Results 1 to 4 of 4
Thread: Installing toolchain - please help
    May 2004
    Hello, all
    While trying to deploy environment for building some binaries for wl-500g I ran over some problems. Could any kind soul help me in building environment?
    I use Colinux 0.6.2 as host system. I've managed to install it and make it running, downloaded ASUS GPL distribution on separate partition and untarred it. Then, according to ASUS README file created sym link to
    /opt/brcm/hndtools-mipsel-uclibc/bin pointing to /opt/broadcom/opt/brcm/hndtools-mipsel-uclibc-3.2.3/bin/
    and added /opt/brcm/hndtools-mipsel-uclibc/bin to PATH
    After then while trying to compile "Hello world" program I got
    colinux:~# mipsel-uclibc-gcc hello.c
    /opt/brcm/hndtools-mipsel-linux-3.2.3/lib/gcc-lib/mipsel-linux/3.2.3/../../../../mipsel-linux/bin/ld: /lib/libc.so.6: version `GLIBC_2.3' not found (required by /opt/brcm/hndtools-mipsel-linux-3.2.3/lib/gcc-lib/mipsel-linux/3.2.3/../../../../mipsel-linux/bin/ld)
    I definetely messed some steps , but what steps ?
    I am not a Linux man, and probably missed some specifics like apt-get or smthg?
    Please help,
    and thanks in advance.
    Roofcat
    PS. I will readily create step-by-step instructions based on mine expirience.
    You do not need to create symbolic link, just move toolchain as is, i.e. it should be /opt/brcm/...
    May 2004
    Ok, tried it this way - same story.
    I've got two suspects:
    1) I've noticed that in
    hndtools-mipsel-linux-3.2.3 is mentioned but I added hndtools-mipsel-uclibc/bin to my PATH. Does it matter?
    2) Colinux 0.6.2 use 2.6 kernel
    colinux:~# uname -a
    Linux colinux 2.6.10-co-0.6.2 #5 Sat Feb 5 10:19:16 IST 2005 i686 unknown
    Should I use earlier version with 2.4 kernel instead?
    Regards,
    Roofcat
    your GLIBC is outdated - you may want to try other colinux distribution... This is not toolchain related.
  1. Tweaking the toolchain
    By unaiur in forum WL-500g Custom Development
    Last Post: 16-09-2005, 20:23
  2. wl500/wlhdd toolchain on gentoo
    By ray in forum WL-500g Q&A
    Last Post: 09-08-2005, 01:44
  3. custom glib based toolchain
    By ja.ro in forum WL-500g Custom Development
    Last Post: 10-04-2005, 01:46
  4. Broadcom toolchain diff's
    By mctiew in forum WL-500g Custom Development
    Last Post: 02-03-2005, 11:24
  5. toolchain question (c++ ?)
    By QuarterPounder in forum WL-500g Custom Development
    Last Post: 28-05-2004, 14:57
