Changing the IP adress of the router seems to be a dangerous task, even with asus original software. That also was the reason for my problems.
With pin9 to ground you pull down one adress line of the nvram so at boot the firmware thinks that nvram content is corrupted and loads default settings. You have to power off/on again after that.
Edit:
It is only a feeling, but I think it is a good recommendation to change the LAN IP of the router as a single task, no other settings changed at the same time.
- Every human has a photographic memory, but some forgot to put the film in -
