Originally Posted by
avberk
One thing i don't understand why transmission is not installed to /opt
it should normally be here:
"/opt/share/transmission"
Do you have a /opt folder?
Can you post the output of 'df'?
What kind of disks are connected to the asus?
I have a folder "/opt/share/transmission"
output of df is:
[admin@WL-500GP root]$ df
Filesystem 1K-blocks Used Available Use% Mounted on
rootfs 3072 3072 0 100% /
/dev/root 3072 3072 0 100% /
/dev/discs/disc0/part2
15694088 437032 14459832 3% /opt
/dev/discs/disc0/part3
937887716 209317168 680928588 24% /mnt
I have a 1TB Western Digital External
