Check your PM.
More info for you.......no reponse from net....so i manually disconnected and reconnected....heres a log
Jan 1 11:00:13 bpalogin[102]: BPALogin v2.0.2 - portable BigPond Broadband login client
Jan 1 11:00:13 kernel: neg fail
Jan 1 11:00:16 bpalogin[102]: Cant connect to auth server - No route to host
Jan 1 11:00:16 bpalogin[102]: Sleeping for 60 seconds
Jan 1 11:00:22 udhcpc[101]: Received DHCP NAK
Jan 1 11:00:22 dnsmasq[51]: read /etc/hosts - 4 addresses
Jan 1 11:00:22 dnsmasq[51]: reading /tmp/resolv.conf
Jan 1 11:00:22 dnsmasq[51]: using nameserver 61.9.128.15#53
Jan 1 11:00:22 bpalogin[102]: Error connecting logout auth socket - Network is unreachable
Jan 1 11:00:22 dhcp client: nak: lease is lost
Jan 1 11:00:22 ddns update: error connecting to members.dyndns.org:80
Jan 1 11:00:23 dhcp client: deconfig: lease is lost
Jan 1 11:00:26 udhcpc[101]: Entering released state
Jan 1 11:00:56 wan: connected manually
Jan 1 11:00:56 udhcpc[101]: Performing a DHCP renew
Jan 1 11:00:58 udhcpc[101]: Lease of 144.132.41.152 obtained, lease time 20925
Jan 1 11:00:58 dnsmasq[51]: read /etc/hosts - 4 addresses
Jan 1 11:00:58 dnsmasq[51]: reading /tmp/resolv.conf
Jan 1 11:00:58 dnsmasq[51]: using nameserver 61.9.192.15#53
Jan 1 11:00:58 dnsmasq[51]: using nameserver 61.9.128.14#53
Jan 1 11:00:58 dnsmasq[51]: using nameserver 61.9.128.15#53
Jan 1 11:00:59 ddns update: no update needed at this time
Feb 19 12:27:20 bpalogin[136]: BPALogin v2.0.2 - portable BigPond Broadband login client
Feb 19 12:27:20 dhcp client: bound IP : 144.132.41.152 from 144.132.40.1
Feb 19 12:27:29 ntp client: Synchronizing time with time.nist.gov ...
Feb 19 12:28:05 login[145]: root login on `pts/0'
Feb 19 12:45:04 login[148]: root login on `pts/0'
Feb 19 12:54:13 wan: disconnected manually
Feb 19 12:54:13 udhcpc[101]: Unicasting a release of 144.132.41.152 to 172.18.17.80
Feb 19 12:54:13 dnsmasq[51]: read /etc/hosts - 4 addresses
Feb 19 12:54:13 dnsmasq[51]: reading /tmp/resolv.conf
Feb 19 12:54:13 dnsmasq[51]: using nameserver 61.9.128.15#53
Feb 19 12:54:13 bpalogin[136]: Error connecting logout auth socket - Network is unreachable
Feb 19 12:54:13 dhcp client: deconfig: lease is lost
Feb 19 12:54:13 udhcpc[101]: Entering released state
Feb 19 12:54:16 wan: connected manually
Feb 19 12:54:16 udhcpc[101]: Performing a DHCP renew
Feb 19 12:54:19 udhcpc[101]: Lease of 144.132.41.152 obtained, lease time 3600
Feb 19 12:54:19 dnsmasq[51]: read /etc/hosts - 4 addresses
Feb 19 12:54:19 dnsmasq[51]: reading /tmp/resolv.conf
Feb 19 12:54:19 dnsmasq[51]: using nameserver 61.9.192.15#53
Feb 19 12:54:19 dnsmasq[51]: using nameserver 61.9.128.14#53
Feb 19 12:54:19 dnsmasq[51]: using nameserver 61.9.128.15#53
Feb 19 12:54:19 ddns update: no update needed at this time
Feb 19 12:54:20 dhcp client: bound IP : 144.132.41.152 from 144.132.40.1
Feb 19 12:54:20 bpalogin[171]: BPALogin v2.0.2 - portable BigPond Broadband login client
Good luck
Adam
Check your PM.
Device: WLHDD
Firmware: 1.9.2.7-3c
Problem: No ftp
[admin@wl-hdd /]$ lsmod
Module Size Used by
usb-storage 62144 0 (unused)
sd_mod 13268 0 (unused)
scsi_mod 70176 1 [usb-storage sd_mod]
videodev 8304 0 (unused)
audio 50120 0 (unused)
soundcore 5280 0 [audio]
printer 12620 0 (unused)
usb-ohci 21764 0 (unused)
usbcore 77224 1 [usb-storage audio printer usb-ohci]
ipt_NETMAP 992 2
ip_nat_starcraft 2224 0 (unused)
wl 418352 0 (unused)
et 26976 0 (unused)
ide-disk 13524 0
ide-probe-mod 11468 0
ide-mod 109568 0 [ide-disk ide-probe-mod]
[admin@wl-hdd /]$ mount
none on /dev type devfs (rw)
proc on /proc type proc (rw)
ramfs on /tmp type ramfs (rw)
Syslog part:
Jan 1 03:00:02 kernel: hda: IC25N040ATMR04-0, ATA DISK drive
I see hard disk not mount, but it present
What i must to do?
Alex
Alex, the problem is that my firmware does not mount your harddisk automatically, you will need to do it yourself using the post-boot script. The easiest way is to add these lines to it:Originally Posted by AlexSuslov
This should trigger mounting your drive in 10 seconds and launching ftp/samba.Code:#!/bin/sh nvram set usb_storage_device=1
What does the router do with OOB (Out of Band) packets?
I'm having problems getting any punkbuster game to work. I have tried router with and without firewall turned on? Does it ignore OOB's?
Thanks
Adam
HI.
I have a problem with the router and the printer(hp deskjet 5652). In the past two days in the system log I get this infoWhen I turn on the printer she prints the latest printed document. It's in Raw port 9100, USB.Code:Feb 22 16:03:55 kernel: lp_wait_ready timeout Feb 22 16:03:55 kernel: lp_write timeout Feb 22 16:04:00 kernel: lp_wait_ready timeout Feb 22 16:04:00 kernel: lp_write timeout Feb 22 16:04:05 kernel: lp_wait_ready timeout Feb 22 16:04:05 kernel: lp_write timeout Feb 22 16:04:10 kernel: lp_wait_ready timeout Feb 22 16:04:10 kernel: lp_write timeout Feb 22 16:04:15 kernel: lp_wait_ready timeout Feb 22 16:04:15 kernel: lp_write timeout Feb 22 16:04:20 kernel: lp_wait_ready timeout Feb 22 16:04:20 kernel: lp_write timeout Feb 22 16:04:25 kernel: lp_wait_ready timeout Feb 22 16:04:25 kernel: lp_write timeout Feb 22 16:04:30 kernel: lp_wait_ready timeout Feb 22 16:04:30 kernel: lp_write timeout
I've readed a similar problem in the previous fw version.
Any news about this?
My fw is 1.9.2.7-cr3c with wpa-psk my wan(2 asus and 1 toshiba) and lan has 3 laptops and 2 desktops.
Thanks.
According to your log you are trying to print via parallel port using either port 9101 or LPR.Originally Posted by kiboko
the printer is connected by usb, port 9100 in both asus laptops. No other laptop or desktop uses the printer.
Problem solved. A friend of mine who also has a wl-500g and has configured his printer in parallel mode has come to my house with his laptop. I believe that was the reason why the router act like this. I've restarted the router and now everything is ok.
thanks.
I Have a strange problem, I have to reset my AP sometimes. When I look with Netstumbler to my AP I see the following:
Does anyone have seen this before?
Well, looks like corrupted packets. Also, the receive signal is too strong - -28dB - have you changed output power somehow or attached external antenna?Originally Posted by freestuff
Device: WL500g
Firmware: 1.9.2.7 CR3c
Problem: MPPE required, but kernel has no support :-(
I try to connect to ISP over VPN connection.
My options.pptp file:
lock
noauth
nobsdcomp
nodeflate
require-mppe
My peer file:
name myname
remotename PPTP
ipparam quadra
file /etc/ppp/options.pptp
Files pap-secret and chap-secret exists and are correct.
Adn I start my connection with command
pppd pty 'pptp 10.4.0.254 --nolaunchpppd' call quadra updetach
This that I see:
Using interface ppp0
Connect: ppp0 <--> /dev/pts/1
Warning - secret file /tmp/ppp/pap-secrets has world and/or group access
Warning - secret file /tmp/ppp/chap-secrets has world and/or group access
MPPE required, but kernel has no support.
Connection terminated.
This string is from kernel log:
Jan 1 03:00:03 kernel: MPPE/MPPC encryption/compression module registered
Sorry for my bad English :-(
This is not an 1.9.2.7-3c log - either you've not upgraded firmware, or it does not belong to wl500g at all. Is this peer (server) log?Originally Posted by KO(c)Tik
1.9.2.7-3c supports MPPE/MPPC out of the box, no manual actions required at all - just select PPTP.
Sorry, can i speek russian with you? My english is to poore to discribe all my manipulations with this deviceOriginally Posted by Oleg
But i can say with 100%, that firmware is 1.9.2.7-3c. This text is not a log, this is what i see on my display, when i try to connect to my VPN server by executing the following command.
In /tmp/syslog.log I find the following lines:
Jan 1 03:11:20 pppd[280]: pppd 2.4.2 started by admin, uid 0
Jan 1 03:11:20 pppd[280]: Using interface ppp0
Jan 1 03:11:20 pppd[280]: Connect: ppp0 <--> /dev/pts/1
Jan 1 03:11:20 pptp[283]: anon log[mainptp.c:243]: The synchronous pptp option is NOT activated
Jan 1 03:11:20 pptp[285]: anon log[ctrlp_repptp_ctrl.c:243]: Sent control packet type is 1 'Start-Control-Connection-Request'
Jan 1 03:11:20 pptp[285]: anon log[ctrlp_dispptp_ctrl.c:721]: Received Start Control Connection Reply
Jan 1 03:11:20 pptp[285]: anon log[ctrlp_dispptp_ctrl.c:755]: Client connection established.
Jan 1 03:11:21 pppd[280]: Warning - secret file /tmp/ppp/pap-secrets has world and/or group access
Jan 1 03:11:21 pptp[285]: anon log[ctrlp_repptp_ctrl.c:243]: Sent control packet type is 7 'Outgoing-Call-Request'
Jan 1 03:11:21 pptp[285]: anon log[ctrlp_dispptp_ctrl.c:841]: Received Outgoing Call Reply.
Jan 1 03:11:21 pppd[280]: Warning - secret file /tmp/ppp/chap-secrets has world and/or group access
Jan 1 03:11:21 pptp[285]: anon log[ctrlp_dispptp_ctrl.c:880]: Outgoing call established (call ID 0, peer's call ID 4480).
Jan 1 03:11:21 pppd[280]: MPPE required, but kernel has no support.
Jan 1 03:11:21 pppd[280]: Connection terminated.
Jan 1 03:11:21 pptp[283]: anon warn[decaps_hdlcptp_gre.c:197]: short read (-1): Input/output error
Jan 1 03:11:21 pptp[283]: anon warn[decaps_hdlcptp_gre.c:209]: pppd may have shutdown, see pppd log
Jan 1 03:11:21 pppd[280]: Exit.
Jan 1 03:11:21 pptp[285]: anon log[callmgr_mainptp_callmgr.c:228]: Closing connection
Jan 1 03:11:21 pptp[285]: anon log[ctrlp_repptp_ctrl.c:243]: Sent control packet type is 12 'Call-Clear-Request'
Jan 1 03:11:21 pptp[285]: anon log[pptp_read_someptp_ctrl.c:525]: read returned zero, peer has closed
Jan 1 03:11:21 pptp[285]: anon log[call_callbackptp_callmgr.c:77]: Closing connection
Sure, use private messages.Originally Posted by KO(c)Tik
