I've been testing with latest teddy bear's tomato mod and Oleg mod to and for. I like the tomato mod for the following:
1) easier to support Chinese filenames (codepage 936) for Samba
2) more stable support of USB devices
3) better and easier to use/understand interface
4) support of wireless ethernet bridge mode
However, the tomato does not fuse.o and hence ntfs-3g. the current ntfs driver comes with tomato cannot display ntfs partitions properly.
the oleg is good for it's support for twonkymedia and ntfs-3g.
byzhang,
Download samba_extra_codepages.tar.gz file from here, and follow instructions in the included readme document to install additional Samba codepages.
Thanks for the usb mod teddy_bear !
I have an asus 520gu and win xp sp3.
Connected printer to router usb port and the printer name appeared in tomato usb section.
However when I try to print, windows tells me "the printer is offline" or "document failed to print" .
Any suggestions to make it work ?
Thanks!
does anyone have links to teddy bear's mod for the 520gu tomato firmware? the linksys forum is down and I don't know where to get it.
thanks teddy bear!
which firmware do i download for my asus 520gu? Broadcom BCM5354 chip rev 3
nevermind, got it. installed the mipsr1 lite
teddy bear: what happened to the file sharing settings? all i see is the FTP option.
movingincircles,
You installed kernel 2.6 -based build. Because of a kernel size, the Lite version (which doesn't include Samba) is the only one that will fit on 4MB flash.
To get full file sharing support, install "Ext" or "VPN" build based on kernel 2.4.37 from http://sourceforge.net/projects/tomatousb/files/K24 folder.
teddy_bear said: "You installed kernel 2.6 -based build. Because of a kernel size, the Lite version (which doesn't include Samba) is the only one that will fit on 4MB flash.
To get full file sharing support, install "Ext" or "VPN" build based on kernel 2.4.37 from http://sourceforge.net/projects/tomatousb/files/K24 folder."
Does this mean that all future releases, or at least, all releases using the 2.6 kernel will no longer support USB file sharing on routers with only 4 MB?
I am the proud owner of a new ASUS WL-520GU that I bought specifically because of Tomato's QoS and teddy_bear's USB support. They should be sending you a percentage of their earnings.
By the way, THANK YOU teddy_bear!
Yes, 4MB is not enough for everything -(... No space for Samba.
If you really want Linux 2.6 on your 4MB router for any reason, use Lite build - you can install Optware Samba on your USB drive if needed. Otherwise stick with kernel 2.4-based builds - they are not going away...
