Results 1 to 14 of 14
Thread: WL500gx GPIO shit
    Nov 2003
    Eindhoven
    WL500gx GPIO shit
    [admin@WL500gx root]$ test gpio /dev/gpio/outen
    val : 1
    val : 0
    [admin@WL500gx root]$ test gpio /dev/gpio/in
    val : b6
    [admin@WL500gx root]$ test gpio /dev/gpio/control
    val : 0
    Power LED control
    So far I can only control Power LED with:
    echo 1 > /dev/gpio/out
    echo 0 > /dev/gpio/out
    Don't know if it alter anything else.
    i can do that too
    But there is only one power led, not 8, and it doesn't have a nice socket
    I'll try to use the functions from paraport_splink.c file, but so far ... segmentation fault.
    Apparently Zolf created a module that does just that...but I think he is no longer intrested in this.
    Update
    Created a module which gives me access to a memory location.
    It is still very basic but i can now access the data register of the parallel port
    and turn the connected LED on and off with a kind of /dev/gpio interface.
    I used the gpio.c 'example' of the /linux/arch/mips/brcm* directory and some code from parport_splink.c.
    Free gpio line on wl500Gp
    Hello all,
    This is my first post here, i'm found of wl500gX who is in end of life. My next router will be an wl500gP but i need two gpio line for adding an i2c bus.
    Is anyone have tested gpio line on this board ?
    I haven't seen gpio line on picture, is there gpio line accessible like on 500gX ?
    Thanks in advance.
    I reply myself.
    I have buy one wl500gp and there is no gpio line directly available.
    I will search for in next day.
    Quote Originally Posted by gzalou View Post
    Hello all,
    ... but i need two gpio line for adding an i2c bus.
    Ia anybody has found free GPIO lines?
    Quote Originally Posted by dINIs View Post
    Hey!
    Could you find out something about the GPIO lines on the Asus Wl 500? I need it also for I2C purpose.
    GPIO lines on WL-500g Premium
    Hello all, i'm looking for schematic or description where can i find GPIO lines ??
    I want connect to router I2C bus etc.. Many thanks for help.
    Ondra
    Question Flashing leds
    Hi!
    I want to flash the leds.
    I know how to switch on (printf "\x00" > /dev/gpio/out) and off (printf "\x02" > /dev/gpio/out) the power led, but i want to switch the others.
    Is this possible?
    Apr 2006
    Heesch, Netherlands
    GPIO on wl500gx
    I would like to use GPIO lines for monitoring some signals, and to power an external led.
    I have no clue however, how this should be done. I've read something about the diag driver on OpenWRT, but I run Oleg's firmware.
    I have a wl500gx (deluxe)
    I see something about gpio in /dev/gpio but I don't know how to use it.
    I want to monitor three states on each gpio line: on/off/flashing (1 sec interval on-off)
    Anyone?
    Solar inverter monitoring with Asus wl500gx http://solar.reinieren.net (dutch)
    Quote Originally Posted by mistraller View Post
    Anyone?
    You can use USB HID device (keyboard) as input/output interface. Input - keys circuit, output - LED line.
    © 2008-2013 ABATAPA WL-500gP/128M / Asus RT-N16 / USB Flash / VLAN / PPPoE / VoIP / nShaper / NAS: iStor is607, Sarotech NAS-20, QNap 109 Pro / NFS / Ïðèíòåð / etc
    Apr 2006
    Heesch, Netherlands
    All 4 usb ports are in use, and GPIO is free to use. I don't want to add an USB hub, if gpio ports are available.
    Maybe not the easiest solution, but the most interesting for me, because i want to know how GPIO works.
    Feb 2007
    well, if you need only reading by router from these GPIOs, I guess it is the easiest. Just read continuously:
    PHP Code:
    cat /dev/gpio/in
    then change the state of the pins and see the changes in the value obtained and try to figure out which bit is which.
    To write to /dev/gpio/out you should provide first a bit mask in /dev/gpio/outen
