Jan 1 03:00:04 syslogd started: BusyBox v1.01 (2006.01.07-10:53+0000)
Jan 1 03:00:04 kernel: klogd started: BusyBox v1.01 (2006.01.07-10:53+0000)
Jan 1 03:00:04 kernel: cpu probe
Jan 1 03:00:04 kernel: prom init
Jan 1 03:00:04 kernel: cpu report
Jan 1 03:00:04 kernel: CPU revision is: 00029007
Jan 1 03:00:04 kernel: Primary instruction cache 8kb, linesize 16 bytes (2 ways)
Jan 1 03:00:04 kernel: Primary data cache 4kb, linesize 16 bytes (2 ways)
Jan 1 03:00:04 kernel: Linux version 2.4.20 (root@omnibook) (gcc version 3.2.3 with Broadcom modifications) #15 Sat Jan 7 20:01:34 MSK 2006
Jan 1 03:00:04 kernel: Setting the PFC value as 0x15
Jan 1 03:00:04 kernel: Determined physical RAM map:
Jan 1 03:00:04 kernel: memory: 02000000 @ 00000000 (usable)
Jan 1 03:00:04 kernel: On node 0 totalpages: 8192
Jan 1 03:00:04 kernel: zone(0): 8192 pages.
Jan 1 03:00:04 kernel: zone(1): 0 pages.
Jan 1 03:00:04 kernel: zone(2): 0 pages.
Jan 1 03:00:04 kernel: Kernel command line: root=/dev/mtdblock2 noinitrd init=/linuxrc console=ttyS0,115200
Jan 1 03:00:04 kernel: CPU: BCM5365 rev 1 at 200 MHz
Jan 1 03:00:04 kernel: Calibrating delay loop... 199.47 BogoMIPS
Jan 1 03:00:04 kernel: Memory: 30068k/32768k available (1772k kernel code, 2700k reserved, 248k data, 72k init, 0k highmem)
Jan 1 03:00:04 kernel: Dentry cache hash table entries: 4096 (order: 3, 32768 bytes)
Jan 1 03:00:04 kernel: Inode cache hash table entries: 2048 (order: 2, 16384 bytes)
Jan 1 03:00:04 kernel: Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Jan 1 03:00:04 kernel: Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes)
Jan 1 03:00:04 kernel: Page-cache hash table entries: 8192 (order: 3, 32768 bytes)
Jan 1 03:00:04 kernel: Checking for 'wait' instruction... unavailable.
Jan 1 03:00:04 kernel: POSIX conformance testing by UNIFIX
Jan 1 03:00:04 kernel: PCI: Fixing up bus 0
Jan 1 03:00:04 kernel: PCI: Fixing up bridge
Jan 1 03:00:04 kernel: PCI: Fixing up bus 1
Jan 1 03:00:04 kernel: Linux NET4.0 for Linux 2.4
Jan 1 03:00:04 kernel: Based upon Swansea University Computer Society NET3.039
Jan 1 03:00:04 kernel: Initializing RT netlink socket
Jan 1 03:00:04 kernel: Starting kswapd
Jan 1 03:00:04 kernel: Journalled Block Device driver loaded
Jan 1 03:00:04 kernel: devfs: v1.12c (20020818) Richard Gooch (rgooch@atnf.csiro.au)
Jan 1 03:00:04 kernel: devfs: boot_options: 0x1
Jan 1 03:00:04 kernel: NTFS driver v1.1.22 [Flags: R/O]
Jan 1 03:00:04 kernel: pty: 256 Unix98 ptys configured
Jan 1 03:00:04 kernel: Serial driver version 5.05c (2001-07-08) with MANY_PORTS SHARE_IRQ SERIAL_PCI enabled
Jan 1 03:00:04 kernel: ttyS00 at 0xb8000300 (irq = 3) is a 16550A
Jan 1 03:00:04 kernel: ttyS01 at 0xb8000400 (irq = 3) is a 16550A
Jan 1 03:00:04 kernel: HDLC line discipline: version $Revision$, maxframe=4096
Jan 1 03:00:04 kernel: N_HDLC line discipline registered.
Jan 1 03:00:04 kernel: loop: loaded (max 8 devices)
Jan 1 03:00:04 kernel: PPP generic driver version 2.4.2
Jan 1 03:00:04 kernel: PPP Deflate Compression module registered
Jan 1 03:00:04 kernel: PPP BSD Compression module registered
Jan 1 03:00:04 kernel: MPPE/MPPC encryption/compression module registered
Jan 1 03:00:04 kernel: Amd/Fujitsu Extended Query Table v1.1 at 0x0040
Jan 1 03:00:04 kernel: number of CFI chips: 1
Jan 1 03:00:04 kernel: Flash device: 0x400000 at 0x1c000000
Jan 1 03:00:05 kernel: Physically mapped flash: squashfs filesystem found at block 944
Jan 1 03:00:05 kernel: Creating 5 MTD partitions on "Physically mapped flash":
Jan 1 03:00:05 kernel: 0x00000000-0x00040000 : "pmon"
Jan 1 03:00:05 kernel: 0x00040000-0x003e0000 : "linux"
Jan 1 03:00:05 kernel: 0x000ec04c-0x003e0000 : "rootfs"
Jan 1 03:00:05 kernel: 0x003f0000-0x00400000 : "nvram"
Jan 1 03:00:05 kernel: 0x003e0000-0x003f0000 : "config"
Jan 1 03:00:05 kernel: sflash: found no supported devices
Jan 1 03:00:05 kernel: NET4: Linux TCP/IP 1.0 for NET4.0
Jan 1 03:00:05 kernel: IP Protocols: ICMP, UDP, TCP
Jan 1 03:00:05 kernel: IP: routing cache hash table of 512 buckets, 4Kbytes
Jan 1 03:00:05 kernel: TCP: Hash tables configured (established 2048 bind 4096)
Jan 1 03:00:05 kernel: ip_conntrack version 2.1 (256 buckets, 2048 max) - 344 bytes per conntrack
Jan 1 03:00:05 kernel: ip_conntrack_pptp version 1.9 loaded
Jan 1 03:00:05 kernel: ip_nat_pptp version 1.5 loaded
Jan 1 03:00:05 kernel: ip_tables: (C) 2000-2002 Netfilter core team
Jan 1 03:00:05 kernel: ipt_time loading
Jan 1 03:00:05 kernel: NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
Jan 1 03:00:05 kernel: IPv6 v0.8 for NET4.0
Jan 1 03:00:05 kernel: IPv6 over IPv4 tunneling driver
Jan 1 03:00:05 kernel: NET4: Ethernet Bridge 008 for NET4.0
Jan 1 03:00:05 kernel: 802.1Q VLAN Support v1.7 Ben Greear <greearb@candelatech.com>
Jan 1 03:00:05 kernel: All bugs added by David S. Miller <davem@redhat.com>
Jan 1 03:00:05 kernel: FAT: bogus logical sector size 22528
Jan 1 03:00:05 kernel: NTFS: Unable to set blocksize 512.
Jan 1 03:00:05 kernel: VFS: Mounted root (squashfs filesystem) readonly.
Jan 1 03:00:05 dnsmasq[72]: started, version 2.22 cachesize 150
Jan 1 03:00:05 kernel: Mounted devfs on /dev
Jan 1 03:00:05 kernel: Freeing unused kernel memory: 72k freed
Jan 1 03:00:05 kernel: Algorithmics/MIPS FPU Emulator v1.5
Jan 1 03:00:05 kernel: 90.7.0
Jan 1 03:00:05 kernel: PCI: Enabling device 01:03.0 (0004 -> 0006)
Jan 1 03:00:05 kernel: eth1: Broadcom BCM4320 802.11 Wireless Controller 3.90.23.0
Jan 1 03:00:05 kernel: vlan0: add 33:33:00:00:00:01 mcast address to master interface
Jan 1 03:00:05 dnsmasq[72]: DHCP, IP range 192.168.68.2 -- 192.168.68.254, lease time 24h
Jan 1 03:00:05 kernel: vlan0: add 33:33:ff:24:61:e6 mcast address to master interface
Jan 1 03:00:05 dnsmasq[72]: DHCP, /tmp/dnsmasq.log will be written every 8h
Jan 1 03:00:05 kernel: vlan0: dev_set_promiscuity(master, 1)
Jan 1 03:00:05 dnsmasq[72]: read /etc/hosts - 5 addresses
Jan 1 03:00:05 kernel: device eth0 entered promiscuous mode
Jan 1 03:00:05 dnsmasq[72]: reading /tmp/resolv.conf
Jan 1 03:00:05 kernel: device vlan0 entered promiscuous mode
Jan 1 03:00:05 dnsmasq[72]: using nameserver 213.135.64.2#53
Jan 1 03:00:05 kernel: device eth1 entered promiscuous mode
Jan 1 03:00:05 dnsmasq[72]: using nameserver 213.135.64.5#53
Jan 1 03:00:05 kernel: br0: port 2(eth1) entering listening state
Jan 1 03:00:05 kernel: br0: port 1(vlan0) entering listening state
Jan 1 03:00:05 kernel: br0: port 2(eth1) entering learning state
Jan 1 03:00:05 kernel: br0: port 1(vlan0) entering learning state
Jan 1 03:00:05 kernel: br0: port 2(eth1) entering forwarding state
Jan 1 03:00:05 kernel: br0: topology change detected, propagating
Jan 1 03:00:05 kernel: br0: port 1(vlan0) entering forwarding state
Jan 1 03:00:05 kernel: usb.c: registered new driver usbdevfs
Jan 1 03:00:05 kernel: usb.c: registered new driver hub
Jan 1 03:00:05 kernel: usb-uhci.c: $Revision: 1.275 $ time 21:43:09 Apr 20 2005
