I right? Or should the feed be manually updated?
Edit: ushare 0.9.8 is now up and running. There is a problem in finding the config file, since it refers to "/etc/opt//etc/opt/ushare.conf" but it can be manually started with the command line switches and most important, it finally makes my WL-500gx kindda work together with the Telegent TG100 media receiver, which was not possible until now!! (AVI files do not work though :-()
Fixed conf location in http://trac.nslu2-linux.org/optware/changeset/5153
We have rebuilded all packages for oleg and ddwrt repository as suggested by Oleg due to major change of buildroot from gcc3.4.6->gcc-4.1.1 and binutils from
http://ipkg.nslu2-linux.org/feeds/op...table/?C=M;O=D
As usual, if some package is giving segmentation fault, users are instructed to update, upgrade and refresh packege and its dependent packages. Sometimes dependent packages are upgraded without rebuilding package which relies on them. Optware maintainers are aware of this problem which can cause loading incompatible libraries. Testing for such incompatibilities is difficult and thus we rely on user reports.
Sample forcing package upgrade.
As this can be tedious job I recommend the following one line package-refresh command:Code:[admin@oleo root]$ ipkg update Downloading http://ipkg.nslu2-linux.org/feeds/optware/oleg/cross/stable/Packages.gz Inflating http://ipkg.nslu2-linux.org/feeds/optware/oleg/cross/stable/Packages.gz Updated list of available packages in /opt/lib/ipkg/lists/optware Successfully terminated. [admin@oleo root]$ ipkg install -force-reinstall svn Reinstalling svn (1.4.2-1) on /opt/... Downloading http://ipkg.nslu2-linux.org/feeds/optware/oleg/cross/stable/svn_1.4.2-1_mipsel.ipk Configuring svn Successfully terminated.
For more info visit http://www.nslu2-linux.org/wiki/FAQ/Optware-uClibcBuildCode:awk '/^Package:/{system("ipkg install -force-reinstall -force-defaults " $2)}' /opt/lib/ipkg/status
I hope that with upcoming -7g firmware this will become default repository for Oleg firmware and that "wl500g" will be obsoleted.
