Results 1 to 8 of 8
Thread: Pppoe doesn't work on Oleg fw 1.9.2.7-10
    Talking Pppoe doesn't work on Oleg fw 1.9.2.7-10
    I've updated the firmware from asus 1.9.7.7 and i cannot connect to my ISP. Pppoe doesn't work.
    I've configured username, password, clicked the auto ip assign....
    This is the log from Asus (this works)
    Jan 1 00:00:08 dhcp client: deconfig: lease is lost
    Jan 1 00:00:16 pppd[96]: Plugin rp-pppoe.so loaded.
    Jan 1 00:00:16 pppd[96]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.2
    Jan 1 00:00:16 pppd[97]: pppd 2.4.2 started by (unknown), uid 0
    Jan 1 00:00:16 pppd[97]: PPP session is 258
    Jan 1 00:00:16 pppd[97]: Using interface ppp0
    Jan 1 00:00:16 pppd[97]: Connect: ppp0 <--> eth0
    Jan 1 00:00:19 pppd[97]: PAP authentication succeeded
    Jan 1 00:00:19 pppd[97]: peer from calling number 00:15:17:4A:EA:B3 authorized
    Jan 1 00:00:19 pppd[97]: local IP address 86.121.176.21
    Jan 1 00:00:19 pppd[97]: remote IP address 10.0.0.1
    Jan 1 00:00:19 pppd[97]: primary DNS address 82.76.253.115
    Jan 1 00:00:19 pppd[97]: secondary DNS address 82.76.253.125
    Jan 1 00:00:19 PPPoE: connect to ISP
    Dec 2 23:20:44 ntp client: time is synchronized to time.nist.gov
    Dec 2 23:20:44 USB storage: vfat fs mounted to /tmp/harddisk/part0
    Dec 2 23:20:44 FTP server: daemon is started
    And here are some logs from Oleg's fw (this doesn't work)
    Jan 1 02:06:35 kernel: vlan1: Setting MAC address to 00 0e a6 f1 e3 54.
    Jan 1 02:06:35 kernel: VLAN (vlan1): Underlying device (eth0) has same MAC, not checking promiscious mode.
    Jan 1 02:06:35 pppd[269]: Plugin rp-pppoe.so loaded.
    Jan 1 02:06:35 pppd[269]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.2
    Jan 1 02:06:35 pppd[270]: pppd 2.4.2 started by admin, uid 0
    Jan 1 02:06:35 pppd[270]: Using interface ppp0
    Jan 1 02:06:35 pppd[270]: local IP address 10.64.64.64
    Jan 1 02:06:35 pppd[270]: remote IP address 10.112.112.112
    Jan 1 02:08:52 wan: connected manually
    Jan 1 02:08:52 pppd[270]: Terminating on signal 15.
    Jan 1 02:08:52 pppd[270]: Exit.
    another try (with idle disconnect time set to 0)
    Jan 1 02:00:07 kernel: USB Mass Storage support registered.
    Jan 1 02:00:07 kernel: vlan1: Setting MAC address to 00 0e a6 f1 e3 54.
    Jan 1 02:00:07 kernel: VLAN (vlan1): Underlying device (eth0) has same MAC, not checking promiscious mode.
    Jan 1 02:00:07 pppd[101]: Plugin rp-pppoe.so loaded.
    Jan 1 02:00:07 pppd[101]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.2
    Jan 1 02:00:07 pppd[102]: pppd 2.4.2 started by admin, uid 0
    Jan 1 02:00:07 pppd[102]: Using interface ppp0
    Jan 1 02:00:07 pppd[102]: local IP address 10.64.64.64
    Jan 1 02:00:07 pppd[102]: remote IP address 10.112.112.112
    Jan 1 02:00:19 kernel: MSDOS FS: IO charset utf8
    Jan 1 02:00:19 kernel: MSDOS FS: Using codepage 866
    Jan 1 02:00:19 USB storage: vfat fs at /dev/discs/disc0/part1 mounted to /tmp/mnt/disc0_1
    Jan 1 02:00:32 wan: connected manually
    Jan 1 02:00:32 pppd[102]: Terminating on signal 15.
    Jan 1 02:00:32 pppd[102]: Exit.
    Jan 1 02:00:37 kernel: vlan1: Setting MAC address to 00 0e a6 f1 e3 54.
    Jan 1 02:00:37 kernel: VLAN (vlan1): Underlying device (eth0) has same MAC, not checking promiscious mode.
    Jan 1 02:00:38 pppd[138]: Plugin rp-pppoe.so loaded.
    Jan 1 02:00:38 pppd[138]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.2
    Jan 1 02:00:38 pppd[139]: pppd 2.4.2 started by admin, uid 0
    Jan 1 02:00:38 pppd[139]: Using interface ppp0
    Jan 1 02:00:38 pppd[139]: local IP address 10.64.64.64
    Jan 1 02:00:38 pppd[139]: remote IP address 10.112.112.112
    Jan 1 02:00:47 wan: connected manually
    Jan 1 02:00:47 pppd[139]: Terminating on signal 15.
    Jan 1 02:00:47 pppd[139]: Exit.
    Jan 1 02:00:53 kernel: vlan1: Setting MAC address to 00 0e a6 f1 e3 54.
    Jan 1 02:00:53 kernel: VLAN (vlan1): Underlying device (eth0) has same MAC, not checking promiscious mode.
    Jan 1 02:00:53 pppd[161]: Plugin rp-pppoe.so loaded.
    Jan 1 02:00:53 pppd[161]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.2
    Jan 1 02:00:53 pppd[162]: pppd 2.4.2 started by admin, uid 0
    Jan 1 02:00:53 pppd[162]: Using interface ppp0
    Jan 1 02:00:53 pppd[162]: local IP address 10.64.64.64
    Jan 1 02:00:53 pppd[162]: remote IP address 10.112.112.112
    Jan 1 02:01:31 wan: connected manually
    Jan 1 02:01:32 pppd[162]: Terminating on signal 15.
    Jan 1 02:01:32 pppd[162]: Exit.
    Jan 1 02:01:34 kernel: vlan1: Setting MAC address to 00 0e a6 f1 e3 54.
    Jan 1 02:01:34 kernel: VLAN (vlan1): Underlying device (eth0) has same MAC, not checking promiscious mode.
    Jan 1 02:01:34 pppd[188]: Plugin rp-pppoe.so loaded.
    Jan 1 02:01:34 pppd[188]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.2
    Jan 1 02:01:34 pppd[189]: pppd 2.4.2 started by admin, uid 0
    Jan 1 02:01:34 pppd[189]: Using interface ppp0
    Jan 1 02:01:34 pppd[189]: local IP address 10.64.64.64
    Jan 1 02:01:34 pppd[189]: remote IP address 10.112.112.112
    Jan 1 02:01:36 radvd[195]: version 0.7.2 started
    Jan 1 02:01:36 radvd[195]: prefix length should be 64 for br0
    Jan 1 02:03:32 wan: connected manually
    Jan 1 02:03:33 pppd[189]: Terminating on signal 15.
    Jan 1 02:03:33 pppd[189]: Exit.
    Jan 1 02:03:38 kernel: vlan1: Setting MAC address to 00 0e a6 f1 e3 54.
    Jan 1 02:03:38 kernel: VLAN (vlan1): Underlying device (eth0) has same MAC, not checking promiscious mode.
    Jan 1 02:03:38 pppd[238]: Plugin rp-pppoe.so loaded.
    Jan 1 02:03:38 pppd[238]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.2
    Jan 1 02:03:38 pppd[239]: pppd 2.4.2 started by admin, uid 0
    Jan 1 02:03:38 pppd[239]: Using interface ppp0
    Jan 1 02:03:38 pppd[239]: local IP address 10.64.64.64
    Jan 1 02:03:38 pppd[239]: remote IP address 10.112.112.112
    Jan 1 02:03:39 radvd[247]: version 0.7.2 started
    Jan 1 02:03:39 radvd[247]: prefix length should be 64 for br0
    Jan 1 02:03:39 radvd[247]: another radvd seems to be already running, terminating
    Jan 1 02:04:22 wan: connected manually
    Jan 1 02:04:22 pppd[239]: Terminating on signal 15.
    Jan 1 02:04:22 pppd[239]: Exit.
    Jan 1 02:04:28 kernel: vlan1: Setting MAC address to 00 0e a6 f1 e3 54.
    Jan 1 02:04:28 kernel: VLAN (vlan1): Underlying device (eth0) has same MAC, not checking promiscious mode.
    Jan 1 02:04:28 pppd[272]: Plugin rp-pppoe.so loaded.
    Jan 1 02:04:28 pppd[272]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.2
    Jan 1 02:04:28 pppd[273]: pppd 2.4.2 started by admin, uid 0
    Jan 1 02:04:28 pppd[273]: Using interface ppp0
    Jan 1 02:04:28 pppd[273]: local IP address 10.64.64.64
    Jan 1 02:04:28 pppd[273]: remote IP address 10.112.112.112
    Jan 1 02:04:29 radvd[281]: version 0.7.2 started
    Jan 1 02:04:29 radvd[281]: prefix length should be 64 for br0
    Jan 1 02:04:29 radvd[281]: another radvd seems to be already running, terminating
    Jan 1 02:04:45 wan: connected manually
    Jan 1 02:04:45 pppd[273]: Terminating on signal 15.
    Jan 1 02:04:45 pppd[273]: Exit.
    Jan 1 02:04:48 kernel: vlan1: Setting MAC address to 00 0e a6 f1 e3 54.
    Jan 1 02:04:48 kernel: VLAN (vlan1): Underlying device (eth0) has same MAC, not checking promiscious mode.
    Jan 1 02:04:48 pppd[300]: Plugin rp-pppoe.so loaded.
    Jan 1 02:04:48 pppd[300]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.2
    Jan 1 02:04:48 pppd[301]: pppd 2.4.2 started by admin, uid 0
    Jan 1 02:04:48 pppd[301]: Using interface ppp0
    Jan 1 02:04:48 pppd[301]: local IP address 10.64.64.64
    Jan 1 02:04:48 pppd[301]: remote IP address 10.112.112.112
    Jan 1 02:04:49 radvd[309]: version 0.7.2 started
    Jan 1 02:04:49 radvd[309]: prefix length should be 64 for br0
    Jan 1 02:04:49 radvd[309]: another radvd seems to be already running, terminating
    I've tried to set de "idle disconnect time" to 0, but it doesn't work.
    Turned on IPv6... doesn't work.
    Turned firewall off... nothing changed.
    Does anyone knows how to solve this problem??
    I was thinking to try dd-wrt firmware, but i didn't found any information if i can put the asus firmware back again. Do u know if it's possible?
    Thanks for your answers.
    Hi !
    I tried DD-WRT v24-SP2-mega on my 500gp.
    It is a stable, good firmware.
    The setup for working with ipkg-opt, is very difficult.
    After I play 2-3 day with DD-WRT, I go back to Oleg fw
    You can put back the stock asus fw or another one.
    Back from DD-WRT to another firmware:
    After you make the first login ( adding user and password via webgui ) to the DD-WRT , it is disabe the standard "recovery mode", no tftp by default !
    Computer setup:
    IP:192.168.1.2
    MASK:255.255.255.0
    Gateway:192.168.1.1
    DNS:192.168.1.1
    * Step 1: You must reset first to default settings ( in webgui or manual with reset button)
    and wait for boot....After that you get back tftp in "recover mode".
    * Step 2: Unplug the power cord from the router
    * Step 3: Wait 20 seconds
    * Step 4: Press and hold the reset button on the back of the router.
    * Step 5: While holding the reset button, plug the power cord into the router. Continue to hold the reset button until the power light starts flashing. Let go of the reset button
    * Step 6: Use tftp to transfer wl500g-clear-nvram.trx to the router.
    * Step 7: Tftp should report a successful file transfer in 7-15 seconds. Wait 2-3 minutes after that before unplugging the router
    * Step 8: Unplug the router, wait 20 seconds. Hold the reset button and plug the power cord into the router, continuing to hold the reset button until the power light flashes. Release the reset button.
    * Step 9: Use tftp to transfer wl500g-recover.trx to the router. Same method as above, just change the file name. Wait 2-3 minutes after tftp reports a successful file transfer before unplugging the router.
    * Step 10: Unplug the router, wait 20 seconds. Hold the reset button and plug the power cord into the router, continuing to hold the reset button until the power light flashes. Release the reset button.
    * Step 11: Use tftp to transfer the firmware what you want to the router (only TRX file !)
    * Step 12: Wait 3-4 or more minutes, if your firmware is big after tftp reports a successful file transfer before unplugging the router. Unplug the power cord from the router, wait 20 seconds, and plug the power cord back into the router.
    Enjoy
    Sorry4my english I am Hungarian
    Простите за тривиальный вопрос- где брали 1.9.2.7-10? И я хочу попробовать...
    Sonice...I don't understand what you are trying to say (unrecognized characters... Простите за тривиальный вопрос- где брали 1.9.2.7-10? И я хочу попробовать... ).
    Subset...I also want to be the happy user of oleg's firmware, but...pppoe doesn't let me. :P
    I've remembered that in the update process i haven't used firmware restoration (it doesn't connect to my router), but the update process made from administration page was ok, no errors (if u don't count the fact that is not connecting to my isp :P).
    Forget the english, is not my native language also, but i hope that u understand what i'm trying to say.
    I've made it work. I don't realy know hat have i done.
    Maybe...i've installed from firmware restoration.
    ....enabled ping from wan (i don't remembered if i've done that in the first place)
    ....set the idle to disconnect to 0 (i've done that)
    Now i'm banging my head trying to make samba the way i like (private folder and so on), setup the ftp and see the torrents flowing.
    Thanks Oleg, i think u know u've done a great job.
    LE. Strong DC works at greater speed.
    I am having the same problem, no PPPoE connect with Oleg Firmware 1.9.2.7-9 and 1.9.2.7-10. With Asus Firmware 1.9.7.7 no problem. I tried flashing with restoration tool, I flashed wl500g-clear-nvram.trx, nothing helped. I have always loaded factory defaults at the first boot with new firmware. Here is the system log from Oleg Firmware 1.9.2.7-10:
    Jan 1 01:00:03 syslogd started: BusyBox v1.1.3
    Jan 1 01:00:03 kernel: klogd started: BusyBox v1.1.3 (2008.03.17-18:24+0000)
    Jan 1 01:00:03 dnsmasq[70]: started, version 2.22 cachesize 150
    Jan 1 01:00:03 dnsmasq[70]: DHCP, IP range 192.168.1.2 -- 192.168.1.254, lease time 24h
    Jan 1 01:00:03 dnsmasq[70]: DHCP, /tmp/dnsmasq.log will be written every 8h
    Jan 1 01:00:03 dnsmasq[70]: read /etc/hosts - 5 addresses
    Jan 1 01:00:03 dnsmasq[70]: reading /tmp/resolv.conf
    Jan 1 01:00:03 kernel: CPU revision is: 00029006
    Jan 1 01:00:03 kernel: Primary instruction cache 16kb, linesize 16 bytes (2 ways)
    Jan 1 01:00:03 kernel: Primary data cache 16kb, linesize 16 bytes (2 ways)
    Jan 1 01:00:03 kernel: Linux version 2.4.20 (root@localhost) (gcc version 3.2.3 with Broadcom modifications) #18 Sun Mar 30 13:13:29 MSD 2008
    Jan 1 01:00:03 kernel: Setting the PFC to its default value
    Jan 1 01:00:03 kernel: Determined physical RAM map:
    Jan 1 01:00:03 kernel: memory: 02000000 @ 00000000 (usable)
    Jan 1 01:00:03 kernel: On node 0 totalpages: 8192
    Jan 1 01:00:03 kernel: zone(0): 8192 pages.
    Jan 1 01:00:03 kernel: zone(1): 0 pages.
    Jan 1 01:00:03 kernel: zone(2): 0 pages.
    Jan 1 01:00:03 kernel: Kernel command line: root=/dev/mtdblock2 noinitrd init=/linuxrc console=ttyS0,115200
    Jan 1 01:00:03 kernel: CPU: BCM4704 rev 8 pkg 2 at 264 MHz
    Jan 1 01:00:03 kernel: Calibrating delay loop... 263.78 BogoMIPS
    Jan 1 01:00:03 kernel: Memory: 30092k/32768k available (1862k kernel code, 2676k reserved, 136k data, 72k init, 0k highmem)
    Jan 1 01:00:03 kernel: Dentry cache hash table entries: 4096 (order: 3, 32768 bytes)
    Jan 1 01:00:03 kernel: Inode cache hash table entries: 2048 (order: 2, 16384 bytes)
    Jan 1 01:00:03 kernel: Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
    Jan 1 01:00:03 kernel: Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes)
    Jan 1 01:00:03 kernel: Page-cache hash table entries: 8192 (order: 3, 32768 bytes)
    Jan 1 01:00:03 kernel: Checking for 'wait' instruction... unavailable.
    Jan 1 01:00:03 kernel: POSIX conformance testing by UNIFIX
    Jan 1 01:00:03 kernel: PCI: Initializing host
    Jan 1 01:00:03 kernel: PCI: Fixing up bus 0
    Jan 1 01:00:03 kernel: PCI: Fixing up bridge
    Jan 1 01:00:03 kernel: PCI: Fixing up bus 1
    Jan 1 01:00:03 kernel: Linux NET4.0 for Linux 2.4
    Jan 1 01:00:03 kernel: Based upon Swansea University Computer Society NET3.039
    Jan 1 01:00:03 kernel: Initializing RT netlink socket
    Jan 1 01:00:03 kernel: Starting kswapd
    Jan 1 01:00:03 kernel: Journalled Block Device driver loaded
    Jan 1 01:00:03 kernel: devfs: v1.12c (20020818) Richard Gooch (rgooch@atnf.csiro.au)
    Jan 1 01:00:03 kernel: devfs: boot_options: 0x1
    Jan 1 01:00:03 kernel: NTFS driver v1.1.22 [Flags: R/O]
    Jan 1 01:00:03 kernel: pty: 256 Unix98 ptys configured
    Jan 1 01:00:03 kernel: Serial driver version 5.05c (2001-07-08) with MANY_PORTS SHARE_IRQ SERIAL_PCI enabled
    Jan 1 01:00:03 kernel: ttyS00 at 0xb8000300 (irq = 3) is a 16550A
    Jan 1 01:00:03 kernel: ttyS01 at 0xb8000400 (irq = 3) is a 16550A
    Jan 1 01:00:03 kernel: HDLC line discipline: version $Revision$, maxframe=4096
    Jan 1 01:00:03 kernel: N_HDLC line discipline registered.
    Jan 1 01:00:03 kernel: loop: loaded (max 8 devices)
    Jan 1 01:00:03 kernel: PPP generic driver version 2.4.2
    Jan 1 01:00:03 kernel: PPP Deflate Compression module registered
    Jan 1 01:00:03 kernel: PPP BSD Compression module registered
    Jan 1 01:00:03 kernel: MPPE/MPPC encryption/compression module registered
    Jan 1 01:00:03 kernel: PPPoL2TP kernel driver, V0.13 (oleg@cs.msu.su)
    Jan 1 01:00:03 kernel: Amd/Fujitsu Extended Query Table v1.3 at 0x0040
    Jan 1 01:00:03 kernel: Flash Id: Vendor: 0x0001 Device: 0x007e
    Jan 1 01:00:03 kernel: number of CFI chips: 1
    Jan 1 01:00:03 kernel: Flash device: 0x800000 at 0x1c000000
    Jan 1 01:00:03 kernel: Physically mapped flash: squashfs filesystem found at block 912
    Jan 1 01:00:03 kernel: Creating 5 MTD partitions on "Physically mapped flash":
    Jan 1 01:00:03 kernel: 0x00000000-0x00040000 : "boot"
    Jan 1 01:00:03 kernel: 0x00040000-0x007f0000 : "linux"
    Jan 1 01:00:03 kernel: 0x000e4000-0x007f0000 : "rootfs"
    Jan 1 01:00:03 kernel: 0x007f0000-0x00800000 : "nvram"
    Jan 1 01:00:03 kernel: 0x003e0000-0x007f0000 : "flashfs"
    Jan 1 01:00:03 kernel: sflash: found no supported devices
    Jan 1 01:00:03 kernel: NET4: Linux TCP/IP 1.0 for NET4.0
    Jan 1 01:00:03 kernel: IP Protocols: ICMP, UDP, TCP, IGMP
    Jan 1 01:00:03 kernel: IP: routing cache hash table of 512 buckets, 4Kbytes
    Jan 1 01:00:03 kernel: TCP: Hash tables configured (established 2048 bind 4096)
    Jan 1 01:00:03 kernel: Linux IP multicast router 0.06 plus PIM-SM
    Jan 1 01:00:03 kernel: ip_conntrack version 2.1 (256 buckets, 2048 max) - 352 bytes per conntrack
    Jan 1 01:00:03 kernel: ip_conntrack_pptp version 1.9 loaded
    Jan 1 01:00:03 kernel: ip_nat_pptp version 1.5 loaded
    Jan 1 01:00:03 kernel: ip_tables: (C) 2000-2002 Netfilter core team
    Jan 1 01:00:03 kernel: ipt_time loading
    Jan 1 01:00:03 kernel: NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
    Jan 1 01:00:03 kernel: IPv6 v0.8 for NET4.0
    Jan 1 01:00:03 kernel: IPv6 over IPv4 tunneling driver
    Jan 1 01:00:03 kernel: NET4: Ethernet Bridge 008 for NET4.0
    Jan 1 01:00:03 kernel: 802.1Q VLAN Support v1.7 Ben Greear <greearb@candelatech.com>
    Jan 1 01:00:03 kernel: All bugs added by David S. Miller <davem@redhat.com>
    Jan 1 01:00:03 kernel: FAT: bogus logical sector size 59648
    Jan 1 01:00:03 kernel: NTFS: Unable to set blocksize 512.
    Jan 1 01:00:03 kernel: VFS: Mounted root (squashfs filesystem) readonly.
    Jan 1 01:00:03 kernel: Mounted devfs on /dev
    Jan 1 01:00:03 kernel: Freeing unused kernel memory: 72k freed
    Jan 1 01:00:03 kernel: Algorithmics/MIPS FPU Emulator v1.5
    Jan 1 01:00:03 kernel: eth0: Broadcom BCM47xx 10/100 Mbps Ethernet Controller 4.150.10.16
    Jan 1 01:00:03 kernel: PCI: Enabling device 01:02.0 (0004 -> 0006)
    Jan 1 01:00:03 kernel: 2.11 Wireless Controller 4.150.10.16
    Jan 1 01:00:03 kernel: device eth0 entered promiscuous mode
    Jan 1 01:00:03 kernel: device vlan0 entered promiscuous mode
    Jan 1 01:00:03 kernel: device eth1 entered promiscuous mode
    Jan 1 01:00:03 kernel: br0: port 2(eth1) entering listening state
    Jan 1 01:00:03 kernel: br0: port 1(vlan0) entering listening state
    Jan 1 01:00:03 kernel: br0: port 2(eth1) entering learning state
    Jan 1 01:00:03 kernel: br0: port 2(eth1) entering forwarding state
    Jan 1 01:00:03 kernel: br0: topology change detected, propagating
    Jan 1 01:00:03 kernel: br0: port 1(vlan0) entering learning state
    Jan 1 01:00:03 kernel: br0: port 1(vlan0) entering forwarding state
    Jan 1 01:00:04 kernel: usb.c: registered new driver usbdevfs
    Jan 1 01:00:04 kernel: usb.c: registered new driver hub
    Jan 1 01:00:04 kernel: usb-uhci.c: $Revision: 1.275 $ time 20:50:46 Mar 17 2008
    I have to split the log, because its too long, read on in next post
    - Every human has a photographic memory, but some forgot to put the film in -
    Jan 1 01:00:04 kernel: usb-uhci.c: High bandwidth mode enabled
    Jan 1 01:00:04 kernel: PCI: Enabling device 01:03.0 (0000 -> 0001)
    Jan 1 01:00:04 kernel: ECHI PCI device 30381106 found.
    Jan 1 01:00:04 kernel: UCHI reg 0x41 = 10
    Jan 1 01:00:04 kernel: UCHI reg 0x41 changed to = 0
    Jan 1 01:00:04 kernel: usb-uhci.c: USB UHCI at I/O 0x100, IRQ 12
    Jan 1 01:00:04 kernel: usb-uhci.c: Detected 2 ports
    Jan 1 01:00:04 kernel: usb.c: new USB bus registered, assigned bus number 1
    Jan 1 01:00:04 kernel: hub.c: USB hub found
    Jan 1 01:00:04 kernel: hub.c: 2 ports detected
    Jan 1 01:00:04 kernel: PCI: Enabling device 01:03.1 (0000 -> 0001)
    Jan 1 01:00:04 kernel: usb-uhci.c: USB UHCI at I/O 0x120, IRQ 12
    Jan 1 01:00:04 kernel: usb.c: new USB bus registered, assigned bus number 2
    Jan 1 01:00:04 kernel: usb-uhci.c: v1.275:USB Universal Host Controller Interface driver
    Jan 1 01:00:04 kernel: PCI: Enabling device 01:03.2 (0000 -> 0002)
    Jan 1 01:00:04 kernel: ehci_hcd 01:03.2: PCI device 1106:3104
    Jan 1 01:00:04 kernel: ehci_hcd 01:03.2: irq 12, pci mem c011c000
    Jan 1 01:00:04 kernel: usb.c: new USB bus registered, assigned bus number 3
    Jan 1 01:00:04 kernel: ECHI PCI device 31041106 found.
    Jan 1 01:00:04 kernel: ECHI reg 0x49 = 80010f20
    Jan 1 01:00:04 kernel: ECHI reg 0x49 changed to = 80010f00
    Jan 1 01:00:04 kernel: ECHI reg 0x4b = 80010f09
    Jan 1 01:00:04 kernel: ECHI reg 0x4b changed to = 80010f29
    Jan 1 01:00:04 kernel: PCI: 01:03.2 PCI cache line size set incorrectly (0 bytes) by BIOS/FW, correcting to 32
    Jan 1 01:00:04 kernel: ehci_hcd 01:03.2: USB 2.0 enabled, EHCI 1.00, driver 2003-Dec-29/2.4
    Jan 1 01:00:04 kernel: hub.c: 4 ports detected
    Jan 1 01:00:04 kernel: usb.c: registered new driver usblp
    Jan 1 01:00:04 kernel: printer.c: v0.13: USB Printer Device Class driver
    Jan 1 01:00:06 kernel: usb.c: registered new driver audio
    Jan 1 01:00:06 kernel: audio.c: v1.0.0:USB Audio Class driver
    Jan 1 01:00:06 kernel: Linux video capture interface: v1.00
    Jan 1 01:00:06 kernel: SCSI subsystem driver Revision: 1.00
    Jan 1 01:00:06 kernel: Initializing USB Mass Storage driver...
    Jan 1 01:00:06 kernel: usb.c: registered new driver usb-storage
    Jan 1 01:00:06 kernel: USB Mass Storage support registered.
    Jan 1 01:00:06 kernel: vlan1: Setting MAC address to 00 17 31 e4 b7 48.
    Jan 1 01:00:06 kernel: VLAN (vlan1): Underlying device (eth0) has same MAC, not checking promiscious mode.
    Jan 1 01:00:07 pppd[98]: Plugin rp-pppoe.so loaded.
    Jan 1 01:00:07 pppd[98]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.2
    Jan 1 01:00:07 pppd[99]: pppd 2.4.2 started by admin, uid 0
    Jan 1 01:00:07 pppd[99]: Using interface ppp0
    Jan 1 01:00:07 pppd[99]: local IP address 10.64.64.64
    Jan 1 01:00:07 pppd[99]: remote IP address 10.112.112.112
    Jan 1 01:00:29 wan: connected manually
    Jan 1 01:00:29 pppd[99]: Terminating on signal 15.
    Jan 1 01:00:29 pppd[99]: Exit.
    Jan 1 01:00:34 kernel: vlan1: Setting MAC address to 00 17 31 e4 b7 48.
    Jan 1 01:00:34 kernel: VLAN (vlan1): Underlying device (eth0) has same MAC, not checking promiscious mode.
    Jan 1 01:00:35 pppd[130]: Plugin rp-pppoe.so loaded.
    Jan 1 01:00:35 pppd[130]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.2
    Jan 1 01:00:35 pppd[131]: pppd 2.4.2 started by admin, uid 0
    Jan 1 01:00:35 pppd[131]: Using interface ppp0
    Jan 1 01:00:35 pppd[131]: local IP address 10.64.64.64
    Jan 1 01:00:35 pppd[131]: remote IP address 10.112.112.112
    Status & Log - Routing Table
    10.112.112.112 * 255.255.255.255 UH 0 0 0 WAN ppp0
    192.168.1.0 * 255.255.255.0 U 0 0 0 LAN br0
    default * 0.0.0.0 U 0 0 0 WAN ppp0
    I am a Windows user and an absolute noob in Linux. I have a WL-HDD running with older Oleg firmware, but never tried to connect to the internet directly. Hopefully someone knows what has gone wrong and can help.
    regards, bitbrain2101
    I got it to work, but the same as posted before me, I dont know what made it work. Reconnect takes a long time (about 25 seconds) with this firmware compared to original Asus firmware.
  1. I cannot connect on pppoe WAN with Oleg firmware
    By kalifro in forum WL-500w Q&A
    Last Post: 20-03-2011, 23:39
  2. Problem getting ADSL with PPPoE to work
    By TheBigLebowski in forum WL-500gP Q&A
    Last Post: 13-09-2008, 15:29
  3. Replies: 1
    Last Post: 16-05-2008, 03:44
