hi,
i missed the nfs-support too. therefore i changed to openwrt - it ofters the common packages so that you should be able to configure what you need.
i wrote some lines to my experiences:
http://wl500g.info/showthread.php?p=38090
regards.
The router also supports the ext2 filesystem, so you could format an external HD (or partition) with that.
hi,
regards.
--double posting --- sorry
Hi
I've connected a 300GB disk to my rouler, it contains two partitions a ntfs 275 GB and an ext2 partition 25 GB. I'have of course not writing access to the ntfs, but strangely it is the same with the ext2 partition. If I format the ext2 patition to fat32 I can write to it, I do however have files > 4GB.
why can't I write to my ext2 partition, does any one have an idea how to fix this?
I'll like just to have just one partition with R/W access I can use from my Win XP clients. At the moment I am using "Ext2 Installable File System for Windows" to access ext2, which works fine when connected direct via USB.
I connected a FAT32 HDD and it works fine.
But FAT32 does not support the file above 4GB.
Any suggestions very gratefully received!
ps. sorry for my english ,i'm from Taiwan
Use ext3, as NTFS is r/o.
I have one ext3 partition mounted to /tmp/harddisk and one ntfs partition mounted to /tmp/harddisk/part1. I can access ext3 partition normally (read/write) via samba, but I cannot access my ntfs partition at all.
I tried to change the attributes of the /tmp/harddisk/part1 directory but without success. While ntfs partition isn't mounted, I can set all the read permissions correctly, but as soon as I mount ntfs partition, /tmp/harddisk/part1 looses all the read permissions.
How can I solve this problem?
btw, I can see both partitions via stupid ftp correctly
Hello together,
I have the original firmware on my asus and want to enable media server to access the attached 500gb HDD with a playstation 3.
The problem now is, that it is recognized by the playstation, but not readable.
WIth my laptop I cannot create folders or save files on it.
Therefore I guess it is an problem with permissions.
has anyone an idea?
thank you
NTFS is never writable when mounted to the asus.
And I don't know if the original firmware supports ntfs-read,
oleg firmware does.
if you want read/write access use fat32, if you can live wiht small (<2gb) files.
otherwise use ext2/ext3 (*nix) filesystem, these one can be mounted rw and don't have a 2gb limit.
HeadStart
did not work
[admin@(none) /tmp]$ ls
dnsmasq.log harddisk nas.lan.pid ppp syslog.log
etc local nas.wan.conf resolv.conf udhcpc
filter_rules nas.lan.conf nat_rules syscmd.log var
[admin@(none) /tmp]$ cd harddisk/
[admin@(none) harddisk]$ mkdir asdf
mkdir: Cannot create directory `asdf': Read-only file system
any recommandations?
The keyword from the previous message is: "NTFS is never writable"
So, relax. there's no way around.
WL-500W cant read my external USB harddisk. I use the latest Oleg's firmware (1.9.2.7-10) and I get this error message:
kernel: NTFS: Unable to set blocksize 512.
kernel: NTFS: Partition cluster size is not supported yet (it is > max kernel blocksize).
Is it possible to solve this problem somehow, please? (I mean - not to reformat harddisk and set smaller cluster size, of course.)
Thanks
P.S. Sorry for my english
For now, i think there is only support for FAT32, ext2 and ext3.
FAT32 and EXT3 are supported in oleg.
NTFS should be read-only
if you want to format the disk on your pc, you might want to use this:
http://gparted.sourceforge.net/livecd.php
it formats and partitions harddisks to nearly anything, and free
if you want to format it on your router, just read wengi''s howto
