Results 1 to 2 of 2
Thread: External disk problem
    i have problem with USB disk access. I bought new WD My book mirror edition and connected to router. I was able to read files only. Then I formated disk as Ext3 and now it's impossible to see disk in settings (Status & Log / USB). FTP/Samba doesn't work as well. When I connect disk to pc there is no problem with access or read/write operations. I tried also Ext2 with the same result. The router uses original firmware 2.0.0.6. Where could be problem?
    The Netherlands - Eindhoven
    EXT2 and FAT32 is the only supported file system for original firmware (on wich you can write).
    I run olges fw and have no problems with a mybook 1TB disk (formatted in EXT3).
    so it might be a firmware limitation here.
  1. Problem with NTFS disk
    By Antiloop in forum WL-500gP Q&A
    Last Post: 07-08-2011, 05:36
  2. Problem with external hard drive
    By Chris_phorms in forum WL-500gP Q&A
    Last Post: 12-03-2009, 10:04
  3. Replies: 6
    Last Post: 07-10-2008, 16:58
  4. Replies: 11
    Last Post: 25-03-2008, 10:54
