Usb interfaces problems WL-500GP v2
When I connect usb modems to my router, it does not recognize nothing, no vendor id , product id.
I tried with modem onda HS600, nothing,
SAMSUNG U700(HSDPA) , nothing
Siemens P990 (UMTS), nothing
WHen I connect hard disc no problem. I connected HDD IOMEGA 120 Giga no powered, ok.
I connected 500 G LANCE HDD, external supply, ok
I also connected an Iphone (it is not a modem) and it was recognized, even without external supply.
I tried with powered usb hub, but nothing changed.
Initially I tested with Koppel wl500GP v2 software (see
http://koppel.cz/conferences/viewtop...r=asc&start=30). Afterwards I upgraded directly to oleg firmware 10 for WL500GPv2 and I have the same problem.
Did you ever tested file log with an usb modem in v2?
Is it a problem of firmware 10?
thanks
