PCI: Enabling device 01:03.2 (0000 -> 0002)
ehci_hcd 01:03.2: PCI device 1106:3104
ehci_hcd 01:03.2: irq 12, pci mem c0168000
usb.c: new USB bus registered, assigned bus number 3
EHCI: Enabling VIA 6212 workarounds
ehci_hcd 01:03.2: USB 2.0 enabled, EHCI 1.00, driver 10 Dec 2004/2.4
usb.c: USB disconnect on device 01:03.0-1 address 2
Unable to disconnect USB device from the SCSI subsystem
usb.c: USB disconnect on device 01:03.0-2 address 3
usb.c: USB disconnect on device 01:03.0-2.3 address 4
usb.c: USB disconnect on device 01:03.0-2.4 address 5
hub.c: USB hub found
hub.c: 4 ports detected
usbaudio: unregister dsp 14,3
usbaudio: unregister mixer 14,0
usbaudio: unregister mixer 14,16
Device 08:01 not ready.
I/O error: dev 08:01, sector 7887368
I/O error: dev 08:01, sector 4488
I/O error: dev 08:01, sector 4504
hub.c: new USB device 01:03.2-1, assigned address 2
Unable to connect USB device to the SCSI subsystem
WARNING: USB Mass Storage data integrity not assured
USB Mass Storage device found at 2
hub.c: new USB device 01:03.2-2, assigned address 3
hub.c: new USB device 01:03.2-2.3, assigned address 4
usb.c: USB device 4 (vend/prod 0xa12/0x1) is not claimed by any active driver.
usbaudio: dma timed out??
hub.c: new USB device 01:03.2-2.4, assigned address 5
usbaudio: device 5 audiocontrol interface 0 has 1 input and 1 output AudioStreaming interfaces
usbaudio: device 5 interface 2 altsetting 1 channels 1 framesize 2 configured
usbaudio: valid input sample rate 48000
usbaudio: valid input sample rate 44100
usbaudio: device 5 interface 2 altsetting 1: format 0x00000010 sratelo 44100 sratehi 48000 attributes 0x01
usbaudio: device 5 interface 1 altsetting 0 does not have an endpoint
usbaudio: device 5 interface 1 altsetting 1 channels 2 framesize 2 configured
usbaudio: valid output sample rate 48000
usbaudio: valid output sample rate 44100
usbaudio: device 5 interface 1 altsetting 1: format 0x01000010 sratelo 44100 sratehi 48000 attributes 0x01
usbaudio: registered dsp 14,3
usbaudio: constructing mixer for Terminal 6 type 0x0301
usbaudio: warning: found 1 of 2 logical channels.
usbaudio: assuming that a stereo channel connected directly to a mixer is missing in search (got Labtec headset?). Should be fine.
usbaudio: registered mixer 14,0
usbaudio: constructing mixer for Terminal 7 type 0x0101
usbaudio: registered mixer 14,16
usb_audio_parsecontrol: usb_audio_state at 81a85aa0
