Originally Posted by
oleg71
Так?__________
Да, так.
Полностью прозрачный - имеется в виду это:
Can Polipo behave as an intercepting proxy?
No.
Interception proxying (sometimes confusingly called ‘‘transparent’’ proxying) is a technique that intercepts client connections at the network layer in order to redirect them at an application layer proxy.
Interception proxying is a fundamentally broken design (see for example this posting and RFC 3143, Section 2.2.2), and will not be supported by Polipo. If you want to use interception proxying in order to avoid manually configuring your clients, please use Netscape's proxy.pac auto-configuration (you don't need a separate web server, as a proxy.pac file can be served by Polipo's internal server). If you want to use interception proxying for any other reason, you're probably doing something wrong.
Именно так указанная конфигурация и будет работать.
