No. Time Source Destination Protocol Info
74 26.952047 xxx.xx.x.x 192.168.1.10 TCP 49962 > 82 [ACK] Seq=909 Ack=582 Win=63659 Len=0
Frame 74 (54 bytes on wire, 54 bytes captured)
Ethernet II, Src: 00:11:2f:73:xx:xx, Dst: 00:12:79:46:xx:xx
Internet Protocol, Src Addr: xxx.xx.x.x (xxx.xx.x.x), Dst Addr: 192.168.1.10 (192.168.1.10)
Transmission Control Protocol, Src Port: 49962 (49962), Dst Port: 82 (82), Seq: 909, Ack: 582, Len: 0
Source port: 49962 (49962)
Destination port: 82 (82)
Sequence number: 909 (relative sequence number)
Acknowledgement number: 582 (relative ack number)
Header length: 20 bytes
Flags: 0x0010 (ACK)
Window size: 63659
Checksum: 0xd4f1 (correct)
SEQ/ACK analysis
This is an ACK to the segment in frame: 72
The RTT to ACK the segment was: 0.075595000 seconds
75 27.131302 xxx.xx.x.x 192.168.1.10 TCP 49962 > 82 [PSH, ACK] Seq=909 Ack=596 Win=63645 Len=1338
Frame 75 (1392 bytes on wire, 1392 bytes captured)
Transmission Control Protocol, Src Port: 49962 (49962), Dst Port: 82 (82), Seq: 909, Ack: 596, Len: 1338
Next sequence number: 2247 (relative sequence number)
Acknowledgement number: 596 (relative ack number)
Flags: 0x0018 (PSH, ACK)
Window size: 63645
Checksum: 0xcbc8 (correct)
SEQ/ACK analysis
This is an ACK to the segment in frame: 73
The RTT to ACK the segment was: 0.220716000 seconds
Data (1338 bytes)
76 27.336533 192.168.1.10 xxx.xx.x.x TCP 82 > 49962 [ACK] Seq=596 Ack=2247 Win=32768 Len=0
Frame 76 (54 bytes on wire, 54 bytes captured)
Ethernet II, Src: 00:12:79:46:xx:xx, Dst: 00:11:2f:73:xx:xx
Internet Protocol, Src Addr: 192.168.1.10 (192.168.1.10), Dst Addr: xxx.xx.x.x (xxx.xx.x.x)
Transmission Control Protocol, Src Port: 82 (82), Dst Port: 49962 (49962), Seq: 596, Ack: 2247, Len: 0
Source port: 82 (82)
Destination port: 49962 (49962)
Sequence number: 596 (relative sequence number)
Acknowledgement number: 2247 (relative ack number)
Flags: 0x0010 (ACK)
Window size: 32768
Checksum: 0x4855 (correct)
SEQ/ACK analysis
This is an ACK to the segment in frame: 75
The RTT to ACK the segment was: 0.205231000 seconds
77 30.721010 192.168.1.10 xxx.xx.x.x TCP 82 > 49962 [PSH, ACK] Seq=596 Ack=2247 Win=32768 Len=12
Frame 77 (66 bytes on wire, 66 bytes captured)
Transmission Control Protocol, Src Port: 82 (82), Dst Port: 49962 (49962), Seq: 596, Ack: 2247, Len: 12
Next sequence number: 608 (relative sequence number)
Window size: 32768
Checksum: 0x233f (correct)
Data (12 bytes)
0000 0b 00 01 00 00 00 13 01 e5 00 21 00 ..........!.
78 30.723469 192.168.1.10 xxx.xx.x.x TCP 82 > 49962 [PSH, ACK] Seq=608 Ack=2247 Win=32768 Len=12
Frame 78 (66 bytes on wire, 66 bytes captured)
Transmission Control Protocol, Src Port: 82 (82), Dst Port: 49962 (49962), Seq: 608, Ack: 2247, Len: 12
Sequence number: 608 (relative sequence number)
Next sequence number: 620 (relative sequence number)
Window size: 32768
Checksum: 0x1933 (correct)
Data (12 bytes)
0000 0b 00 01 00 00 00 13 01 e0 00 30 00 ..........0.
79 30.789783 xxx.xx.x.x 192.168.1.10 TCP 49962 > 82 [ACK] Seq=2247 Ack=620 Win=63621 Len=0
Frame 79 (54 bytes on wire, 54 bytes captured)
Transmission Control Protocol, Src Port: 49962 (49962), Dst Port: 82 (82), Seq: 2247, Ack: 620, Len: 0
Sequence number: 2247 (relative sequence number)
Acknowledgement number: 620 (relative ack number)
Flags: 0x0010 (ACK)
Window size: 63621
Checksum: 0xcfb7 (correct)
SEQ/ACK analysis
This is an ACK to the segment in frame: 78
The RTT to ACK the segment was: 0.066314000 seconds
80 31.030234 xxx.xx.x.x 192.168.1.10 TCP 49962 > 82 [PSH, ACK] Seq=2247 Ack=620 Win=63621 Len=1072
Frame 80 (1126 bytes on wire, 1126 bytes captured)
Transmission Control Protocol, Src Port: 49962 (49962), Dst Port: 82 (82), Seq: 2247, Ack: 620, Len: 1072
Next sequence number: 3319 (relative sequence number)
Window size: 63621
Checksum: 0xbda1 (correct)
Data (1072 bytes)
81 31.186223 192.168.1.10 xxx.xx.x.x TCP 82 > 49962 [ACK] Seq=620 Ack=3319 Win=31696 Len=0
Frame 81 (54 bytes on wire, 54 bytes captured)
Transmission Control Protocol, Src Port: 82 (82), Dst Port: 49962 (49962), Seq: 620, Ack: 3319, Len: 0
Sequence number: 620 (relative sequence number)
Acknowledgement number: 3319 (relative ack number)
Flags: 0x0010 (ACK)
Window size: 31696
Checksum: 0x483d (correct)
SEQ/ACK analysis
This is an ACK to the segment in frame: 80
The RTT to ACK the segment was: 0.155989000 seconds
