Heya,
I just wonder what the reset pin on the uart might do?
The reason im asking is because i have an external uart that i want to connect to one of the uart's on the wl500gp, however this device uses a reset line as well as tx and rx to signal the start of communication.
It then wants a ATR from the "master device" (wl500gp in this case) in response to this.
Now i was hoping that possibly the reset pin on the router could be used for this but i haven't found any datasheet info on what it does.
If that does not work, are there any GPIO pins available on the wl500gp that i may be able to use?
BR agru
