Results 1 to 3 of 3
Thread: Firmware problem with WL500b (maybe v2?)
    i've got problem to upload any of newer firmwares than 1.7.5.9 - the preinstalled one. I've tried a lot of versions, used rescue mode & so on, but nothing.
    Every times i try to do it form wwwcontrol pages result is:
    Firmware Upgrade Fail !
    Firmware upgrade fail. It may result from incorrect image or error transmission. Please check the version of firmare and try again.
    I dont know what shall i do, to get newer firmware into my unit?
    Could you help me?
    I've tried firmware versions:
    wg01080109_WL500bv2_EN
    WL500b_1.8.1.3_en
    WL500bv2_1824_EN
    wg01080109_WL500g_EN
    It's quite strange.
    Thank you for your suggestions.
    Jan PACAK
    Nov 2003
    Eindhoven
    search for FIRMWARE RECOVERY
    also consult the CD which came with your router
    Ok, I'v ecucceded. With recovery tool and firmware 1.8.1.9, thank you. I tried this to do several tiems and the last attempt was ok.
    But i've got still problems with raw printig - using both 9100 and 9101 port - it doesn't work with hp deskjet 5550 - windows just say that printig nasn't succesful. LPRServer works, but there is long time, when last paper cames out of the printer and the moment whan i can print another job (it takes about 2 minutes) it is normal?
  1. Interfaces in wl500b v.2
    By webman in forum WL-500g Q&A
    Last Post: 11-05-2005, 11:33
  2. OLEG Firmware on WL500b
    By albi in forum WL-500g Q&A
    Last Post: 11-09-2004, 12:33
  3. Firmware v1.8.1.3 (Qualification Test) WL500b ONLY
    By Antiloop in forum WL-500b Firmware Releases
    Last Post: 23-07-2004, 18:10
