i use lighttpd with cgi executed by /opt/bin/bash.
So same idea, other webserver
wengi
I think I found a better solution ... when you install new busybox three some command stop working (mount, per example) and push don't work everytime ... oleo say "Or maybe bash", so I try this:
- use thttpd instead of busybox;
- add cgipat=/cgi-bin/* and user=admin in thttpd.conf;
- install bash (ipkg install bash);
- change #!/bin/sh with #!/opt/bin/bash on transmission.cgi top.
and everything works better and faster!
Perhaps busybox-httpd will work as well, I use php-thttpd because I need it for a blog ... two pigeon with a bean!
wengi
Ьbersicht aller HowTos --- HowTo Overview (mostly german)
