yes it is already included in the custom firmware (1.7.5.9cr5 for example)
[root@WL500G root]$ ether-wake
Specify the Ethernet address as 00:11:22:33:44:55.
i've tested this too, and it works. it flawlessy turns on my nForce2 powered pc
Hi All,
Does anyone have ether-wake (www.scyld.com/wakeonlan.html) compiled for the ASUS wl500? Is there someone kind enough to do it for me?
Thank you very much in advance,
ROliveira
Thanks a lot!
ROliveira
Has anyone compiled a wake on LAN utility? My motherboard has that option and I would like to be able to turn it on from the router. I found some Linux tools here. Maybe someone would like to compile?
Unless someone is compiling perl of course.. That would be even better! Is there a reason why that hasn't been done yet? Wouldn't perl be great to have on there?
S.
Search gives me this: http://wl500g.info/showthread.php?t=...light=wake+LAN
it's even already built-in to the latest custom firmwares (current 1.9.2.7-4)
[root@WL500gx root]$ ether-wake
Very sorry! Officialy kicking my self on the leg!
S.
sorry for asking once more: Could someone please explain step-by-step how to wake up a pc from WAN-side through the WL500g with the latest firmware installed? Thanks!
fraho
To wake machine with mac adress: 00:11:22:33:44:55
Telnet to router and type:
You can also use "Hidden admin page".Code:ether-wake 00:11:22:33:44:55
S.
Thanks for your quick answer! Anyway, what can I do if I'm behind a firewall and the telnet-port can't be used? Isn't it possible to create a graphical WOL-Page within the web-frontend (I know, I shouldn't have remote administration enabled but who cares.....) so that any opened port could be used for WOL as well as for all other things?
fraho
How about SSH? That's what I use..
S.
What port does ssh use?
By the way, I've never used the "hidden admin page", how do I get there?
fraho
22.
Faq.
S.
o.k, just before I start flashing a new firmware on a running system :
Will this "hidden Admin page" let me send a wake-on-lan-command via Web-Frontend (via port 80)?
fraho
I can't test it for you right now, but I don't see how it shoult not work. So yes. You should be able to wake-on-lan from the web.
S.
