[myself@usb-router root]$ ipkg list_installed
bzip2 - 1.0.5-1 - Very high-quality data compression program
cron - 4.1-7 - Standard vixie cron, with cron.d addition
cyrus-sasl-libs - 2.1.22-2 - Provides client or server side authentication (see RFC 2222).
e2fslibs - 1.41.4-1 - Ext2 Filesystem Libraries
gdbm - 1.8.3-2 - GNU dbm is a set of database routines that use extensible hashing. It works similar to the standard UNIX dbm routines.
glib - 2.16.6-1 - The GLib library of C routines.
gzip - 1.2.4a-3 - GNU Zip data compression program
ipkg-opt - 0.99.163-10 - The Itsy Package Manager
libdb - 4.2.52-3 - Berkeley DB Libraries
libuclibc++ - 0.2.2-8 - C++ standard library designed for use in embedded systems
libxml2 - 2.7.3-1 - Libxml2 is the XML C parser and toolkit developed for the Gnome project.
libxslt - 1.1.24-1 - An XML Stylesheet processor based on libxml2
lighttpd - 1.4.22-1 - A fast webserver with minimal memory footprint.
mc - 4.6.2-1 - Midnight Commander File Manager
nano - 2.1.9-1 - A pico like editor
ncurses - 5.7-1 - NCurses libraries
openldap-libs - 2.3.43-1 - Open Lightweight Directory Access Protocol
openssl - 0.9.7m-5 - Openssl provides the ssl implementation in libraries libcrypto and libssl, and is needed by many other applications and librari
pcre - 7.8-1 - Perl-compatible regular expression library
perl - 5.8.8-20 - Practical Extraction and Report Language.
php - 5.2.9-3 - The php scripting language
php-fcgi - 5.2.9-1 - The php scripting language, built as an fcgi module
procps - 3.2.7-6 - PROCPS System Utilities
slang - 2.1.4-1 - S-Lang is a multi-platform library designed to allow a developer to create robust multi-platform software.
spawn-fcgi - 1.6.1-1 - spawn-fcgi is used to spawn fastcgi applications
tar - 1.22-2 - heavyweight version of the Tape ARchiver
uclibc-opt - 0.9.28-13 - micro C library for embedded Linux systems
unrar - 3.8.5-1 - unrar is an application that can decompress files and archives created using the RAR compression scheme
unzip - 5.52-3 - A (de)compression library for the ZIP format
zlib - 1.2.3-3 - zlib is a library implementing the 'deflate' compression system.
Successfully terminated.
[myself@usb-router root]$ ps axf
BusyBox v1.1.3 (2008.03.17-18:24+0000) multi-call binary
Usage: ps
