Results 1 to 3 of 3
Thread: Help: cannot use ext2 on usb flash stick with Oleg 1.9.2.7-10 (but can use ext3)
    When reading several articles on mounting usb flash devices under linux,
    many of them advice to use ext2 i.s.o. ext3 to prevent premature flash wearout, in combination with mounting such partitions with -o noatime.
    However, when trying to get this to work with Oleg's firmware 1.9.2.7-10
    it will not mount the ext2 partition.
    I used fdisk to wipe all partitions and make a fresh one:
    fdisk -l
    Disk /dev/scsi/host0/bus0/target0/lun0/disc: 131 MB, 131072000 bytes
    16 heads, 32 sectors/track, 500 cylinders
    Units = cylinders of 512 * 512 = 262144 bytes
    /dev/scsi/host0/bus0/target0/lun0/part1 1 500 127984 83 Linux
    I formatted to ext2 partition with
    mke2fs /dev/discs/disc0/part1
    which completed succesful.
    Trying to mount it however will fail
    mount -t ext2 /dev/discs/disc0/part1 /opt
    mount: Mounting /dev/discs/disc0/part1 on /opt failed: No such device
    If however I format using ext3, everything is A OK.
    mke2fs -j /dev/discs/disc0/part1
    mount -o noatime /dev/discs/disc0/part1 /opt
    df gives:
    /dev/root 3072 3072 0 100% /
    /dev/discs/disc0/part1 123939 4127 113413 4% /opt
    How to proceed? I thought ext2 should work in all situations??
    I really want to prevent flash wearout due to ext3, and want to use ext2.
    Jun 2005
    Slovenia
    See supported filesystems with
    cat /proc/filesystems
    and you will notice that ext2 is not included
    is it possible to add it without having to recompile the kernel myself?
    Last Post: 14-03-2012, 15:28
  2. USB Stick wird nicht erkannt, jetzt unter OLEG
    By pc-nico in forum German Discussion - Deutsch (DE)
    Last Post: 27-05-2008, 18:21
  3. usb stick not present
    By fennec in forum WL-HDD Q&A
    Last Post: 10-03-2007, 21:57
