Results 1 to 7 of 7
Thread: Firmware 1.9.2.7-3c from Oleg and 1.2.3.2 from ASUS for WLHDD, some features...
    Feb 2005
    I try Firmware 1.2.3.2 (and some early) from ASUS, and find some cool features:
    1. Dual USB-storage mode - Auto sharing and auto copy to HDD
    2. Web-interface for administration have pages for share some folders in Samba and FTP, set users access rights, format and check disks.
    3. Shutdown page for safe shutdown
    How this functionality can be added to 1.9.2.7-3c sources from ASUS GPL for WLHDD ?
    Oleg, do you plan to extend functionality with WLHDD specific functions? Becouse 1.9.2.7 was developed by ASUS without supporting WLHDD, in your patch to 1.9.2.7-3c added manually only suport for compilation for WLHDD...
    And question about hardware: can I modify actions on press BOX button to custom (to run script on 1,2,3 short presses, for example to ON/OFF WiFi, copy from USB-Storage to HDD, e.t.c.), where I can find this in sources ??
    Quote Originally Posted by undead
    Well, you need to implement this. At the moment only basic things are added to the 1.9.2.7-3c, I was in hope that someone owning wl-hdd could take care of adding wl-hdd features...
    Yes, but I've no much time, as well I do not have wl-hdd.
    Sure, it's totally software driven.
    Feb 2005
    I will be try to do this, if have time...
    I already compiled from 1.9.2.7-3c sources (add on your site "make lzma" in prepare compilation steps for 1.9.2.7-3c) with custom configuration of busybox and kernel (enable support of more tools in busybox and drivers in kernel for some devices and HDD) and planing to move Firmware files to HDD, where I will experementing with them, may be I add some stuff...
    I buy WLHDD 2 wheek ago in Moscow, and discover that this is more than I expect - with custom Firmware and many tools - this is a "small server" (But CPU is not so faster and only 16Mb of memory)... I am live in Russia in Saint-Petersburgh and plan move work to Moscow, we may talk about WLHDD (I can help possibly with testing e.t.c.) in Russian by mail or private.
    Who know where source for box button placed (path in src/router/...) ???
    Sure, this should be done in the kernel target.
    ok.
    In the 1.9.2.7-3c this is in the rc/watchdog.c
    Feb 2005
    Ok, sorry, I am try first before compilation only "make" without "make kernel" in patch folder , and see error with "lzma not found...", and then use "make lzma", then "make kernel"... "If not working - read instruction again"... - I am too haste...
    Thanks, will be researching watchdoc.c, I reach till to "rc" only ...
    I'm planning to change my wl500g into wl-hdd because of less size... but l'm not sure about NAT.
    Is there NAT in wl-hdd with oleg's firmware?
    Yes, you get everything from a Wl-500g, exect the parallel port, and the 4 port lan switch (you get only one). Otherwise, it give more fonctionality due to the speed of HDD.
  1. Do you know that ASUS thanks OLEG ?
    By ankn99 in forum WL-500g Q&A
    Last Post: 06-09-2005, 16:16
  2. Help WLHDD firmware update crash
    By math_67 in forum WL-HDD Q&A
    Last Post: 07-06-2005, 14:24
  3. Asus WL-500g deluxe and oleg firmware
    By Hannes123 in forum WL-500g Q&A
    Last Post: 26-04-2005, 11:12
  4. Firmware v1.7.5.6 CR2 [Oleg]
    Last Post: 05-05-2004, 03:10
    Last Post: 07-04-2004, 17:22
