I make some discovery and I found folowing - when I connect my IPTV cable into ASUS WL500W this step totaly finished router because there is a lot of packets errors.
Is any way to find out why reason of these errors?
Thanks for help
I use Oleg last fw 1.9.2.7-10 and I have problem with forwarding multicast packets from Wan to Lan. If I use only LAN ports there is no problem with that.
In my config I allowed Multicast and DHCP routes, also no firewall is on.
I had the same problem with orig Asus fw (2.0.0.1).
Is there anything what should I try to find out where is the problem?
BTW - If I try replace ASUS WL500W with some Linksys everything works fine.
Thanks for any help
Thanks for help
what if you try turning down the firewall?
any difference
My firewall is off. There is no lan to wan and wan to lan filter too.
I have to admit, I don't really have a lot of knolege about multicast packages...
maybe you can ask around in the wl-500gP forums, it has more active members and ppl who know a lot
it could also be a utp cable tough... dunno how long they are
