I find another firmware release ,working great.
http://koppel.cz/cdmawifi
http://koppel.cz/cdmawifi/download/1...-CDMA-1.55.trx
SNMPd is in it.
SNMPd is in it.
In the new version the firmware supports up to 32 bandwith rules.
http://koppel.cz/cdmawifi/download/History
Probably this Forum an the czech Forum could work together.
But pleeeaaase in English!!
Yes.
It's our modification of Oleg's firmware to support USB GTRAN modem for CDMA EV-DO which runs on 450MHz. This wireless technology is only in Czech republic.
Wow, it looks like it may help my networking problem, does the VPN allow me access to a usb disk in the router?
Also, is the interface in English?
No. It's only in czech because CDMA is only in czech. USB disk is accessible via FTP.
..that is a political reason..not technical?Originally Posted by engy
Yes. When CDMA and our firmware modification will by widely used, it will by also in english.
Here is the link to source code for this version
http://koppel.cz/cdmawifi/download/1...MA-1.55.tar.gz
is the firmware interface in english?
if not, any english version?
will Oleg's fw ever support gprs/cdma modem?
i think it'll be great to put gprs/cdma modem support into fw.
my plan is to plug my gprs/cdma modem into wl500g/x and put it on my car with a modified power supply.
so i'd got a truely mobile hotspot. anywhere you see my car you can use the hotspot...
aztech adsl router -> asus wl500g w/ 1.9.2.7-5a fw -> linksys wrt54g w/ dd-wrt & hyperwrt as WDS
http://www.ngobrol.com
Unfortunaelly the .cz firmware for wl-500gx contains a ppp not compiled with support for active-filter.
I guess even using iptable I still not able to stop internet since idle time is never reached due to misc incoming packages.
Could it be possible to include ppp filtering in a new firmware or provide a ppp package with support for acrive-filter (I'm interested in outbound keyword).
Please help me or provide me an alternative to be able to ignore incoming packets when dial on demand is used with pppd.
Thanks a lot
So has a CDMA package been developed for Oleg's software?
Can't really try Oleg's as I'm CDMA dependant for the internet.
tanx
in this firmware exist property " use my dialup file"
There are i can get this files, and read about this?
And what is structures of this files?
Hi Everyone,
I was visiting http://koppel.cz/cdmawifi/download/1...f-USB-1.64.trx,
and found out that they have a new soft for WL500g. This soft allows to plug 2 CDMA modem and have internet VIA WIFI. There are 2 models that are supported by this software. AnydataADU-E100H and one more model. I use C-Montech CNU-550. Can anybody help to modify the 1.9.2.7-7f-USB-1.64.trx in a such way that my modem will work.
WL500GX recognizes the modem very well. Here is the log
System Log from My Asus WL500gx, after inserting the CNU-550. C-Montech
Apr 19 17:51:43 kernel: usb.c: USB disconnect on device 01:02.2-2 address 2
Apr 19 17:51:44 nmbd[136]: [2007/04/19 17:51:44, 0] nmbd/nmbd.c:sig_term(65)
Apr 19 17:51:44 nmbd[136]: Got SIGTERM: going down...
Apr 19 17:51:45 USB storage: removed
Apr 19 17:51:45 kernel: Device 08:05 not ready.
Apr 19 17:51:45 kernel: I/O error: dev 08:05, sector 1
Apr 19 17:51:57 kernel: hub.c: new USB device 01:02.0-2, assigned address 2
Apr 19 17:51:57 kernel: Manufacturer: CMOTECH CO., LTD.
Apr 19 17:51:57 kernel: Product: CMOTECH CDMA Technologies
Apr 19 17:51:58 kernel: SerialNumber: Serial Number
Apr 19 17:51:58 kernel: usb.c: USB device 2 (vend/prod 0x16d8/0x5543) is not claimed by any active driver.
Apr 19 17:51:58 kernel: Length = 18
Apr 19 17:51:58 kernel: DescriptorType = 01
Apr 19 17:51:58 kernel: USB version = 2.00
Apr 19 17:51:58 kernel: Vendor:Product = 16d8:5543
Apr 19 17:51:58 kernel: MaxPacketSize0 = 16
Apr 19 17:51:58 kernel: NumConfigurations = 1
Apr 19 17:51:58 kernel: Device version = 0.00
Apr 19 17:51:58 kernel: Device Class:SubClass:Protocol = 02:00:00
Apr 19 17:51:58 kernel: Communications class
Apr 19 17:51:58 kernel: Configuration:
Apr 19 17:51:58 kernel: bLength = 9
Apr 19 17:51:58 kernel: bDescriptorType = 02
Apr 19 17:51:58 kernel: wTotalLength = 005a
Apr 19 17:51:58 kernel: bNumInterfaces = 03
Apr 19 17:51:58 kernel: bConfigurationValue = 01
Apr 19 17:51:58 kernel: iConfiguration = 00
Apr 19 17:51:58 kernel: bmAttributes = 80
Apr 19 17:51:58 kernel: MaxPower = 100mA
Apr 19 17:51:58 kernel: Interface: 0
Apr 19 17:51:58 kernel: Alternate Setting: 0
Apr 19 17:51:58 kernel: bDescriptorType = 04
Apr 19 17:51:58 kernel: bInterfaceNumber = 00
Apr 19 17:51:58 kernel: bAlternateSetting = 00
Apr 19 17:51:58 kernel: bNumEndpoints = 01
Apr 19 17:51:58 kernel: bInterface Class:SubClass:Protocol = 02:02:01
Apr 19 17:51:58 kernel: iInterface = 00
Apr 19 17:51:58 kernel: Endpoint:
Apr 19 17:51:58 kernel: bLength = 7
Apr 19 17:51:58 kernel: bDescriptorType = 05
Apr 19 17:51:58 kernel: bEndpointAddress = 81 (in)
Apr 19 17:51:58 kernel: bmAttributes = 03 (Interrupt)
Apr 19 17:51:58 kernel: wMaxPacketSize = 0010
Apr 19 17:51:58 kernel: bInterval = 20
Apr 19 17:51:58 kernel: Interface: 1
Apr 19 17:51:58 kernel: bInterfaceNumber = 01
Apr 19 17:51:58 kernel: bNumEndpoints = 02
Apr 19 17:51:58 kernel: bInterface Class:SubClass:Protocol = 0a:00:00
Apr 19 17:51:58 kernel: iInterface = 04
Apr 19 17:51:58 kernel: bEndpointAddress = 8a (in)
Apr 19 17:51:58 kernel: bmAttributes = 02 (Bulk)
Apr 19 17:51:58 kernel: wMaxPacketSize = 0040
Apr 19 17:51:58 kernel: bInterval = 00
Apr 19 17:51:58 kernel: bEndpointAddress = 0b (out)
Apr 19 17:51:58 kernel: Interface: 2
Apr 19 17:51:58 kernel: bInterfaceNumber = 02
Apr 19 17:51:58 kernel: bInterface Class:SubClass:Protocol = ff:ff:ff
Apr 19 17:51:58 kernel: bEndpointAddress = 82 (in)
Apr 19 17:51:58 kernel: bEndpointAddress = 05 (out)
I think I need to use this script.
921600
connect '/usr/sbin/chat -s -v "" "AT&F0E0V1S0=0" OK ATD#777 CONNECT'
debug
updetach
crtscts
noipdefault
nodetach
novj
lcp-echo-failure 0
nobsdcomp
novjccomp
nopcomp
noaccomp
noauth
user mobile
modem
usepeerdns
defaultroute
connect-delay 5000
Thanks in Advance.
I think you better ask the person who wrote this firmware. He speaks very good english.
Hi Alien433'
Are you from from Czech republic? That script was written by very smart guy from Czech republic. But I cannot speak czech and cannot find any information on that forum. If you can help to readdress my question?
Thanks in Advance.
Skier
