Results 1 to 3 of 3
Thread: Several problems
    Several problems
    First: I've never had problems with this router. Oleg's newest firmware worked for a long time very stable. But since a week I have several problems with my router. I don't have internet anymore; in system status the router says that I'm connected but I'm not; only a hard-reset works.
    Now I have a big problem: Wireless don't work. After all possible resets, it still doesn't work. Earlier I had the same problem; but then I saw in System Status -> Wireless that Radio was disabled. But now is everything enabled, but still no blinking Air-light and no signal. System status says:
    Mode : AP Only
    Channel : 0
    Channel: 0????? What? Why? Can somebody explain this to me?
    when i do de 'wl' command, I get this:
    wl: wl driver adapter not found
    How is this possible? Everytime it works, instead of now... The only thing I can remember is that everything worked perfectly this morning, but in the evening I came home and I found the router on the ground (think it fell) so that is the only thing that changed. Maybe something broken inside the router?
    THAT was the problem; the WLAN-pci card inside the router was not completely in his bracket (because of the fall), I put it back in the bracket and everything works
    Argh, so many resets because of something easy :P
  1. problems with esniper
    By zwoerb in forum WL-500gP Q&A
    Last Post: 07-08-2009, 13:04
  2. rc.local problems
    By Troto in forum WL-700g Firmware Discussion
    Last Post: 05-07-2008, 15:38
  3. 1.9.2.7-9 encryption problems fix
    By wpte in forum WL-500w Firmware Discussion
    Last Post: 30-03-2008, 19:45
  4. How TO - Vodafone Huawei E-220 Connecting problems
    By xipbox in forum WL-500gP Tutorials
    Last Post: 19-03-2008, 22:16
  5. ASUS F5R Wireless Problems
    By Chino in forum WL-500g Q&A
    Last Post: 28-01-2008, 09:02
