Results 1 to 7 of 7
Thread: saving firmware
    Feb 2005
    Germany - Cologne
    saving firmware
    hi,
    i want to test an older firmware but i have made several changes (samba config etc) in the current one.
    am i able to save the whole firmware to my harddisk or usb stick?
    newbie question i know - but a search in the forum returned no reults :-/
    tia
    mod
    Dec 2004
    the netherlands
    You cannot save the firmware. You don't have to either. You can download the firmware from here or from the asus website, depending on what version you have.
    However, you should be able to save the settings, but I don't know if that will save manual made settings as well.
    But of course you have documented all settings made manually so redoing won't be a problem
    Feb 2005
    Germany - Cologne
    documented - sure
    sure i wrote down everything
    thanks for the help
    Sep 2004
    Austria
    Not quite true - AFAIK you can get the combination of kernel and rootfs from /dev/mtdblock/1 and a tool to put this into a trx file is also available somewhere (I thinks its in the GPL source tarball from asus).
    Quote Originally Posted by modnet25
    hi,
    tia
    mod
    If you mean saving flashfs - then you could type flashfs save and then copy /tmp/flashfs.tar.gz to usb stick. Also, keep in mind, that even after firmware upgrade flashfs is still there - it's just disabled - type flashfs enable and reboot your router.
    Feb 2005
    Germany - Cologne
    ok thanks
    thanks...but the question is out of date :-/
    is it a normal behaviour that all settings er reseted when unplugging the powercable of my router?
    No, unless you forget to press Finish.
  1. saving the WEP settings
    By Sprinjee in forum WL-500g Q&A
    Last Post: 28-03-2006, 22:31
  2. Daylight saving time problem
    By engy in forum WL-500g Q&A
    Last Post: 03-04-2005, 17:29
  3. Access denied on saving files
    By RKT in forum WL-HDD Q&A
    Last Post: 17-03-2005, 23:25
