There is no chance (yet?) to get Transmission WebUI running functionally on IE due Explorer not following standards once again. Check out this forum thread: http://forum.transmissionbt.com/view...t=4907&p=23707
Transmission hours work, but once you start the daemon, and disappears rrdtool webpage rrdtool not be reached. What is wrong?
hmm... right, it still sux I have to use a different browser...
I mean I hate firefox because the one time I tried it, it cought a virus and after norton removed it I couldn't start or remove firefox anymore...
and opera seems to have problems on showing updated content on websites, you really need to hit the update button to see it
but for opera it works fine so far, it looks modern this way...
but I dunno, it still looks a bit like windows vista, it's pimped up but I still kinda miss some functionality that has been lost...
it has great preformance tho... I get 500kb/s all the time
normally it was about 70kb/s
Transmission was splitted into two packages with changeset 8882.
Clutch package now depends on 1.22 transmisisond package until next upgrade.
I completely reinstalled everything on my router including transmission1.32, it works fine but I have few questions:
1. When I rebooted my router(i was forwarding ports), transmission simply forgot all torrent that I was seeding. How can I shutdown transmission before rebooting to avoid this?
2. Where does he put torrent files?
3. Where is configuration file for transmission?
A few issues I have with the new transmission:
- transmission-daemon won't start at reboot, I have transmission-daemon in my post-boot
- after a router restart all the settings I made in "Preferences", from the transmission web page are reset
- I had one torrent seeding, with the new transmission, but after a router restart it dissapeared
- compared with the previous ver the downloading speed is smaller, It may be something about the connection with the tracker using the new transmission
How can I reinstall the previous version of transmission?
I have followed wengi's how to install . Everything was Ok until
vi /opt/etc/transmission.conf the file doesn't exist. The install of transmission was without error . Please help... THANKS !
[admin@ASUS root]$ ipkg list_installed
c-ares - 1.5.2-2 - C library that performs DNS requests and name resolves asynch ronously
cron - 4.1-7 - Standard vixie cron, with cron.d addition
e2fslibs - 1.41.0-1 - Ext2 Filesystem Libraries
e2fsprogs - 1.41.0-1 - Ext2 Filesystem Utilities
expat - 2.0.1-1 - XML Parser library
fontconfig - 2.5.0-0 - Font configuration library
freetype - 2.3.6-1 - Free truetype library
gconv-modules - 2.2.5-7 - Provides gconv modules missing from the firmware. The se are used by glibc iconv() implementation.
glib - 2.12.13-1 - The GLib library of C routines.
gnuplot - 4.2.3-1 - Command-line driven interactive data and function plotting u tility
ipkg-opt - 0.99.163-10 - The Itsy Package Manager
libcurl - 7.18.2-3 - Curl is a command line tool for transferring files with URL syntax, supporting FTP, FTPS, HTTP, HTTPS, GOPHER, TELNET, DICT, FI
libgd - 2.0.35-2 - An ANSI C library for the dynamic creation of images
libjpeg - 6b-2 - collection of jpeg tools
libpng - 1.2.29-1 - Portable Network Graphics Libraries
libuclibc++ - 0.2.2-8 - C++ standard library designed for use in embedded system s
logrotate - 3.7.5-2 - Rotates, compresses, removes and mails system log files.
mc - 4.6.1-3 - Midnight Commander File Manager
ncurses - 5.6-3 - NCurses libraries
openssl - 0.9.7m-4 - Openssl provides the ssl implementation in libraries libcry pto and libssl, and is needed by many other applications and librari
popt - 1.14-1 - A C library for parsing command line parameters.
readline - 5.2-2 - The GNU Readline library provides a set of functions for use by applications that allow users to edit command lines as they are
slang - 2.1.3-1 - S-Lang is a multi-platform library designed to allow a develop er to create robust multi-platform software.
transmission - 1.32-1 - lightweight BitTorrent client and daemon
uclibc-opt - 0.9.28-13 - micro C library for embedded Linux systems
zlib - 1.2.3-3 - zlib is a library implementing the 'deflate' compression system .
Successfully terminated.
I also had same problems, also my router became unstable and after many reboots I installed 1.22Code:ipkg remove transmssion ipkg install http://ipkg.nslu2-linux.org/feeds/optware/oleg/cross/stable/transmissiond_1.22-1_mipsel.ipk
Look at this topic, and you get your answer:
http://wl500g.info/showthread.php?t=15562
Ed
when I reboot my torrents are gone... is this the asus download manager after all?
I’ve found solution for this problem (but I’ve lost some of .torrent files ).
It might be because config, .torrent and temp are stored in flash memory, so you have to lashfs etc. to store them before reboot.
Try to move all folders and files from /tmp/local/root/.config/transmission-daemon to /tmp/harddisk/torrent/.config/
Then start transmission with parameters (last two are user and password to acces web interface - remove or change xxxx and yyyy)
So far it works. After manual start with parameters uploaded .torrent files are stored in /tmp/harddisk/torrent/.config/torrents folders and thera are still there after reboot.Code:transmission-daemon -p 8008 -g /tmp/harddisk/torrent/.config -w /tmp/harddisk/torrent -t --auth -u xxxxxxxx -v yyyyyyyyy
But I have still problem with starting transmission automatically.
Doesn't work.Code:nano /usr/local/sbin/post-mount flashfs save && flashfs commit && flashfs enable && reboot
How to start transmission automatically?
Hi
Im new(bie) to this so I followed wengi's guide for setting up the router just yesterday.
Was wondering if someone could explain exactly which of the transmission install/setup steps that should be changed/replaced?
