попробовал 9 пункт но все без изменений...
Jan 1 00:00:02 kernel: hub.c: USB hub found
Jan 1 00:00:02 kernel: hub.c: 2 ports detected
Jan 1 00:00:03 kernel: ehci_hcd 00:03.1: PCI device 14e4:471a
Jan 1 00:00:03 kernel: ehci_hcd 00:03.1: irq 6, pci mem b8003800
Jan 1 00:00:03 kernel: usb.c: new USB bus registered, assigned bus number 2
Jan 1 00:00:03 kernel: ehci_hcd 00:03.1: USB 0.0 enabled, EHCI 1.00, driver 10 Dec 2004/2.4
Jan 1 00:00:03 kernel: hub.c: USB hub found
Jan 1 00:00:03 kernel: hub.c: 2 ports detected
Jan 1 00:00:03 kernel: usb.c: registered new driver usblp
Jan 1 00:00:03 kernel: printer.c: v0.13: USB Printer Device Class driver
Jan 1 00:00:04 kernel: hub.c: new USB device 00:03.0-1, assigned address 2
Jan 1 00:00:04 kernel: usb.c: USB device 2 (vend/prod 0x1011/0x3198) is not claimed by any active driver.
Jan 1 00:00:04 kernel: usb.c: registered new driver audio
Jan 1 00:00:04 kernel: audio.c: v1.0.1:USB Audio Class driver
Jan 1 00:00:04 kernel: Linux video capture interface: v1.00
Jan 1 00:00:05 kernel: SCSI subsystem driver Revision: 1.00
Jan 1 00:00:05 kernel: Initializing USB Mass Storage driver...
Jan 1 00:00:05 kernel: usb.c: registered new driver usb-storage
Jan 1 00:00:05 kernel: USB Mass Storage support registered.
Jan 1 00:00:05 kernel: vlan1: Setting MAC address to 00 90 4c c0 00 00.
Jan 1 00:00:05 kernel: VLAN (vlan1): Underlying device (eth0) has same MAC, not checking promiscious mode.
Jan 1 00:00:06 dnsmasq[73]: read /etc/hosts - 2 addresses
Jan 1 00:00:06 dhcp client: deconfig: lease is lost
Jan 1 00:00:06 kernel: usb.c: registered new driver serial
Jan 1 00:00:06 kernel: usbserial.c: USB Serial support registered for Generic
Jan 1 00:00:06 kernel: usbserial.c: Generic converter detected
Jan 1 00:00:06 kernel: usbserial.c: Generic converter now attached to ttyUSB0 (or usb/tts/0 for devfs)
Jan 1 00:00:06 kernel: usbserial.c: Generic converter now attached to ttyUSB1 (or usb/tts/1 for devfs)
Jan 1 00:00:06 kernel: usbserial.c: USB Serial Driver core v1.4
Jan 1 00:00:16 pppd[116]: pppd 2.4.5 started by admin, uid 0
Jan 1 00:00:17 ddns update: could not open config file "/etc/ddns.conf": No such file or directory
Jan 1 00:00:17 ddns update: error parsing config file "/etc/ddns.conf"
Jan 1 00:00:18 pppd[116]: Serial connection established.
Jan 1 00:00:19 pppd[116]: Using interface ppp0
Jan 1 00:00:19 pppd[116]: Connect: ppp0 <--> /dev/usb/tts/0
Jan 1 00:00:22 pppd[116]: CHAP authentication succeeded
Jan 1 00:00:22 pppd[116]: MPPC compression enabled
Jan 1 00:00:22 pppd[116]: local IP address 89.253.26.211
Jan 1 00:00:22 pppd[116]: remote IP address 89.253.1.45
Jan 1 00:00:22 pppd[116]: primary DNS address 212.129.96.13
Jan 1 00:00:22 pppd[116]: secondary DNS address 212.129.101.1
Jan 1 00:00:22 dnsmasq[73]: read /etc/hosts - 2 addresses
Jan 1 00:00:22 dnsmasq[73]: using nameserver 212.129.101.1#53
Jan 1 00:00:22 dnsmasq[73]: using nameserver 212.129.96.13#53
Jan 1 00:00:23 ddns update: ez-ipupdate Version 3.0.11b7, Copyright (C) 1998-2001 Angus Mackay.
Jan 1 00:00:23 ddns update: ez-ipupdate started for interface vlan1 host *.dyndns.org using server members.dyndns.org and service dyndns
Jan 1 00:00:23 ddns update: (*.dyndns.org) unable to resolve interface vlan1
Jan 1 00:00:23 Automatic IP: connected to ISP
Jul 3 07:59:32 ntp client: Synchronizing time with time.nist.gov ...
Jul 3 08:00:18 pppd[116]: System time change detected.
