have a look at my screenshot:
screenshot
this is how my wan 2 lan is set up.
@wiz
Ok Firewall works but why i couldnt get into the web after enable WAN 2 LAN Filters!
All Ports i needed are described in my WAN 2 LAN Filters and LAN 2 WAN is disabled!
Shawn
Here is a hardcopy of my selections!
A little bit deeper there is also Port 80 (BLANK - 80 - BLANK - BLANK - TCP ALL). You couldnt see it on this picture!
screenshot
Thats my problem Wiz!
If i enable WAN 2 LAN Filter and the settings are.....
I didnt come into the web!
Shawn
I found the problem!
Its not TCP ALL!
ITS only TCP!
That was the problem!
Now it works for web and i will try the other entries!
Shawn
Now i have a new problem!
All ports are working fine!
Port 110
Port 25
Port 20:21
Port 443
Port 123 and
Port 53
but i have a problem with these ports for my eMule!
4661:4665
4672
Could anybody help me with this last WAN 2 LAN Problem?
Many ThX!
I think you should also add 4673 (both tcp and udp) for kademlia to work.... (or is that not your problem?)
No thats not my problem!
Kad is still connecting, but eMule will not connect!
Many ThX!
Shawn
I've got it like this, and it's working. (currently using 1.9.2.7-2, with 1.8.x.x is was also working)
Many ThX for your answer Vonk!
I will try it!
Shawn
P.S. Your are using 1.9.2.7-2!
It is possible to downgrade to 1.9.2.7 if i try 1.9.2.7-2?
you can just downgrade to 1.9.2.7 yesOriginally Posted by Shawn
[QUOTE=Shawn]
I will try it!
Shawn
...have you tied it?
Any results?
I have the same problem with the WAN 2 LAN filtering.
My firm. is 1.9.2.7 -5
lg opg
http://home.no.net/emo/lan2wan.jpg
This screen-grab shows what I have tried after reading this thread.
What I actually want to achieve is to stop all access to Internet no matter what during a given period of time.
How do I do this?
