Page 4 of 5 FirstFirst ... 2345 LastLast
Results 46 to 60 of 73
Thread: Transmission help
  1. #46
    Jun 2005
    Slovenia
    ipkg update && ipkg upgrade
  2. #47
    Feb 2005
    Germany - Frankfurt
    Thanks oleo
  3. #48
    Feb 2005
    Germany - Frankfurt
    regarding the transmission port: which webserver are you using?
    If it is the default (busybox) you should have a look at /opt/etc/init.d/S80busybox_httpd.
    Look for a line like "LISTENING_PORT=8008".
    wengi
  4. #49
    Yea I figured it out last night poking around in the folders for opt/etc/ init.d found it in there. I was wondering If I decide to use lighttfpd to is better because it has ssl. It was one of the tutorials in the post for more tricks and stuff. I just want to make the transmission website secure so other people can't access it from LAN.
  5. Transmission & log
    Every time I hit "Log" button in the transmission web interface, I get different graph, but every time it's not the right one... e.g. graph shows that transmission was not running for a day, even if it was, or the graph shows values for 2 days ahead, or 2 days in the past... what's up with that?
  6. #51
    Jun 2005
    Slovenia
    Maybe troubles with date/time and ntpclient.
  7. Quote Originally Posted by oleo View Post
    date is ok
    [admin@WL-500GP root]$ date
    Thu Jul 17 15:20:48 METDST 2008
    how do I set/check ntp client?
  8. #53
    Sorry im really stupid at this..
    How do i do this??
    Please help
  9. #54
    Transmission and ports
    Hi all,
    I have WL500gP with Oleg FW and with Transmission. Transmissions run without problems but I'm active only if i stop internet firewall. When is firewall runnig my status is pasive. I tried open ports (my listen port for trans. is 9090) but without efect. Can you help me? Thamks.
  10. #55
    I am trying to edit iptables and nothing works for me.
    What is a detailed configuration of your firewall,
    what rules are set .
    And how to access firewall rules on Olegs firmware.
    iptables listing is almost transparent
    darius
    Quote Originally Posted by CZ_Rexx View Post
    Hi all,
  11. #56
    Feb 2005
    Germany - Frankfurt
    Try to add this to /usr/local/sbin/post-firewall where XXX is the portnumer.
    # this opens the port number XXX to internet!
    iptables -I INPUT -m tcp -p tcp --dport XXX -j ACCEPT
    wengi
    PS: My HowTo, Chapter 14b. (Done for ssh)
  12. #57
    Quote Originally Posted by shouriken View Post
    I've had this problem too after installing 1.9.2.7-10 and following wengi's new tutorial.
    I've solved it by setting loglevel=7 in S05syslogd:
    OPTIONS="-m 0 -O $LOG_NEW/$LOGFILE -S -l 7 -s 0"
    and now I have statistics data for transmission.
    i'm having the same problem, as first poster in thread, bu i've checked that file and everything is like above
    any thoughts ?
  13. #58
    Quote Originally Posted by wengi View Post
    wengi
    i tried it, but without effect. I read your how to, but after save and reboot is port still close.
    When i try port here: http://www.canyouseeme.org/ i have reason:
    Error: I could not see your service on xx.xx.xxx.xxx on port (9090)
    Reason: Connection timed out
    When i disable firewall, all is open. But it is unusable
  14. #59
    Feb 2005
    Germany - Frankfurt
    Do a forum search for iptables.
    You will find many threads dealing with opening ports and the right order of rules.
    wengi
  15. #60
    wengi
    my problem was in missing string: "#!/bin/sh"
    Thanks for help
  1. WL-500gp and Transmission
    By happymeal in forum WL-500gP Q&A
    Last Post: 27-08-2008, 18:46
  2. Understanding and debugging Transmission [oleo?]
    By wengi in forum WL-500gP Q&A
    Last Post: 05-08-2007, 09:36
