Hi there
Tried to use a very old cheap cam on wl500gp v2:
Vendor=0ac8 ProdID=301b Rev= 1.00
Manufacturer=Z-Star Corp.
Product=PC Camera
Figured out that I should use spca5xx (or LE?), so I downloaded it from another post here and did:
modprobe videodev
insmod spca5xx.o
dmesg gives me:
usb.c: registered new driver ?
spca5xx.c: spca5xx driver 00.60.00 registered
next I plugged the camera into usb (without hub), dmesg gives:
hub.c: port 1, portstatus 103, change 0, 12 Mb/s
hub.c: port 2, portstatus 101, change 1, 12 Mb/s
hub.c: port 2 connection change
hub.c: port 2, portstatus 101, change 0, 12 Mb/s
hub.c: port 2, portstatus 103, change 10, 12 Mb/s
hub.c: new USB device 00:03.0-1.2, assigned address 6
usb.c: kmalloc IF 816fd7c0, numif 1
usb.c: new device strings: Mfr=1, Product=2, SerialNumber=0
usb.c: USB device number 6 default language ID 0x409
Manufacturer: Z-Star Corp.
Product: PC Camera
usb.c: ? driver claimed interface 816fd7c0
usb.c: kusbd: /sbin/hotplug add 6
and lsmod gives (which seems the webcam is recognized):
Module Size Used by Tainted: P
spca5xx-00.60.00 577560 1
videodev 8312 0 [spca5xx-00.60.00]
However my problem is in /dev, there is no 'video' or 'v4l/video0' folder created properly which is required by webcam apps normally I suppose.
Anyone please help? Thanks a lot!!!
