Using stock firmware atm, looking to swap over to olegs when I get the time to sit down with the router, bit swamped under atm unfortuantly.
Tried both TKIP & AES with both the 3945 and usb-n11, same prob all round
Haven't touched the advanced settings section as yet, to be honest I don't know what half of those settings mean so I think I'll leave well enough alone
Wired hasn't been a problem for me, when I was trying to troubleshoot this I had the laptop plugged in via ethernet cable to the router and I swapped between setting the default routes to go via that device and the wireless devices. The wired connection did not drop once that I noticed.
Anyhow, thanks for letting me know that it works for you and it's not just some stupid design flaw that makes it impossible to get encryption working with linux clients period
nice to know that I'm (hopefully) not wasting my time trying to get it to work lol
