Results 16 to 22 of 22
Thread: wl-500g help needed before it kills me.
Threaded View
    Jun 2009
    liverpool uk
    Unhappy wl-500g help needed before it kills me.
    Hi all.
    This is my first post on these here boards.
    I hope to have lots of fun from here on in.
    Any way back to my question.
    Im new to this router and im stuck and can not progress till i can find an answer.
    I got a wl-500g about three weeks ago and want to use the ftp feature for getting drivers and that remotely.
    I have been trying to sort this for over 2 weeks but no luck as yet.
    ive been using filezilla as a way to connect from my home pc to the usb drive with the files on.
    But when i try to connect from any other pc not in my home then filezilla says this to me which im now stumped if i can sort without asking for help first.
    filezilla say this.
    Status: Connecting to REMOVED FOR SECURITY REASONS ...
    Status: Connection established, waiting for welcome message...
    Response: 220 Welcome to FTP server.
    Command: USER wraith36
    Response: 331 Password required for user wraith36.
    Command: PASS ********
    Response: 230 User wraith36 logged in.
    Command: SYST
    Response: 215 UNIX Type: L8 (Linux).
    Command: FEAT
    Response: 503 Command not understood.
    Status: Connected
    Status: Retrieving directory listing...
    Command: PWD
    Response: 257 "/" is current directory.
    Command: TYPE I
    Response: 200 Type set to I.
    Command: PASV
    Response: 227 Entering Passive Mode (192,168,1,1,4,4)
    Status: Server sent passive reply with unroutable address. Passive mode failed.
    Command: PORT 192,168,0,3,10,190
    Response: 200 PORT command successful.
    Command: LIST
    Response: 501 Error in parameters.
    Error: Failed to retrieve directory listing
    In my drive i have 2 folders named ftp_pub and ftp_pvt and have put files in both as a way to view inside the folder on connecting to it which works fine from my home pc just not from the works pc i use to test with.
    Am i missing something here.
    I have had a good look round the boards for what the issue may be but yet to find something along the same lines.
    I dont even know if im even able to do what im after which is use my drive for ftp use out side my own home.
    Im using oleg's firmware which is as up to date as i can get them.
    If you can help in any way please do before ive pulled my hair out.
    Sorry my first post is me needing help straight away.
    Thanks for any help forth coming.
    If you need any other info please ask away.
    Thanks. Wraith36
    www.wz-gaming.co.uk
    A mature gaming clan.
  1. My 500G died. Now what?
    By Rapax in forum WL-500g Q&A
    Last Post: 03-09-2008, 19:07
  2. Asus 500g knopen aan Asus 500g dlx
    By dolphs in forum Dutch Discussion - Nederlands
    Last Post: 15-03-2007, 08:38
  3. Replies: 2
    Last Post: 07-12-2006, 00:50
