Results 1 to 2 of 2
Thread: Asus WL-700gE chyba problem z dyskiem
    Witam
    mam chyba problem z dyskiem Smart zwraca log o takiej tresci :
    Device: HDT722525DLAT80 Supports ATA Version 7
    Drive supports S.M.A.R.T. and is enabled
    Check S.M.A.R.T. Passed.
    General Smart Values:
    Off-line data collection status: (0x00) Offline data collection activity was
    never started
    Self-test execution status: ( 0) The previous self-test routine completed
    without error or no self-test has ever
    been run
    Total time to complete off-line
    data collection: (4797) Seconds
    Capabilities: (0x5b)SMART EXECUTE OFF-LINE IMMEDIATE
    Automatic timer ON/OFF support
    Suspend Offline Collection upon new
    command
    Offline surface scan supported
    Self-test supported
    Smart Capablilities: (0x0003) Saves SMART data before entering
    power-saving mode
    Supports SMART auto save timer
    Error logging capability: (0x01) Error logging supported
    Short self-test routine
    recommended polling time: ( 1) Minutes
    Extended self-test routine
    recommended polling time: ( 80) Minutes
    Vendor Specific SMART Attributes with Thresholds:
    Revision Number: 16
    Attribute Flag Value Worst Threshold Raw Value
    ( 1)Raw Read Error Rate 0x000b 100 100 016 0
    ( 2)Throughput Performance 0x0005 100 100 050 0
    ( 3)Spin Up Time 0x0007 144 144 024 19660983
    ( 4)Start Stop Count 0x0012 100 100 000 112
    ( 5)Reallocated Sector Ct 0x0033 100 100 005 0
    ( 7)Seek Error Rate 0x000b 100 100 067 0
    ( 8)Seek Time Preformance 0x0005 100 100 020 0
    ( 9)Power On Hours 0x0012 100 100 000 3009
    ( 10)Spin Retry Count 0x0013 100 100 060 0
    ( 12)Power Cycle Count 0x0032 100 100 000 112
    (192)Power-Off Retract Count 0x0032 100 100 050 229
    (193)Load Cycle Count 0x0012 100 100 050 229
    (194)Temperature 0x0002 112 112 000 1114169
    (196)Reallocated Event Count 0x0032 100 100 000 0
    (197)Current Pending Sector 0x0022 100 100 000 0
    (198)Offline Uncorrectable 0x0008 100 100 000 0
    (199)UDMA CRC Error Count 0x000a 200 200 000 0
    SMART Error Log:
    SMART Error Logging Version: 1
    Error Log Data Structure Pointer: 02
    ATA Error Count: 2
    Non-Fatal Count: 0
    Error Log Structure 1:
    DCR FR SC SN CL SH D/H CR Timestamp
    02 a1 00 00 00 00 a0 fe 26
    02 a2 01 00 00 0c a0 fe 26
    02 a2 01 01 00 0c a0 fe 26
    02 a2 01 00 00 0e a0 fe 26
    00 40 01 00 00 ee ef 51 0
    Error condition: 0 Error State: 3
    Number of Hours in Drive Life: 0 (life of the drive in hours)
    Error Log Structure 2:
    04 a2 01 00 00 00 ef fe 29
    04 a2 01 01 00 00 a0 fe 29
    02 a1 00 00 00 00 a0 fe 29
    02 a2 01 00 00 0f a0 fe 29
    00 40 01 00 00 ef ef 51 0
    fdisk twierdzi ze jest blad w tablicy partycji i jak zapisze zmiany to go usunie. Po zapisaniu zmian i restarcie system sie nawet nie podniosl. Musialem flashowac routerek. Wystartowal ale problem nadal wystepuje.
    Dodam ze nadal moge zapisywac i odczytywac pliki na dysku, tylko jak dlugo
    Aug 2008
    Poland, Bia³a Podlaska
    Dysk Ci pad³, musisz go wymieniæ.
  1. ASUS WL 700gE und Routercontrol
    By joe12345 in forum German Discussion - Deutsch (DE)
    Last Post: 29-07-2008, 19:47
  2. ASUS WL-500gP + USB HDD problem
    By nsec in forum WL-500gP Tutorials
    Last Post: 21-04-2008, 07:04
  3. Asus + Zadacom default gateway problem
    By Anttu in forum WL-500gP Q&A
    Last Post: 29-02-2008, 06:35
  4. asus wl-500g Deluxe firmware flash problem
    By kontra in forum WL-500g Q&A
    Last Post: 23-01-2008, 11:01
  5. WL-500gP and Asus support experience
    Last Post: 03-12-2006, 12:59
