Results 1 to 9 of 9
Thread: c compiler question olegs firmware
    sorry for asking this implicitness but i want to know if there is a possibility to compile a c sourcefile like with gcc -o ... on olegs fimware.
    I've checked ipkg list and installed for a kind of gcc pkg but i'am not sure enough with this stuff...
    thanks in advance and kind regards,
    zwieback
    Feb 2007
    for the on-router compilation install optware-devel package. It's a meta-package which includes the most of needed things.
    al37919,
    I've installed the optware but i didn't find the correct compiler. Could you specify me the correct compiler pls ?
    Feb 2007
    I don't think I understand your question. To compile typical program you have to execute:
    PHP Code:
    ./configure
    make
    make install
    More details usually can be found in the documentation to the sources. All the stuff needed to perform this is installed by the optware-devel package. It is better if you clarify what do you mean under "correct compiler".
    sorry, thats my mistake.
    i want to compile the following like that:
    ----- newfile.c-----
    #include <stdio.h>
    void main()
    printf("hello world!\n");
    i want to get an executable file. I've done it with gcc on our SUN machines, but i haven't found something adequate on the wlhdd with olegs firmware.
    I've looked at make but i think this wouldn't be ok for this.
    But i believe there has to be something for this...
    best regards
    Feb 2007
    PHP Code:
    root@wl500g,~> gcc 1.c
    1.c
    In function ‘main’:
    1.c:5warning: return type of ‘main’ is not ‘int’
    root
    @wl500g,~> ./a.out
    hello world
    root@wl500g,~>
    so, you see --- it is possible
  1. How-to: Recompile Oleg's firmware
    By moszinet in forum WL-500gP Tutorials
    Last Post: 08-08-2008, 19:48
  2. libmcrypt on Oleg's firmware ?
    By simistef in forum WL-500gP Q&A
    Last Post: 14-03-2008, 10:31
  3. Flashing Oleg's Firmware in WL HDD
    Last Post: 21-10-2004, 14:55
