Originally Posted by
ti_chris
So Here's what I do:
-I tftp flash.trx onto the device (That works fine)
-Press Reset
-Device boots up with the HD spinning, the port light comes on and the power light comes on, the IDE light flashes ONCE and then it never changes.
-I try to push the NAS file with the firmware restoration tool and I get:
Downloading C:\WL700gE_1.0.7.8.nas...
ERROR: Transfer failed: 10054
Could you please re-port flash.trx? I'm just wondering if I got a bad version of it (I got my 1.0.7.8 from Asus, which should be fine).
