# lighttpd configuration file
# use it as a base for lighttpd 1.0.0 and above
# $Id: lighttpd.conf 8860 2008-08-05 10:56:16Z engy $
############ Options you really have to take care of ####################
## modules to load
# at least mod_access and mod_accesslog should be loaded
# all other module should only be loaded if really neccesary
# - saves some time
# - saves memory
server.modules = (
# "mod_rewrite",
# "mod_redirect",
# "mod_alias",
"mod_access",
# "mod_cml",
# "mod_trigger_b4_dl",
# "mod_auth",
# "mod_status",
# "mod_setenv",
# "mod_fastcgi",
# "mod_proxy",
# "mod_simple_vhost",
# "mod_evhost",
# "mod_userdir",
# "mod_cgi",
# "mod_compress",
# "mod_ssi",
# "mod_usertrack",
# "mod_expire",
# "mod_secdownload",
# "mod_rrdtool",
"mod_accesslog" )
## a static document-root, for virtual-hosting take look at the
## server.virtual-* options
server.document-root = "/opt/share/www/"
## where to send error-messages to
server.errorlog = "/opt/var/log/lighttpd/error.log"
# files to check for if .../ is requested
index-file.names = ( "index.php", "index.html",
"index.htm", "default.htm",
<------><------><------><------>"lighttpd/index.html" )
## set the event-handler (read the performance section in the manual)
# server.event-handler = "freebsd-kqueue" # needed on OS X
# mimetype mapping
mimetype.assign = (
".pdf" => "application/pdf",
".sig" => "application/pgp-signature",
".spl" => "application/futuresplash",
".class" => "application/octet-stream",
".ps" => "application/postscript",
".torrent" => "application/x-bittorrent",
".dvi" => "application/x-dvi",
".gz" => "application/x-gzip",
".pac" => "application/x-ns-proxy-autoconfig",
".swf" => "application/x-shockwave-flash",
".tar.gz" => "application/x-tgz",
".tgz" => "application/x-tgz",
".tar" => "application/x-tar",
".zip" => "application/zip",
".mp3" => "audio/mpeg",
".m3u" => "audio/x-mpegurl",
".wma" => "audio/x-ms-wma",
".wax" => "audio/x-ms-wax",
".ogg" => "application/ogg",
".wav" => "audio/x-wav",
".gif" => "image/gif",
".jpg" => "image/jpeg",
".jpeg" => "image/jpeg",
".png" => "image/png",
".xbm" => "image/x-xbitmap",
".xpm" => "image/x-xpixmap",
".xwd" => "image/x-xwindowdump",
".css" => "text/css",
".html" => "text/html",
".htm" => "text/html",
".js" => "text/javascript",
".asc" => "text/plain",
".c" => "text/plain",
".cpp" => "text/plain",
".log" => "text/plain",
".conf" => "text/plain",
".text" => "text/plain",
".txt" => "text/plain",
".dtd" => "text/xml",
".xml" => "text/xml",
".mpeg" => "video/mpeg",
".mpg" => "video/mpeg",
".mov" => "video/quicktime",
".qt" => "video/quicktime",
".avi" => "video/x-msvideo",
".asf" => "video/x-ms-asf",
".asx" => "video/x-ms-asf",
".wmv" => "video/x-ms-wmv",
".bz2" => "application/x-bzip",
".tbz" => "application/x-bzip-compressed-tar",
".tar.bz2" => "application/x-bzip-compressed-tar"
# Use the "Content-Type" extended attribute to obtain mime type if possible
#mimetype.use-xattr = "enable"
## send a different Server: header
## be nice and keep it at lighttpd
# server.tag = "lighttpd"
#### accesslog module
accesslog.filename = "/opt/var/log/lighttpd/access.log"
## deny access the file-extensions
# ~ is for backupfiles from vi, emacs, joe, ...
# .inc is often used for code includes which should in general not be part
# of the document-root
url.access-deny = ( "~", ".inc" )
$HTTP["url"] =~ "\.pdf$" {
server.range-requests = "disable"
# which extensions should not be handle via static-file transfer
# .php, .pl, .fcgi are most often handled by mod_fastcgi or mod_cgi
static-file.exclude-extensions = ( ".fcgi", ".php", ".pl", ".py", ".rb" )
######### Options that are good to be but not neccesary to be changed #######
## bind to port (default: 80)
server.port = 8081
## bind to localhost (default: all interfaces)
#server.bind = "grisu.home.kneschke.de"
## error-handler for status 404
#server.error-handler-404 = "/error-handler.html"
#server.error-handler-404 = "/error-handler.php"
## to help the rc.scripts
server.pid-file = "/var/run/lighttpd.pid"
###### virtual hosts
## If you want name-based virtual hosting add the next three settings and load
## mod_simple_vhost
## document-root =
## virtual-server-root + virtual-server-default-host + virtual-server-docroot
## or
## virtual-server-root + http-host + virtual-server-docroot
#simple-vhost.server-root = "/home/weigon/wwwroot/servers/"
#simple-vhost.default-host = "grisu.home.kneschke.de"
#simple-vhost.document-root = "/pages/"
## Format: <errorfile-prefix><status-code>.html
## -> ..../status-404.html for 'File not found'
#server.errorfile-prefix = "/home/weigon/projects/lighttpd/doc/status-"
## virtual directory listings
#dir-listing.activate = "enable"
## enable debugging
#debug.log-request-header = "enable"
#debug.log-response-header = "enable"
#debug.log-request-handling = "enable"
#debug.log-file-not-found = "enable"
### only root can use these options
# chroot() to directory (default: no chroot() )
#server.chroot = "/"
## change uid to <uid> (default: don't care)
#server.username = "nobody"
#server.groupname = "nobody"
#### compress module
#compress.cache-dir = "/tmp/lighttpd/cache/compress/"
#compress.filetype = ("text/plain", "text/html")
#### proxy module
## read proxy.txt for more info
#proxy.server = ( ".php" =>
# ( "localhost" =>
# "host" => "192.168.0.101",
# "port" => 80
#### fastcgi module
## read fastcgi.txt for more info
#fastcgi.server = ( ".php" =>
# ( "localhost" =>
# "socket" => "/tmp/php-fcgi.sock",
# "bin-path" => "/opt/bin/php-fcgi",
# "bin-environment" => (
# <-->"PHP_FCGI_MAX_REQUESTS" => "4000"
#### CGI module
#cgi.assign = ( ".pl" => "/opt/bin/perl",
# ".cgi" => "/opt/bin/perl" )
#### SSL engine
#ssl.engine = "enable"
#ssl.pemfile = "server.pem"
#ssl.ca-file = "ca.crt"
#ssl.verifyclient.activate = "enable"
#ssl.verifyclient.enforce = "enable"
#ssl.verifyclient.depth = 1
#### status module
#status.status-url = "/server-status"
#status.config-url = "/server-config"
# Configuration from other optware packages
include_shell "cat /opt/etc/lighttpd/conf.d/*.conf"
