Results 1 to 2 of 2
Thread: WLHDD can not use Home Gateway mode
    hi,
    i upgrade my WLHDD's firmware to 1.9.2.7-9, but there is a problem i found.
    in System Setup -> Operation Mode
    when i switch to "Home Gateway" mode and restart my AP...it is broken!! so i need to press reset bottom to reset it to "AP" mode...
    anyone else get the same result?
    what's wrong with my AP?
    Jun 2006
    England
    Quote Originally Posted by dahanhsi View Post
    hi,
    It works with 1.9.2.7-7 that I'm running.
    Are you forgeting that when you setup gateway mode, you can no longer access the admin webpage from the ethernet side due to the nat/firewall settings? You have to login from wifi side, or enable web access from WAN in firewall setting before you commit.
  1. OLEG + Client Mode
    By eriche in forum WL-500w Q&A
    Last Post: 16-03-2008, 12:38
  2. WL500g as a home gateway
    By rigips in forum WL-500g Q&A
    Last Post: 18-11-2006, 15:09
  3. Replies: 2
    Last Post: 17-03-2006, 07:33
  4. Probleem met Hostnames in Gateway mode...
    By molski in forum Dutch Discussion - Nederlands
    Last Post: 31-01-2006, 21:42
  5. AP mode x Home Gateway mode
    By Fi-5 in forum WL-500g Q&A
    Last Post: 17-02-2005, 08:24
