I get a ?xml error with title 403 forbidden and h1 forbidden, then all i see is "loading" .
The permissions look ok to me, and i "install" this 3 times, but no go in any browser.
Some help here pls.
And i do restart ..
Some help here pls.
And i do restart ..
fixed it, sorry was my fault - problem with php not being set up correctly.
I am having the exact same problem. Receiving 403 forbidden, and then it just sasy loading... How exactly should I configure php? I have just downloaded the ipkg php - 5.2.6-1 package. Should I do something more???
rrd graph for wl500gp http://wl500ginfo.pastebin.com/f63a4f212
Is this your own creation, or based off of another rtorrent frontend? I'm not using this on an asus router but a standalone torrent box.
This is by far the best looking rtorrent webui I've seen. Will you continue to support this and do you have a project page?
I'm getting this response when rtorrent is working more than few hours, and then i reboot server and all download need do be checked [few hours to check all of them..] how can i solve this problem??Bad response: (500) <?xml version="1.0" encoding="iso-8859-1"?> <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"> <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en"> <head> <title>500 - Internal Server Error</title> </head> <body> <h1>500 - Internal Server Error</h1> </body> </html>
