hi, have you done to put inside the firmware with such a mac? i have the same things but i can't put inside. could you explain me how to do? an how to for dummies?
it is important
thanks
can i put also a huawei e180?
Hi.
I'd like to set up my router to get a ppp connection on demand (when a client try to browse the web, for instance).
I have an Asus WL-500g Premium V1 with Koppel firmware (version 1.9.2.7-10-USB-1.71) and an Huawei E220.
The problem are:
- I don't know how to edit a file and to let that the modified version is persistent : I tryed with
but unsuccessfullyCode:flashfs save && flashfs commit && flashfs enable && reboot- I don't know exactly which files I have to edit: I think it's /tmp/ppp/gprs/gprs, but I'm not sure
When I'll find the file and the way to save it, I think it would be enough to add
to get a connection on demand and an auto-disconnect if the line is idle.Code:demand idle 600
Every suggestion is wellcome.
Thanks.
it is important
thanks
Hi.
i published an howto on my blog, but it's in Italian.
Let me know if you need help.
posso avere la tua mail per contattarti? ti mando la mia tronodaniele(chiocciola)gmail.com
zeromega(chiocciola)libero.it
