Cпасибо!
Залил новую прошивку, сбросил все настройки, сбросил кеш, включил WAN - вот что получилось. Ничего хорошего вроде, сейчас вот переткнул WAN обратно в dlink - заработал мгновенно. Есть идеи?
Jan 1 00:00:05 syslogd started: BusyBox v1.1.3
Jan 1 00:00:05 kernel: klogd started: BusyBox v1.1.3 (2009.02.22-14:37+0000)
Jan 1 00:00:05 kernel: CPU revision is: 00029029
Jan 1 00:00:05 kernel: Primary instruction cache 16kb, linesize 16 bytes (4 ways)
Jan 1 00:00:05 kernel: Primary data cache 16kb, linesize 16 bytes (2 ways)
Jan 1 00:00:05 kernel: Linux version 2.4.20 (root@localhost) (gcc version 3.2.3 with Broadcom modifications) #34 Wed Feb 25 22:34:05 MSK 2009
Jan 1 00:00:05 kernel: Setting the PFC to its default value
Jan 1 00:00:05 kernel: Determined physical RAM map:
Jan 1 00:00:05 kernel: memory: 02000000 @ 00000000 (usable)
Jan 1 00:00:05 kernel: On node 0 totalpages: 8192
Jan 1 00:00:05 kernel: zone(0): 8192 pages.
Jan 1 00:00:05 kernel: zone(1): 0 pages.
Jan 1 00:00:05 kernel: zone(2): 0 pages.
Jan 1 00:00:05 kernel: Kernel command line: root=/dev/mtdblock2 noinitrd init=/linuxrc console=ttyS0,115200
Jan 1 00:00:05 kernel: CPU: BCM5354 rev 2 pkg 0 at 240 MHz
Jan 1 00:00:05 kernel: Calibrating delay loop... 237.56 BogoMIPS
Jan 1 00:00:05 kernel: Memory: 30084k/32768k available (1869k kernel code, 2684k reserved, 136k data, 72k init, 0k highmem)
Jan 1 00:00:05 kernel: Dentry cache hash table entries: 4096 (order: 3, 32768 bytes)
Jan 1 00:00:05 kernel: Inode cache hash table entries: 2048 (order: 2, 16384 bytes)
Jan 1 00:00:05 kernel: Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Jan 1 00:00:05 kernel: Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes)
Jan 1 00:00:05 kernel: Page-cache hash table entries: 8192 (order: 3, 32768 bytes)
Jan 1 00:00:05 kernel: Checking for 'wait' instruction... unavailable.
Jan 1 00:00:05 kernel: POSIX conformance testing by UNIFIX
Jan 1 00:00:05 kernel: PCI: no core
Jan 1 00:00:05 kernel: PCI: Fixing up bus 0
Jan 1 00:00:05 kernel: Linux NET4.0 for Linux 2.4
Jan 1 00:00:05 kernel: Based upon Swansea University Computer Society NET3.039
Jan 1 00:00:05 kernel: Initializing RT netlink socket
Jan 1 00:00:05 kernel: Starting kswapd
Jan 1 00:00:05 kernel: Journalled Block Device driver loaded
Jan 1 00:00:05 kernel: devfs: v1.12c (20020818) Richard Gooch (rgooch@atnf.csiro.au)
Jan 1 00:00:05 kernel: devfs: boot_options: 0x1
Jan 1 00:00:05 kernel: NTFS driver v1.1.22 [Flags: R/O]
Jan 1 00:00:05 kernel: pty: 256 Unix98 ptys configured
Jan 1 00:00:05 kernel: Serial driver version 5.05c (2001-07-08) with MANY_PORTS SHARE_IRQ SERIAL_PCI enabled
Jan 1 00:00:05 kernel: ttyS00 at 0xb8000300 (irq = 3) is a 16550A
Jan 1 00:00:05 kernel: ttyS01 at 0xb8000400 (irq = 3) is a 16550A
Jan 1 00:00:05 kernel: HDLC line discipline: version $Revision$, maxframe=4096
Jan 1 00:00:05 kernel: N_HDLC line discipline registered.
Jan 1 00:00:05 kernel: loop: loaded (max 8 devices)
Jan 1 00:00:05 kernel: PPP generic driver version 2.4.2
Jan 1 00:00:05 kernel: PPP Deflate Compression module registered
Jan 1 00:00:05 kernel: PPP BSD Compression module registered
Jan 1 00:00:05 kernel: MPPE/MPPC encryption/compression module registered
Jan 1 00:00:05 kernel: PPPoL2TP kernel driver, V0.13 (oleg@cs.msu.su)
Jan 1 00:00:05 kernel: Amd/Fujitsu Extended Query Table v1.1 at 0x0040
Jan 1 00:00:05 kernel: Flash Id: Vendor: 0x00c2 Device: 0x00cb
Jan 1 00:00:05 kernel: number of CFI chips: 1
Jan 1 00:00:05 kernel: Flash device: 0x800000 at 0x1c000000
Jan 1 00:00:05 kernel: Physically mapped flash: squashfs filesystem found at block 785
Jan 1 00:00:05 kernel: Creating 5 MTD partitions on "Physically mapped flash":
Jan 1 00:00:05 kernel: 0x00000000-0x00020000 : "boot"
Jan 1 00:00:05 kernel: 0x00020000-0x007f0000 : "linux"
Jan 1 00:00:05 kernel: 0x000c4714-0x007f0000 : "rootfs"
Jan 1 00:00:05 kernel: 0x007f0000-0x00800000 : "nvram"
Jan 1 00:00:05 kernel: 0x003c0000-0x007f0000 : "flashfs"
Jan 1 00:00:05 kernel: sflash: found no supported devices
Jan 1 00:00:05 kernel: NET4: Linux TCP/IP 1.0 for NET4.0
Jan 1 00:00:05 kernel: IP Protocols: ICMP, UDP, TCP, IGMP
Jan 1 00:00:05 kernel: IP: routing cache hash table of 512 buckets, 4Kbytes
Jan 1 00:00:05 kernel: TCP: Hash tables configured (established 2048 bind 4096)
Jan 1 00:00:05 kernel: Linux IP multicast router 0.06 plus PIM-SM
Jan 1 00:00:05 kernel: ip_conntrack version 2.1 (256 buckets, 2048 max) - 352 bytes per conntrack
Jan 1 00:00:05 kernel: ip_conntrack_pptp version 1.9 loaded
Jan 1 00:00:05 kernel: ip_nat_pptp version 1.5 loaded
Jan 1 00:00:05 kernel: ip_tables: (C) 2000-2002 Netfilter core team
Jan 1 00:00:05 kernel: ipt_time loading
Jan 1 00:00:05 kernel: NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
Jan 1 00:00:05 kernel: IPv6 v0.8 for NET4.0
Jan 1 00:00:05 kernel: IPv6 over IPv4 tunneling driver
Jan 1 00:00:05 kernel: NET4: Ethernet Bridge 008 for NET4.0
Jan 1 00:00:05 kernel: 802.1Q VLAN Support v1.7 Ben Greear <greearb@candelatech.com>
Jan 1 00:00:05 kernel: All bugs added by David S. Miller <davem@redhat.com>
Jan 1 00:00:05 kernel: FAT: bogus logical sector size 46080
Jan 1 00:00:05 kernel: NTFS: Unable to set blocksize 512.
Jan 1 00:00:05 kernel: VFS: Mounted root (squashfs filesystem) readonly.
Jan 1 00:00:05 kernel: Mounted devfs on /dev
Jan 1 00:00:05 kernel: Freeing unused kernel memory: 72k freed
Jan 1 00:00:05 kernel: Algorithmics/MIPS FPU Emulator v1.5
Jan 1 00:00:05 kernel: eth0: Broadcom BCM47xx 10/100 Mbps Ethernet Controller 4.150.10.16
Jan 1 00:00:05 kernel: eth1: Broadcom BCM4318 802.11 Wireless Controller 4.150.10.29
Jan 1 00:00:05 kernel: device eth0 entered promiscuous mode
Jan 1 00:00:05 kernel: device vlan0 entered promiscuous mode
Jan 1 00:00:05 kernel: device eth1 entered promiscuous mode
Jan 1 00:00:05 kernel: br0: port 2(eth1) entering listening state
Jan 1 00:00:05 kernel: br0: port 1(vlan0) entering listening state
Jan 1 00:00:05 kernel: br0: port 2(eth1) entering learning state
Jan 1 00:00:05 kernel: br0: port 1(vlan0) entering learning state
Jan 1 00:00:05 kernel: br0: port 2(eth1) entering forwarding state
Jan 1 00:00:05 kernel: br0: topology change detected, propagating
Jan 1 00:00:05 kernel: br0: port 1(vlan0) entering forwarding state
Jan 1 00:00:05 dnsmasq[73]: started, version 2.22 cachesize 150
Jan 1 00:00:05 dnsmasq[73]: DHCP, IP range 192.168.1.2 -- 192.168.1.254, lease time 24h
Jan 1 00:00:05 dnsmasq[73]: DHCP, /tmp/dnsmasq.log will be written every 8h
Jan 1 00:00:05 dnsmasq[73]: read /etc/hosts - 4 addresses
Jan 1 00:00:05 dnsmasq[73]: reading /tmp/resolv.conf
Jan 1 00:00:06 kernel: usb.c: registered new driver usbdevfs
Jan 1 00:00:06 kernel: usb.c: registered new driver hub
Jan 1 00:00:06 kernel: usb-ohci.c: USB OHCI at membase 0xb8003000, IRQ 6
Jan 1 00:00:06 kernel: usb-ohci.c: usb-00:03.0, PCI device 14e4:471a
Jan 1 00:00:06 kernel: usb.c: new USB bus registered, assigned bus number 1
Jan 1 00:00:06 kernel: hub.c: USB hub found
Jan 1 00:00:06 kernel: hub.c: 2 ports detected
Jan 1 00:00:06 kernel: ehci_hcd 00:03.1: PCI device 14e4:471a
Jan 1 00:00:06 kernel: ehci_hcd 00:03.1: irq 6, pci mem b8003800
Jan 1 00:00:06 kernel: usb.c: new USB bus registered, assigned bus number 2
Jan 1 00:00:06 kernel: ehci_hcd 00:03.1: illegal capability!
Jan 1 00:00:06 kernel: ECHI PCI device 471a14e4 found.
Jan 1 00:00:06 kernel: PCI: 00:03.1 PCI cache line size set incorrectly (0 bytes) by BIOS/FW, correcting to 32
Jan 1 00:00:06 kernel: ehci_hcd 00:03.1: USB 0.0 enabled, EHCI 1.00, driver 2003-Dec-29/2.4
Jan 1 00:00:06 kernel: usb.c: registered new driver usblp
Jan 1 00:00:06 kernel: printer.c: v0.13: USB Printer Device Class driver
Jan 1 00:00:07 kernel: hub.c: new USB device 00:03.1-1, assigned address 2
Jan 1 00:00:07 kernel: hub.c: USB hub found
Jan 1 00:00:07 kernel: hub.c: 2 ports detected
Jan 1 00:00:08 kernel: usb.c: registered new driver audio
Jan 1 00:00:08 kernel: audio.c: v1.0.0:USB Audio Class driver
Jan 1 00:00:08 kernel: Linux video capture interface: v1.00
Jan 1 00:00:08 kernel: SCSI subsystem driver Revision: 1.00
Jan 1 00:00:08 kernel: Initializing USB Mass Storage driver...
Jan 1 00:00:08 kernel: usb.c: registered new driver usb-storage
Jan 1 00:00:08 kernel: USB Mass Storage support registered.
Jan 1 00:00:09 udhcpc[98]: udhcpc (v0.9.9-pre) started
Jan 1 00:00:09 dnsmasq[73]: read /etc/hosts - 4 addresses
Jan 1 00:00:09 dnsmasq[73]: reading /tmp/resolv.conf
Jan 1 00:00:09 dhcp client: deconfig: lease is lost
Jan 1 00:04:18 dnsmasq[73]: DHCPDISCOVER(br0) 00:23:6c:34:fd:92
Jan 1 00:04:18 dnsmasq[73]: DHCPOFFER(br0) 192.168.1.134 00:23:6c:34:fd:92
Jan 1 00:04:19 dnsmasq[73]: DHCPREQUEST(br0) 192.168.1.134 00:23:6c:34:fd:92
Jan 1 00:04:19 dnsmasq[73]: DHCPACK(br0) 192.168.1.134 00:23:6c:34:fd:92 iPhone
Jan 1 00:08:03 wan: connected manually
Jan 1 00:08:03 udhcpc[98]: Performing a DHCP renew
Jan 1 00:12:35 wan: connected manually
Jan 1 00:12:35 udhcpc[98]: Performing a DHCP renew
